MMWAVE-STUDIO: Crashes with error
Part Number: MMWCAS-DSP-EVM
Hello Team,
I'm posting on behalf of my customer, please see the inquiry below:
Currently referring to this guide to set up my radar.
 1447.mmwave_studio_cascade_user_guide.pdf
On step 5, I am using Teraterm to format the SSD, but the program keeps crashing with an error.
The crash seems to always happen after a certain amount of time. It works fine, then as I am going through the steps it just crashes.
U-Boot SPL 2016.05-00018-g6bc25a5 (Aug 05 2019 - 14:43:03)
DRA752-GP ES2.0
no pinctrl for hs200_1_8v
no pinctrl for ddr_1_8v
Card did not respond to voltage select!
*** Warning - MMC init failed, using default environment
Trying to boot from MMC1
reading dra7-ipu2-fw.lzop
spl_load_file_fat: error reading file dra7-ipu2-fw.lzop, err - -1
spl: error reading image dra7-ipu2-fw.lzop, err - -1
Error loading remotecore IPU2!,Continuing with boot ...
reading dra7-dsp1-fw.lzop
spl_load_file_fat: error reading file dra7-dsp1-fw.lzop, err - -1
spl: error reading image dra7-dsp1-fw.lzop, err - -1
Error loading remotecore DSP1!,Continuing with boot ...
reading dra7-dsp2-fw.lzop
spl_load_file_fat: error reading file dra7-dsp2-fw.lzop, err - -1
spl: error reading image dra7-dsp2-fw.lzop, err - -1
Error loading remotecore DSP2!,Continuing with boot ...
reading dra7-ipu1-fw.lzop
spl_load_file_fat: error reading file dra7-ipu1-fw.lzop, err - -1
spl: error reading image dra7-ipu1-fw.lzop, err - -1
Error loading remotecore IPU1!,Continuing with boot ...
spl: falcon_args_file not set in environment, falling back to default
reading single-stage-boot.dtb
spl_load_image_fat_os: error reading image single-stage-boot.dtb, err - -1
reading u-boot.img
reading u-boot.img
reading u-boot.img
reading u-boot.img
U-Boot 2016.05-00018-g6bc25a5 (Aug 05 2019 - 14:43:03 +0530)
CPU  : DRA752-GP ES2.0
Model: TI DRA742
Board: DRA74x Cascade EVM REV H.4
DRAM:  4 GiB
MMC:   i2c_write: error waiting for data ACK (status=0x116)
pcf8575_i2c_write_le16 i2c write failed to addr 21
OMAP SD/MMC: 0, OMAP SD/MMC: 1
ERROR: invalid mmc device
at arch/arm/cpu/armv7/omap-common/utils.c:193/mmc_get_part_size()
Warning: fastboot.userdata_size: unable to calc
SCSI:  SATA link 0 timeout.
AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl SATA mode
flags: 64bit ncq stag pm led clo only pmp pio slum part ccc apst
scanning bus for devices...
Found 0 device(s).
Net:   Could not get PHY for ethernet@48484000: addr 2
Warning: ethernet@48484000 using MAC address from ROM
eth0: ethernet@48484000
Hit any key to stop autoboot:  0
## Error: "board_findfdt" not defined
switch to partitions #0, OK
mmc0 is current device
SD/MMC found on device 0
reading boot.scr
** Unable to read file boot.scr **
reading uEnv.txt
185 bytes read in 2 ms (89.8 KiB/s)
Loaded env from uEnv.txt
Importing environment from mmc0 ...
3577032 bytes read in 168 ms (20.3 MiB/s)
107792 bytes read in 20 ms (5.1 MiB/s)
Booting from mmc0 ...
Kernel image @ 0x82000000 [ 0x000000 - 0x3694c8 ]
   Loading Device Tree to 8ffe2000, end 8ffff50f ... OK
Starting kernel ...
[    0.000000] Booting Linux on physical CPU 0x0
[    0.000000] Initializing cgroup subsys cpuset
[    0.000000] Initializing cgroup subsys cpuacct
[    0.000000] Linux version 4.4.84-00041-g84382ab (x0284921@bangvideoapps02) (gcc version 5.3.1 20160113 (Linaro GCC 5.3-2016.02) ) #1 SMP PREEMPT Mon Aug 5 14:52:40 IST 2019
[    0.000000] CPU: ARMv7 Processor [412fc0f2] revision 2 (ARMv7), cr=30c5387d
[    0.000000] CPU: PIPT / VIPT nonaliasing data cache, PIPT instruction cache
[    0.000000] Machine model: TI DRA742 Cascade Radar Board
[    0.000000] Reserved memory: created DMA memory pool at 0x0000000040300000, size 3 MiB
[    0.000000] Reserved memory: initialized node cmem@40300000, compatible id shared-dma-pool
[    0.000000] Reserved memory: regions without no-map are not yet supported
[    0.000000] Reserved memory: created CMA memory pool at 0x0000000099000000, size 80 MiB
[    0.000000] Reserved memory: initialized node ipu2_cma@95800000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x000000009e000000, size 32 MiB
[    0.000000] Reserved memory: initialized node ipu1_cma@9d000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a1000000, size 32 MiB
[    0.000000] Reserved memory: initialized node dsp1_cma@99000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created CMA memory pool at 0x00000000a3000000, size 32 MiB
[    0.000000] Reserved memory: initialized node dsp2_cma@9f000000, compatible id shared-dma-pool
[    0.000000] Reserved memory: created DMA memory pool at 0x00000000a9000000, size 64 MiB
[    0.000000] Reserved memory: initialized node cmem@A9000000, compatible id shared-dma-pool
[    0.000000] cma: Reserved 64 MiB at 0x00000000bc000000
[    0.000000] Forcing write-allocate cache policy for SMP
[    0.000000] Memory policy: Data cache writealloc
[    0.000000] OMAP4: Map 0x000000027fd00000 to fe600000 for dram barrier
[    0.000000] DRA752 ES2.0
[    0.000000] PERCPU: Embedded 11 pages/cpu @f2f1e000 s14912 r8192 d21952 u45056
[    0.000000] Built 1 zonelists in Zone order, mobility grouping on.  Total pages: 1025330
[    0.000000] Kernel command line: console=ttyO0,115200n8 vram=16M root=PARTUUID=3cc717e1-02 rw rootwait ip=none cma=64M vmalloc=128M
[    0.000000] PID hash table entries: 4096 (order: 2, 16384 bytes)
[    0.000000] Dentry cache hash table entries: 131072 (order: 7, 524288 bytes)
[    0.000000] Inode-cache hash table entries: 65536 (order: 6, 262144 bytes)
[    0.000000] Memory: 2439424K/4109312K available (6671K kernel code, 320K rwdata, 2396K rodata, 336K init, 290K bss, 1424128K reserved, 245760K cma-reserved, 2167808K highmem)
[    0.000000] Virtual kernel memory layout:
[    0.000000]     vector  : 0xffff0000 - 0xffff1000   (   4 kB)
[    0.000000]     fixmap  : 0xffc00000 - 0xfff00000   (3072 kB)
[    0.000000]     vmalloc : 0xf8000000 - 0xff800000   ( 120 MB)
[    0.000000]     lowmem  : 0xc0000000 - 0xf7800000   ( 888 MB)
[    0.000000]     pkmap   : 0xbfe00000 - 0xc0000000   (   2 MB)
[    0.000000]     modules : 0xbf000000 - 0xbfe00000   (  14 MB)
[    0.000000]       .text : 0xc0008000 - 0xc08e302c   (9069 kB)
[    0.000000]       .init : 0xc08e4000 - 0xc0938000   ( 336 kB)
[    0.000000]       .data : 0xc0938000 - 0xc0988220   ( 321 kB)
[    0.000000]        .bss : 0xc098a000 - 0xc09d2880   ( 291 kB)
[    0.000000] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=2, Nodes=1
[    0.000000] Preemptible hierarchical RCU implementation.
[    0.000000]  Build-time adjustment of leaf fanout to 32.
[    0.000000] NR_IRQS:16 nr_irqs:16 16
[    0.000000] ti_dt_clocks_register: failed to lookup clock node gmac_gmii_ref_clk_div
[    0.000000] OMAP clockevent source: timer1 at 32786 Hz
[    0.000000] Architected cp15 timer(s) running at 6.14MHz (phys).
[    0.000000] clocksource: arch_sys_counter: mask: 0xffffffffffffff max_cycles: 0x16af5adb9, max_idle_ns: 440795202250 ns
[    0.000004] sched_clock: 56 bits at 6MHz, resolution 162ns, wraps every 4398046511023ns
[    0.000015] Switching to timer-based delay loop, resolution 162ns
[    0.000341] clocksource: 32k_counter: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 58327039986419 ns
[    0.000349] OMAP clocksource: 32k_counter at 32768 Hz
[    0.000803] Console: colour dummy device 80x30
[    0.000819] WARNING: Your 'console=ttyO0' has been replaced by 'ttyS0'
[    0.000825] This ensures that you still see kernel messages. Please
[    0.000830] update your kernel commandline.
[    0.000843] Calibrating delay loop (skipped), value calculated using timer frequency.. 12.29 BogoMIPS (lpj=61475)
[    0.000856] pid_max: default: 32768 minimum: 301
[    0.000954] Mount-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.000964] Mountpoint-cache hash table entries: 2048 (order: 1, 8192 bytes)
[    0.001511] Initializing cgroup subsys io
[    0.001528] Initializing cgroup subsys memory
[    0.001552] Initializing cgroup subsys devices
[    0.001564] Initializing cgroup subsys freezer
[    0.001575] Initializing cgroup subsys perf_event
[    0.001586] Initializing cgroup subsys pids
[    0.001614] CPU: Testing write buffer coherency: ok
[    0.001811] /cpus/cpu@0 missing clock-frequency property
[    0.001827] /cpus/cpu@1 missing clock-frequency property
[    0.001837] CPU0: thread -1, cpu 0, socket 0, mpidr 80000000
[    0.001872] Setting up static identity map for 0x80008380 - 0x800083e0
[    0.080054] CPU1: thread -1, cpu 1, socket 0, mpidr 80000001
[    0.080123] Brought up 2 CPUs
[    0.080135] SMP: Total of 2 processors activated (24.59 BogoMIPS).
[    0.080142] CPU: All CPU(s) started in HYP mode.
[    0.080147] CPU: Virtualization extensions available.
[    0.080525] devtmpfs: initialized
[    0.109424] VFP support v0.3: implementor 41 architecture 4 part 30 variant f rev 0
[    0.110403] omap_hwmod: l3_main_2 using broken dt data from ocp
[    0.313003] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 19112604462750000 ns
[    0.313024] futex hash table entries: 512 (order: 3, 32768 bytes)
[    0.318083] pinctrl core: initialized pinctrl subsystem
[    0.318954] NET: Registered protocol family 16
[    0.319900] DMA: preallocated 256 KiB pool for atomic coherent allocations
[    0.350229] cpuidle: using governor ladder
[    0.380253] cpuidle: using governor menu
[    0.388800] OMAP GPIO hardware version 0.1
[    0.392746] irq: no irq domain found for /ocp/l4@4a000000/scm@2000/pinmux@1400 !
[    0.408174] omap-gpmc 50000000.gpmc: GPMC revision 6.0
[    0.408187] gpmc_mem_init: disabling cs 0 mapped at 0x0-0x1000000
[    0.417288] hw-breakpoint: found 5 (+1 reserved) breakpoint and 4 watchpoint registers.
[    0.417299] hw-breakpoint: maximum watchpoint size is 8 bytes.
[    0.417769] omap4_sram_init:Unable to allocate sram needed to handle errata I688
[    0.417779] omap4_sram_init:Unable to get sram pool needed to handle errata I688
[    0.418356] OMAP DMA hardware revision 0.0
[    0.461438] omap-dma-engine 4a056000.dma-controller: OMAP DMA engine driver (LinkedList1/2/3 supported)
[    0.462569] edma 43300000.edma: memcpy is disabled
[    0.467290] edma 43300000.edma: TI EDMA DMA engine driver
[    0.471352] omap-iommu 40d01000.mmu: 40d01000.mmu registered
[    0.471536] omap-iommu 40d02000.mmu: 40d02000.mmu registered
[    0.471696] omap-iommu 58882000.mmu: 58882000.mmu registered
[    0.471856] omap-iommu 55082000.mmu: 55082000.mmu registered
[    0.472133] omap-iommu 41501000.mmu: 41501000.mmu registered
[    0.472337] omap-iommu 41502000.mmu: 41502000.mmu registered
[    0.475367] palmas 0-0058: IRQ missing: skipping irq request
[    0.490819] palmas 0-0058: Muxing GPIO 2e, PWM 0, LED 0
[    0.552687] pcf857x: probe of 0-0020 failed with error -121
[    0.552937] pcf857x: probe of 0-0021 failed with error -121
[    0.553807] omap_i2c 48070000.i2c: bus 0 rev0.12 at 400 kHz
[    0.554211] omap_i2c 48060000.i2c: bus 2 rev0.12 at 400 kHz
[    0.554407] media: Linux media interface: v0.10
[    0.554459] Linux video capture interface: v2.00
[    0.554500] pps_core: LinuxPPS API ver. 1 registered
[    0.554507] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti <giometti@linux.it>
[    0.554536] PTP clock support registered
[    0.554586] EDAC MC: Ver: 3.0.0
[    0.555336] omap-mailbox 48840000.mailbox: omap mailbox rev 0x400
[    0.555627] omap-mailbox 48842000.mailbox: omap mailbox rev 0x400
[    0.555955] Advanced Linux Sound Architecture Driver Initialized.
[    0.556812] clocksource: Switched to clocksource arch_sys_counter
[    0.567390] NET: Registered protocol family 2
[    0.567890] TCP established hash table entries: 8192 (order: 3, 32768 bytes)
[    0.567953] TCP bind hash table entries: 8192 (order: 4, 65536 bytes)
[    0.568078] TCP: Hash tables configured (established 8192 bind 8192)
[    0.568124] UDP hash table entries: 512 (order: 2, 16384 bytes)
[    0.568155] UDP-Lite hash table entries: 512 (order: 2, 16384 bytes)
[    0.568300] NET: Registered protocol family 1
[    0.568607] RPC: Registered named UNIX socket transport module.
[    0.568617] RPC: Registered udp transport module.
[    0.568623] RPC: Registered tcp transport module.
[    0.568630] RPC: Registered tcp NFSv4.1 backchannel transport module.
[    0.569585] hw perfevents: enabled with armv7_cortex_a15 PMU driver, 7 counters available
[    0.579594] squashfs: version 4.0 (2009/01/31) Phillip Lougher
[    0.580242] NFS: Registering the id_resolver key type
[    0.580276] Key type id_resolver registered
[    0.580284] Key type id_legacy registered
[    0.580342] ntfs: driver 2.1.32 [Flags: R/O].
[    0.581620] bounce: pool size: 64 pages
[    0.581777] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 247)
[    0.581793] io scheduler noop registered
[    0.581806] io scheduler deadline registered
[    0.581840] io scheduler cfq registered (default)
[    0.587348] pinctrl-single 4a003400.pinmux: 282 pins at pa fc003400 size 1128
[    0.590848] PCI host bridge /ocp/axi@0/pcie_rc@51000000 ranges:
[    0.590861]   No bus range found for /ocp/axi@0/pcie_rc@51000000, using [bus 00-ff]
[    0.590895]    IO 0x20003000..0x20012fff -> 0x00000000
[    0.590916]   MEM 0x20013000..0x2fffffff -> 0x20013000
[    0.591125] dra7-pcie 51000000.pcie_rc: CFG 'Bus Master Enable' change
[    0.591134] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618167] dra7-pcie 51000000.pcie_rc: PCI host bridge to bus 0000:00
[    0.618180] pci_bus 0000:00: root bus resource [bus 00-ff]
[    0.618191] pci_bus 0000:00: root bus resource [io  0x0000-0xffff]
[    0.618200] pci_bus 0000:00: root bus resource [mem 0x20013000-0x2fffffff]
[    0.618262] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618279] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618303] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618317] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618339] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618354] dra7-pcie 51000000.pcie_rc: CFG 'Memory Space Enable' change
[    0.618657] PCI: bus0: Fast back to back transfers disabled
[    0.636902] PCI: bus1: Fast back to back transfers disabled
[    0.637030] pci 0000:00:00.0: BAR 0: assigned [mem 0x20100000-0x201fffff]
[    0.637045] pci 0000:00:00.0: BAR 8: assigned [mem 0x20200000-0x202fffff]
[    0.637056] pci 0000:00:00.0: BAR 1: assigned [mem 0x20020000-0x2002ffff]
[    0.637070] pci 0000:01:00.0: BAR 0: assigned [mem 0x20200000-0x20203fff 64bit]
[    0.637118] pci 0000:00:00.0: PCI bridge to [bus 01]
[    0.637130] pci 0000:00:00.0:   bridge window [mem 0x20200000-0x202fffff]
[    0.637342] pcieport 0000:00:00.0: Signaling PME through PCIe PME interrupt
[    0.637351] pci 0000:01:00.0: Signaling PME through PCIe PME interrupt
[    0.698674] Serial: 8250/16550 driver, 10 ports, IRQ sharing disabled
[    0.702048] 4806a000.serial: ttyS0 at MMIO 0x4806a000 (irq = 202, base_baud = 3000000) is a 8250
[    1.801979] console [ttyS0] enabled
[    1.806371] 4806c000.serial: ttyS1 at MMIO 0x4806c000 (irq = 203, base_baud = 3000000) is a 8250
[    1.816077] 48020000.serial: ttyS2 at MMIO 0x48020000 (irq = 204, base_baud = 3000000) is a 8250
[    1.826101] [drm] Initialized drm 1.1.0 20060810
[    1.831654] [drm] Supports vblank timestamp caching Rev 2 (21.10.2013).
[    1.838342] [drm] No driver support for vblank timestamp query.
[    1.844472] [drm] Initialized vdrm 1.0.0 20110917 on minor 0
[    1.851626] OMAP DSS rev 6.1
[    1.855372] omapdss_dss 58000000.dss: bound 58001000.dispc (ops dispc_component_ops)
[    1.871003] loop: module loaded
[    1.874539] vmemexp device MAJOR num = 245
[    1.878689] vmemexp class registered
[    1.882402] /dev/vmemexp device registered
[    1.886515] ioctl DBUFIOC_EXPORT_VIRTMEM = -1072899120
[    1.892065] nvme 0000:01:00.0: enabling device (0140 -> 0142)
[    1.898481] nand: No NAND device found
[    1.902251] omap2-nand 8000000.nand: scan failed, may be bus-width mismatch
[    1.911354] m25p80 spi32766.0: found n25q00, expected s25fl256s1
[    1.917457] m25p80 spi32766.0: n25q00 (131072 Kbytes)
[    1.922589] 7 ofpart partitions found on MTD device spi32766.0
[    1.928465] Creating 7 MTD partitions on "spi32766.0":
[    1.933628] 0x000000000000-0x000000040000 : "QSPI.SPL"
[    1.949782] 0x000000040000-0x000000140000 : "QSPI.u-boot"
[    1.966097] 0x000000140000-0x0000001c0000 : "QSPI.u-boot-spl-os"
[    1.983068] 0x0000001c0000-0x0000001d0000 : "QSPI.u-boot-env"
[    1.989733] 0x0000001d0000-0x0000001e0000 : "QSPI.u-boot-env.backup1"
[    2.007130] 0x0000001e0000-0x0000009e0000 : "QSPI.kernel"
[    2.016768]  nvme0n1: p1
[    2.023485] 0x0000009e0000-0x000002000000 : "QSPI.file-system"
[    2.041283] libphy: Fixed MDIO Bus: probed
[    2.096845] davinci_mdio 48485000.mdio: davinci mdio revision 1.6
[    2.102972] libphy: 48485000.mdio: probed
[    2.120439] davinci_mdio 48485000.mdio: phy[2]: device 48485000.mdio:02, driver TI DP83867
[    2.129382] cpsw 48484000.ethernet: Detected MACID = e0:62:34:52:60:e8
[    2.136030] cpsw 48484000.ethernet: cpts: overflow check period 800
[    2.143003] cpsw 48484000.ethernet: cpsw: Detected MACID = e0:62:34:52:60:e9
[    2.151631] mousedev: PS/2 mouse device common for all mice
[    2.167840] i2c /dev entries driver
[    2.176592] omap_hsmmc 4809c000.mmc: Got CD GPIO
[    2.227388] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr25 mode
[    2.233776] omap_hsmmc 480b4000.mmc: no pinctrl state for sdr12 mode
[    2.246960] evm_3v3_sw: supplied by sysen1
[    2.307654] ledtrig-cpu: registered to indicate activity on CPUs
[    2.317738] aic_dvdd: supplied by evm_3v3_sw
[    2.322989] davinci-mcasp 4847c000.mcasp: invalid tdm slots: 0
[    2.330498] NET: Registered protocol family 10
[    2.345806] sit: IPv6 over IPv4 tunneling driver
[    2.351014] NET: Registered protocol family 17
[    2.355694] Key type dns_resolver registered
[    2.360140] omap_voltage_late_init: Voltage driver support not added
[    2.367051] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.373260] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.379965] Adding alias for supply vdd,cpu0 -> vdd,4a003b20.oppdm
[    2.386171] Adding alias for supply vbb,cpu0 -> vbb,4a003b20.oppdm
[    2.393502] Power Management for TI OMAP4+ devices.
[    2.398630] Registering SWP/SWPB emulation handler
[    2.404751] dmm 4e000000.dmm: workaround for errata i878 in use
[    2.412292] dmm 4e000000.dmm: initialized all PAT entries
[    2.418720] [drm] Initialized omapdrm 1.0.0 20110917 on minor 1
[    2.446578] hctosys: unable to open rtc device (rtc0)
[    2.463701] evm_1v8: disabling
[    2.466778] aic_dvdd: disabling
[    2.470140] ldousb: disabling
[    2.473604] ALSA device list:
[    2.476585]   No soundcards found.
[    2.480901] Waiting for root device PARTUUID=3cc717e1-02...
[    2.497052] mmc0: host does not support reading read-only switch, assuming write-enable
[    2.509695] mmc0: new high speed SDHC card at address aaaa
[    2.515654] mmcblk0: mmc0:aaaa SS08G 7.40 GiB
[    2.522788]  mmcblk0: p1 p2
[    2.589422] EXT4-fs (mmcblk0p2): couldn't mount as ext3 due to feature incompatibilities
[    2.600014] EXT4-fs (mmcblk0p2): couldn't mount as ext2 due to feature incompatibilities
[    2.773027] EXT4-fs (mmcblk0p2): recovery complete
[    2.778755] EXT4-fs (mmcblk0p2): mounted filesystem with ordered data mode. Opts: (null)
[    2.786934] VFS: Mounted root (ext4 filesystem) on device 179:2.
[    2.796930] devtmpfs: mounted
[    2.800123] Freeing unused kernel memory: 336K
[    2.804661] This architecture does not have kernel memory protection.
[    2.997452] systemd[1]: System time before build time, advancing clock.
[    3.038313] random: systemd: uninitialized urandom read (16 bytes read, 17 bits of entropy available)
[    3.053204] random: systemd: uninitialized urandom read (16 bytes read, 18 bits of entropy available)
[    3.064928] systemd[1]: systemd 229 running in system mode. (+PAM -AUDIT -SELINUX +IMA -APPARMOR +SMACK +SYSVINIT +UTMP -LIBCRYPTSETUP -GCRYPT +GNUTLS +ACL +XZ -LZ4 -SECCOMP +BLKID -ELFUTILS +KMOD -IDN)
[    3.083460] systemd[1]: Detected architecture arm.
Welcome to Arago 2016.12!
[    3.109783] systemd[1]: Set hostname to <dra7xx-evm>.
[    3.183555] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.194044] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.204284] random: systemd-gpt-aut: uninitialized urandom read (16 bytes read, 19 bits of entropy available)
[    3.224800] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.238997] random: systemd-sysv-ge: uninitialized urandom read (16 bytes read, 20 bits of entropy available)
[    3.318209] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    3.327767] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    3.337783] random: systemd: uninitialized urandom read (16 bytes read, 23 bits of entropy available)
[    3.609886] systemd[1]: Configuration file /etc/systemd/system/multi-user.target.wants/vsdk.service is marked executable. Please remove executable permission bits. Proceeding anyway.
[    3.629041] systemd[1]: [/etc/systemd/system/multi-user.target.wants/vsdk.service:3] Failed to add dependency on rc.pvr, ignoring: Invalid argument
[    3.725391] systemd[1]: dbus.socket: Found ordering cycle on dbus.socket/start
[    3.732717] systemd[1]: dbus.socket: Found dependency on sysinit.target/start
[    3.740017] systemd[1]: dbus.socket: Found dependency on alignment.service/start
[    3.747495] systemd[1]: dbus.socket: Found dependency on basic.target/start
[    3.754493] systemd[1]: dbus.socket: Found dependency on sockets.target/start
[    3.761683] systemd[1]: dbus.socket: Found dependency on dbus.socket/start
[    3.768611] systemd[1]: dbus.socket: Breaking ordering cycle by deleting job alignment.service/start
[    3.777806] systemd[1]: alignment.service: Job alignment.service/start deleted to break ordering cycle starting with dbus.socket/start
[ SKIP ] Ordering cycle found, skipping alignment.service
[    3.819412] systemd[1]: Listening on udev Control Socket.
[  OK  ] Listening on udev Control Socket.
[    3.847262] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[  OK  ] Started Forward Password Requests to Wall Directory Watch.
[    3.877134] systemd[1]: Listening on /dev/initctl Compatibility Named Pipe.
[  OK  ] Listening on /dev/initctl Compatibility Named Pipe.
[    3.908483] systemd[1]: Created slice System Slice.
[  OK  ] Created slice System Slice.
[    3.937135] systemd[1]: Listening on udev Kernel Socket.
[  OK  ] Listening on udev Kernel Socket.
[    3.979065] systemd[1]: Listening on Journal Socket.
[  OK  ] Listening on Journal Socket.
[    4.047037] systemd[1]: Mounting POSIX Message Queue File System...
[    4.079459] systemd[1]: Starting Setup Virtual Console...
[    4.107921] systemd[1]: Created slice system-getty.slice.
[  OK  ] Created slice system-getty.slice.
[    4.137052] systemd[1]: Reached target Remote File Systems.
[  OK  ] Reached target Remote File Systems.
[    4.167165] systemd[1]: Listening on Journal Socket (/dev/log).
[  OK  ] Listening on Journal Socket (/dev/log).
[    4.227038] systemd[1]: Mounting Temporary Directory...
[    4.257875] systemd[1]: Created slice system-serial\x2dgetty.slice.
[  OK  ] Created slice system-serial\x2dgetty.slice.
[    4.287482] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[  OK  ] Started Dispatch Password Requests to Console Directory Watch.
[    4.317020] systemd[1]: Reached target Paths.
[  OK  ] Reached target Paths.
[    4.337033] systemd[1]: Reached target Swap.
[  OK  ] Reached target Swap.
[    4.357084] systemd[1]: Listening on Syslog Socket.
[  OK  ] Listening on Syslog Socket.
[    4.407271] systemd[1]: Starting Journal Service...
[    4.429775] systemd[1]: Mounting Debug File System...
[    4.462751] systemd[1]: Starting Load Kernel Modules...
[    4.487871] systemd[1]: Created slice User and Session Slice.
[  OK  ] Created slice User and Session Slice.
[    4.517136] systemd[1]: Reached target Slices.
[  OK  ] Reached target Slices.
[    4.567275] systemd[1]: Starting Create list of required static device nodes for the current kernel...
         Starting Create list of required st... nodes for the current kernel...
[    4.597327] systemd[1]: Listening on Network Service Netlink Socket.
[  OK  ] Listening on Network Service Netlink Socket.
[    4.667387] systemd[1]: Starting Remount Root and Kernel File Systems...
[    4.685710] EXT4-fs (mmcblk0p2): re-mounted. Opts: (null)
[    4.704193] systemd[1]: Mounted Debug File System.
[  OK  ] Mounted Debug File System.
[    4.737700] systemd[1]: Mounted POSIX Message Queue File System.
[  OK  ] Mounted POSIX Message Queue File System.
[    4.767118] systemd[1]: Mounted Temporary Directory.
[  OK  ] Mounted Temporary Directory.
[    4.798905] systemd[1]: Started Journal Service.
[  OK  ] Started Journal Service.
[  OK  ] Started Setup Virtual Console.
[FAILED] Failed to start Load Kernel Modules.
See 'systemctl status systemd-modules-load.service' for details.
[  OK  ] Started Create list of required sta...ce nodes for the current kernel.
[  OK  ] Started Remount Root and Kernel File Systems.
         Starting udev Coldplug all Devices...
         Starting Create Static Device Nodes in /dev...
         Starting Apply Kernel Variables...
         Starting Flush Journal to Persistent Storage...
[  OK  ] Started Create Static Device Nodes in /dev.
[  OK  ] Started Apply Kernel Variables.
[    5.517108] systemd-journald[122]: Received request to flush runtime journal from PID 1
[  OK  ] Started Flush Journal to Persistent Storage.
[  OK  ] Reached target Local File Systems (Pre).
         Mounting /var/volatile...
         Mounting /media/ram...
         Starting udev Kernel Device Manager...
[  OK  ] Mounted /var/volatile.
[  OK  ] Mounted /media/ram.
[  OK  ] Started udev Kernel Device Manager.
[  OK  ] Started udev Coldplug all Devices.
         Starting Load/Save Random Seed...
[  OK  ] Reached target Local File Systems.
         Starting Create Volatile Files and Directories...
[  OK  ] Started Load/Save Random Seed.
[    6.063114] omap-rproc 55020000.ipu: assigned reserved memory node ipu2_cma@95800000
[    6.073975]  remoteproc0: 55020000.ipu is available
[    6.079004]  remoteproc0: Note: remoteproc is still under development and considered experimental.
[    6.090112]  remoteproc0: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    6.104180] omap-rproc 40800000.dsp: assigned reserved memory node dsp1_cma@99000000
[    6.121721]  remoteproc1: 40800000.dsp is available
[    6.127572]  remoteproc1: Note: remoteproc is still under development and considered experimental.
[  OK  ] Started Create Volatile Files and Directories.[    6.171370]  remoteproc1: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[    6.249027]  remoteproc1: Direct firmware load for dra7-dsp1-fw.xe66 failed with error -2
[    6.264389] omap-rproc 41000000.dsp: assigned reserved memory node dsp2_cma@9f000000
[    6.280314]  remoteproc1: failed to load dra7-dsp1-fw.xe66
[    6.307867]  remoteproc2: 41000000.dsp is available
[    6.329033]  remoteproc2: Note: remoteproc is still under development and considered experimental.
[    6.361387]  remoteproc2: THE BINARY FORMAT IS NOT YET FINALIZED, and backward compatibility isn't yet guaranteed.
[  OK  ] Found device /dev/ttyS0.[    6.378880]  remoteproc2: Direct firmware load for dra7-dsp2-fw.xe66 failed with error -2
[    6.427442]  remoteproc2: failed to load dra7-dsp2-fw.xe66
[    6.465940]  remoteproc0: registered virtio0 (type 7)
[    6.472306] omap-des 480a5000.des: OMAP DES hw accel rev: 2.2
         Starting Update UTMP about System Boot/Shutdown...
         Starting Network Time Synchronization...
[    6.568542] omap_rng 48090000.rng: OMAP Random Number Generator ver. 20
[    6.580710] omap_rtc 48838000.rtc: rtc core: registered 48838000.rtc as rtc0
[  OK  ] Started Network Time Synchronization.
[  OK  ] Started Update UTMP about System Boot/Shutdown.
[    6.985081] omap-sham 4b101000.sham: hw accel on OMAP rev 4.3
[    7.038094] CAN device driver interface
[    7.070713] SCSI subsystem initialized
         Starting Synchronize System and HW clocks...
[  OK  ] Reached target System Time Synchronized.
[    7.147022] omap-aes 4b500000.aes: OMAP AES hw accel rev: 3.3
[  OK  ] Started Synchronize System and HW clocks.
[    7.198976] c_can_platform 4ae3c000.can: c_can_platform device registered (regs=fce3c000, irq=254)
[    7.242323] omap-aes 4b700000.aes: OMAP AES hw accel rev: 3.3
[  OK  ] Reached target System Initialization.
[    7.449931] ahci 4a140000.sata: SSS flag set, parallel bus scan disabled
[    7.456708] ahci 4a140000.sata: Enable 32-bit DMA instead of 64-bit.
[    7.456739] ahci 4a140000.sata: AHCI 0001.0300 32 slots 1 ports 3 Gbps 0x1 impl platform mode
[    7.456749] ahci 4a140000.sata: flags: 64bit ncq sntf stag pm led clo only pmp pio slum part ccc apst
[    7.533985] scsi host0: ahci
[    7.534359] ata1: SATA max UDMA/133 mmio [mem 0x4a140000-0x4a1410ff] port 0x100 irq 240
[    7.557508] [drm] Initialized pvr 1.14.3699939 20110701 on minor 2
[    7.575469] FAT-fs (mmcblk0p1): Volume was not properly unmounted. Some data may be corrupt. Please run fsck.
[  OK  ] Listening on dropbear.socket.
[  OK  ] Started Daily Cleanup of Temporary Directories.
[  OK  ] Reached target Timers.
[  OK  ] Listening on D-Bus System Message Bus Socket.
[  OK  ] Reached target Sockets.
[  OK  ] Reached target Basic System.[    7.808759] EXT4-fs (nvme0n1p1): recovery complete
[    7.833201] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[    7.867242] ata1: SATA link down (SStatus 0 SControl 300)
         Starting rc.pvr.service...
[  OK  ] Started Kernel Logging Service.
         Starting Permit User Sessions...
[    7.979271] PVR_K: UM DDK-(3699939) and KM DDK-(3699939) match. [ OK ]
[  OK  ] Started Launching Vision SDK App.
[  OK  ] Started System Logging Service.
         Starting Login Service...
[  OK  ] Started D-Bus System Message Bus.
         Starting Network Service...
[  OK  ] Started rc.pvr.service.
[  OK  ] Started Permit User Sessions.
[    8.456032] net eth0: initializing cpsw version 1.15 (0)
[    8.490255] net eth0: initialized cpsw ale version 1.4
[    8.495424] net eth0: ALE Table size 1024
[    8.518401]  remoteproc0: powering up 55020000.ipu
[    8.558637]  remoteproc0: Booting fw image dra7-ipu2-fw.xem4, size 4396172
[    8.565632] omap-iommu 55082000.mmu: 55082000.mmu: version 2.1
[    8.579368] net eth0: phy found : id is : 0x2000a231
[    8.601302] IPv6: ADDRCONF(NETDEV_UP): eth0: link is not ready
[    8.635184]  remoteproc0: remote processor 55020000.ipu is now up
[    8.649070] virtio_rpmsg_bus virtio0: rpmsg host is online
[    8.686981] virtio_rpmsg_bus virtio0: creating channel rpmsg-proto addr 0x50
[  OK  ] Started Network Service.
[    8.728641] NET: Registered protocol family 41
[  OK  ] Listening on Load/Save RF Kill Switch Status /dev/rfkill Watch.
[  OK  ] Started Serial Getty on ttyS0.
[  OK  ] Started Getty on tty1.
         Starting weston.service...
[  OK  ] Started weston.service.
[  OK  ] Started Login Service.
         Starting tiipclad-daemon.service...
         Starting telnetd.service...
[  OK  ] Started tiipclad-daemon.service.
[  OK  ] Started telnetd.service.
[FAILED] Failed to listen on Network Service Bus Name.
See 'systemctl status org.freedesktop.network1.busname' for details.
[FAILED] Failed to start Network Service.
See 'systemctl status systemd-networkd.service' for details.
[  OK  ] Reached target Network.
         Starting Network Name Resolution...
[  OK  ] Started Network Name Resolution.
[   11.584409] cpsw 48484000.ethernet eth0: Link is Up - 1Gbps/Full - flow control rx/tx
[   11.592333] IPv6: ADDRCONF(NETDEV_CHANGE): eth0: link becomes ready
[   13.237529] EXT4-fs (nvme0n1p1): mounted filesystem with ordered data mode. Opts: (null)
[   15.273890] DMA: Module install successful, device major num = 241
[   15.280271] DRV: Module install successful
 _____                    _____           _         _
|  _  |___ ___ ___ ___   |  _  |___ ___  |_|___ ___| |_
|     |  _| .'| . | . |  |   __|  _| . | | | -_|  _|  _|
|__|__|_| |__,|_  |___|  |__|  |_| |___|_| |___|___|_|
              |___|                    |___|
Arago Project http://arago-project.org dra7xx-evm ttyS0
Arago 2016.12 dra7xx-evm ttyS0
dra7xx-evm login: [   15.551813] omap_l3_noc 44000000.ocp: L3 application error: target 3 mod:2 (unclearable)
[   15.559985] omap_l3_noc 44000000.ocp: L3 debug error: target 3 mod:2 (unclearable)
[   49.912360] random: nonblocking pool is initialized
[  129.897882] Process 896(false) has RLIMIT_CORE set to 1
[  129.903138] Aborting core
[  129.944171] ------------[ cut here ]------------
[  129.948849] WARNING: CPU: 1 PID: 728 at mm/page_alloc.c:6827 free_contig_range+0x98/0x9c()
[  129.966877] 2025 pages are still in use!
[  129.970818] Modules linked in: memcache(O) rpmsg_proto virtio_rpmsg_bus bc_example(O) extcon_usb_gpio ahci_platform pvrsrvkm(O) libahci_platform libahci libata c_can_platform c_can scsi_mod omap_aes_driver can_dev omap_sham dwc3_omap extcon rtc_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[  130.037096] CPU: 0 PID: 728 Comm: weston Tainted: G           O    4.4.84-00041-g84382ab #1
[  130.045486] Hardware name: Generic DRA74X (Flattened Device Tree)
[  130.051606] Backtrace:
[  130.054091] [<c00131d4>] (dump_backtrace) from [<c00133d0>] (show_stack+0x18/0x1c)
[  130.061694]  r7:c00d939c r6:60010113 r5:00000000 r4:c0957810
[  130.067427] [<c00133b8>] (show_stack) from [<c02b21a8>] (dump_stack+0x8c/0xa0)
[  130.074685] [<c02b211c>] (dump_stack) from [<c0035340>] (warn_slowpath_common+0x88/0xb8)
[  130.082811]  r7:c00d939c r6:00001aab r5:00000009 r4:f5077bb8
[  130.088541] [<c00352b8>] (warn_slowpath_common) from [<c00353a8>] (warn_slowpath_fmt+0x38/0x40)
[  130.097278]  r8:c09b7880 r7:c093d5d0 r6:000bc9e9 r5:000007e9 r4:c082ca30
[  130.104067] [<c0035374>] (warn_slowpath_fmt) from [<c00d939c>] (free_contig_range+0x98/0x9c)
[  130.112541]  r3:000007e9 r2:c082ca30
[  130.116152]  r4:000bc9e9
[  130.118715] [<c00d9304>] (free_contig_range) from [<c011dd30>] (cma_release+0x90/0xb0)
[  130.126668]  r9:f2f9a000 r8:f626e410 r7:00000001 r6:f380e800 r5:c09b9470 r4:000bc200
[  130.134503] [<c011dca0>] (cma_release) from [<c03ecde0>] (dma_release_from_contiguous+0x38/0x40)
[  130.143327]  r5:00874800 r4:007e9000
[  130.146943] [<c03ecda8>] (dma_release_from_contiguous) from [<c001c8d8>] (__arm_dma_free+0x124/0x1fc)
[  130.156206] [<c001c7b4>] (__arm_dma_free) from [<c001c9f8>] (arm_dma_free+0x20/0x28)
[  130.163983]  r10:00000001 r9:c001c9d8 r8:bc200000 r7:f380e800 r6:007e9000 r5:f626e410
[  130.171902]  r4:f507f180
[  130.174462] [<c001c9d8>] (arm_dma_free) from [<c03ae8c4>] (v_gem_free_object+0x10c/0x144)
[  130.182681] [<c03ae7b8>] (v_gem_free_object) from [<c038e698>] (drm_gem_object_free+0x38/0x50)
[  130.191331]  r9:c038e974 r8:f5761000 r7:00000001 r6:f5892800 r5:f507f180 r4:f5892800
[  130.199164] [<c038e660>] (drm_gem_object_free) from [<c038e840>] (drm_gem_object_handle_unreference_unlocked+0xf0/0x124)
[  130.210080]  r5:f5892834 r4:f507f180
[  130.213695] [<c038e750>] (drm_gem_object_handle_unreference_unlocked) from [<c038e9cc>] (drm_gem_object_release_handle+0x58/0x70)
[  130.225393]  r5:f5761000 r4:f507f180
[  130.229010] [<c038e974>] (drm_gem_object_release_handle) from [<c02b2c68>] (idr_for_each+0xac/0xe0)
[  130.238096]  r7:00000001 r6:000000ff r5:f5077d28 r4:00000000
[  130.243823] [<c02b2bbc>] (idr_for_each) from [<c038f73c>] (drm_gem_release+0x24/0x30)
[  130.251687]  r10:f576107c r9:f5892834 r8:f58928f8 r7:f58928f4 r6:f5761080 r5:f5892800
[  130.259600]  r4:f5761020
[  130.262156] [<c038f718>] (drm_gem_release) from [<c038e490>] (drm_release+0x3f0/0x4b4)
[  130.270107]  r5:f5892800 r4:f5761000
[  130.273723] [<c038e0a0>] (drm_release) from [<c01220e4>] (__fput+0x88/0x1d0)
[  130.280803]  r10:f5761188 r9:00000008 r8:f5c445d8 r7:f542a110 r6:00000000 r5:f59c2f78
[  130.288717]  r4:f5761180
[  130.291272] [<c012205c>] (__fput) from [<c012228c>] (____fput+0x10/0x14)
[  130.298002]  r10:f57ab984 r9:f544bd40 r8:f50ec1fc r7:f5790000 r6:f507f300 r5:c098b81c
[  130.305917]  r4:f5790460
[  130.308472] [<c012227c>] (____fput) from [<c004e91c>] (task_work_run+0x98/0xcc)
[  130.315817] [<c004e884>] (task_work_run) from [<c0037d60>] (do_exit+0x300/0x9b8)
[  130.323242]  r7:f5077e40 r6:00000001 r5:f5790478 r4:f5790000
[  130.328967] [<c0037a60>] (do_exit) from [<c003849c>] (do_group_exit+0x48/0xc4)
[  130.336221]  r7:f5077edc
[  130.338777] [<c0038454>] (do_group_exit) from [<c0042214>] (get_signal+0x22c/0x5b0)
[  130.346465]  r7:f5077edc r6:00106001 r5:f5076000 r4:08430000
[  130.352190] [<c0041fe8>] (get_signal) from [<c0012928>] (do_signal+0xd0/0x3b4)
[  130.359441]  r10:00000000 r9:f5076000 r8:00000000 r7:00000000 r6:f5077ec8 r5:00000000
[  130.367351]  r4:f5077fb0
[  130.369911] [<c0012858>] (do_signal) from [<c0012dd4>] (do_work_pending+0xa8/0xc0)
[  130.377513]  r10:00000000 r9:f5076000 r8:00000000 r7:30c5387d r6:f5077fb0 r5:00000000
[  130.385427]  r4:f5076000
[  130.387986] [<c0012d2c>] (do_work_pending) from [<c000fb2c>] (slow_work_pending+0xc/0x20)
[  130.396198]  r7:30c5387d r6:ffffffff r5:200f0030 r4:b6fa7bfc
[  130.776852] ---[ end trace e4b171fa69554501 ]---
[  130.782006] ------------[ cut here ]------------
[  130.786654] WARNING: CPU: 0 PID: 728 at mm/page_alloc.c:6827 free_contig_range+0x98/0x9c()
[  130.816844] 2025 pages are still in use!
[  130.820788] Modules linked in: memcache(O) rpmsg_proto virtio_rpmsg_bus bc_example(O) extcon_usb_gpio ahci_platform pvrsrvkm(O) libahci_platform libahci libata c_can_platform c_can scsi_mod omap_aes_driver can_dev omap_sham dwc3_omap extcon rtc_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[  130.877037] CPU: 0 PID: 728 Comm: weston Tainted: G        W  O    4.4.84-00041-g84382ab #1
[  130.885428] Hardware name: Generic DRA74X (Flattened Device Tree)
[  130.891546] Backtrace:
[  130.894023] [<c00131d4>] (dump_backtrace) from [<c00133d0>] (show_stack+0x18/0x1c)
[  130.901628]  r7:c00d939c r6:600f0113 r5:00000000 r4:c0957810
[  130.907364] [<c00133b8>] (show_stack) from [<c02b21a8>] (dump_stack+0x8c/0xa0)
[  130.914622] [<c02b211c>] (dump_stack) from [<c0035340>] (warn_slowpath_common+0x88/0xb8)
[  130.922746]  r7:c00d939c r6:00001aab r5:00000009 r4:f5077bb8
[  130.928475] [<c00352b8>] (warn_slowpath_common) from [<c00353a8>] (warn_slowpath_fmt+0x38/0x40)
[  130.937213]  r8:c09b7880 r7:c093d5d0 r6:000bd1e9 r5:000007e9 r4:c082ca30
[  130.944002] [<c0035374>] (warn_slowpath_fmt) from [<c00d939c>] (free_contig_range+0x98/0x9c)
[  130.952475]  r3:000007e9 r2:c082ca30
[  130.956084]  r4:000bd1e9
[  130.958647] [<c00d9304>] (free_contig_range) from [<c011dd30>] (cma_release+0x90/0xb0)
[  130.966598]  r9:f2f9a000 r8:f626e410 r7:00000001 r6:f3820800 r5:c09b9470 r4:000bca00
[  130.974436] [<c011dca0>] (cma_release) from [<c03ecde0>] (dma_release_from_contiguous+0x38/0x40)
[  130.983258]  r5:00886800 r4:007e9000
[  130.986874] [<c03ecda8>] (dma_release_from_contiguous) from [<c001c8d8>] (__arm_dma_free+0x124/0x1fc)
[  130.996138] [<c001c7b4>] (__arm_dma_free) from [<c001c9f8>] (arm_dma_free+0x20/0x28)
[  131.003914]  r10:00000002 r9:c001c9d8 r8:bca00000 r7:f3820800 r6:007e9000 r5:f626e410
[  131.011829]  r4:f507f840
[  131.014388] [<c001c9d8>] (arm_dma_free) from [<c03ae8c4>] (v_gem_free_object+0x10c/0x144)
[  131.022606] [<c03ae7b8>] (v_gem_free_object) from [<c038e698>] (drm_gem_object_free+0x38/0x50)
[  131.031254]  r9:c038e974 r8:f5761000 r7:00000001 r6:f5892800 r5:f507f840 r4:f5892800
[  131.039089] [<c038e660>] (drm_gem_object_free) from [<c038e840>] (drm_gem_object_handle_unreference_unlocked+0xf0/0x124)
[  131.050006]  r5:f5892834 r4:f507f840
[  131.053619] [<c038e750>] (drm_gem_object_handle_unreference_unlocked) from [<c038e9cc>] (drm_gem_object_release_handle+0x58/0x70)
[  131.065320]  r5:f5761000 r4:f507f840
[  131.068935] [<c038e974>] (drm_gem_object_release_handle) from [<c02b2c68>] (idr_for_each+0xac/0xe0)
[  131.078019]  r7:00000001 r6:000000ff r5:f5077d28 r4:00000000
[  131.083749] [<c02b2bbc>] (idr_for_each) from [<c038f73c>] (drm_gem_release+0x24/0x30)
[  131.091610]  r10:f576107c r9:f5892834 r8:f58928f8 r7:f58928f4 r6:f5761080 r5:f5892800
[  131.099526]  r4:f5761020
[  131.102081] [<c038f718>] (drm_gem_release) from [<c038e490>] (drm_release+0x3f0/0x4b4)
[  131.110031]  r5:f5892800 r4:f5761000
[  131.113644] [<c038e0a0>] (drm_release) from [<c01220e4>] (__fput+0x88/0x1d0)
[  131.120723]  r10:f5761188 r9:00000008 r8:f5c445d8 r7:f542a110 r6:00000000 r5:f59c2f78
[  131.128637]  r4:f5761180
[  131.131191] [<c012205c>] (__fput) from [<c012228c>] (____fput+0x10/0x14)
[  131.137921]  r10:f57ab984 r9:f544bd40 r8:f50ec1fc r7:f5790000 r6:f507f300 r5:c098b81c
[  131.145834]  r4:f5790460
[  131.148392] [<c012227c>] (____fput) from [<c004e91c>] (task_work_run+0x98/0xcc)
[  131.155737] [<c004e884>] (task_work_run) from [<c0037d60>] (do_exit+0x300/0x9b8)
[  131.163165]  r7:f5077e40 r6:00000001 r5:f5790478 r4:f5790000
[  131.168890] [<c0037a60>] (do_exit) from [<c003849c>] (do_group_exit+0x48/0xc4)
[  131.176142]  r7:f5077edc
[  131.178698] [<c0038454>] (do_group_exit) from [<c0042214>] (get_signal+0x22c/0x5b0)
[  131.186388]  r7:f5077edc r6:00106001 r5:f5076000 r4:08430000
[  131.192117] [<c0041fe8>] (get_signal) from [<c0012928>] (do_signal+0xd0/0x3b4)
[  131.199369]  r10:00000000 r9:f5076000 r8:00000000 r7:00000000 r6:f5077ec8 r5:00000000
[  131.207282]  r4:f5077fb0
[  131.209843] [<c0012858>] (do_signal) from [<c0012dd4>] (do_work_pending+0xa8/0xc0)
[  131.217443]  r10:00000000 r9:f5076000 r8:00000000 r7:30c5387d r6:f5077fb0 r5:00000000
[  131.225356]  r4:f5076000
[  131.227915] [<c0012d2c>] (do_work_pending) from [<c000fb2c>] (slow_work_pending+0xc/0x20)
[  131.236127]  r7:30c5387d r6:ffffffff r5:200f0030 r4:b6fa7bfc
[  131.617067] ---[ end trace e4b171fa69554502 ]---
[  131.622222] ------------[ cut here ]------------
[  131.637184] WARNING: CPU: 0 PID: 728 at mm/page_alloc.c:6827 free_contig_range+0x98/0x9c()
[  131.645488] 2025 pages are still in use!
[  131.666964] Modules linked in: memcache(O) rpmsg_proto virtio_rpmsg_bus bc_example(O) extcon_usb_gpio ahci_platform pvrsrvkm(O) libahci_platform libahci libata c_can_platform c_can scsi_mod omap_aes_driver can_dev omap_sham dwc3_omap extcon rtc_omap omap_rng rng_core omap_des omap_remoteproc remoteproc virtio virtio_ring sch_fq_codel
[  131.727155] CPU: 0 PID: 728 Comm: weston Tainted: G        W  O    4.4.84-00041-g84382ab #1
[  131.735545] Hardware name: Generic DRA74X (Flattened Device Tree)
[  131.741662] Backtrace:
[  131.744146] [<c00131d4>] (dump_backtrace) from [<c00133d0>] (show_stack+0x18/0x1c)
[  131.751751]  r7:c00d939c r6:600f0113 r5:00000000 r4:c0957810
[  131.757487] [<c00133b8>] (show_stack) from [<c02b21a8>] (dump_stack+0x8c/0xa0)
[  131.764747] [<c02b211c>] (dump_stack) from [<c0035340>] (warn_slowpath_common+0x88/0xb8)
[  131.772869]  r7:c00d939c r6:00001aab r5:00000009 r4:f5077bb8
[  131.778598] [<c00352b8>] (warn_slowpath_common) from [<c00353a8>] (warn_slowpath_fmt+0x38/0x40)
[  131.787333]  r8:c09b7880 r7:c093d5d0 r6:000bd9e9 r5:000007e9 r4:c082ca30
[  131.794118] [<c0035374>] (warn_slowpath_fmt) from [<c00d939c>] (free_contig_range+0x98/0x9c)
[  131.802594]  r3:000007e9 r2:c082ca30
[  131.806205]  r4:000bd9e9
[  131.808768] [<c00d9304>] (free_contig_range) from [<c011dd30>] (cma_release+0x90/0xb0)
[  131.816719]  r9:f2f9a000 r8:f626e410 r7:00000001 r6:f3832800 r5:c09b9470 r4:000bd200
[  131.824562] [<c011dca0>] (cma_release) from [<c03ecde0>] (dma_release_from_contiguous+0x38/0x40)
[  131.833385]  r5:00898800 r4:007e9000
[  131.836999] [<c03ecda8>] (dma_release_from_contiguous) from [<c001c8d8>] (__arm_dma_free+0x124/0x1fc)
[  131.846260] [<c001c7b4>] (__arm_dma_free) from [<c001c9f8>] (arm_dma_free+0x20/0x28)
[  131.854034]  r10:00000003 r9:c001c9d8 r8:bd200000 r7:f3832800 r6:007e9000 r5:f626e410
[  131.861946]  r4:f507fc00
[  131.864508] [<c001c9d8>] (arm_dma_free) from [<c03ae8c4>] (v_gem_free_object+0x10c/0x144)
[  131.872727] [<c03ae7b8>] (v_gem_free_object) from [<c038e698>] (drm_gem_object_free+0x38/0x50)
[  131.881373]  r9:c038e974 r8:f5761000 r7:00000001 r6:f5892800 r5:f507fc00 r4:f5892800
[  131.889203] [<c038e660>] (drm_gem_object_free) from [<c038e840>] (drm_gem_object_handle_unreference_unlocked+0xf0/0x124)
[  131.900116]  r5:f5892834 r4:f507fc00
[  131.903730] [<c038e750>] (drm_gem_object_handle_unreference_unlocked) from [<c038e9cc>] (drm_gem_object_release_handle+0x58/0x70)
[  131.915431]  r5:f5761000 r4:f507fc00
[  131.919047] [<c038e974>] (drm_gem_object_release_handle) from [<c02b2c68>] (idr_for_each+0xac/0xe0)
[  131.928132]  r7:00000001 r6:000000ff r5:f5077d28 r4:00000000
[  131.933859] [<c02b2bbc>] (idr_for_each) from [<c038f73c>] (drm_gem_release+0x24/0x30)
[  131.941724]  r10:f576107c r9:f5892834 r8:f58928f8 r7:f58928f4 r6:f5761080 r5:f5892800
[  131.949638]  r4:f5761020
[  131.952194] [<c038f718>] (drm_gem_release) from [<c038e490>] (drm_release+0x3f0/0x4b4)
[  131.960144]  r5:f5892800 r4:f5761000
[  131.963757] [<c038e0a0>] (drm_release) from [<c01220e4>] (__fput+0x88/0x1d0)
[  131.970837]  r10:f5761188 r9:00000008 r8:f5c445d8 r7:f542a110 r6:00000000 r5:f59c2f78
[  131.978750]  r4:f5761180
[  131.981305] [<c012205c>] (__fput) from [<c012228c>] (____fput+0x10/0x14)
[  131.988035]  r10:f57ab984 r9:f544bd40 r8:f50ec1fc r7:f5790000 r6:f507f300 r5:c098b81c
[  131.995950]  r4:f5790460
[  131.998507] [<c012227c>] (____fput) from [<c004e91c>] (task_work_run+0x98/0xcc)
[  132.005850] [<c004e884>] (task_work_run) from [<c0037d60>] (do_exit+0x300/0x9b8)
[  132.013277]  r7:f5077e40 r6:00000001 r5:f5790478 r4:f5790000
[  132.019008] [<c0037a60>] (do_exit) from [<c003849c>] (do_group_exit+0x48/0xc4)
[  132.026263]  r7:f5077edc
[  132.028818] [<c0038454>] (do_group_exit) from [<c0042214>] (get_signal+0x22c/0x5b0)
[  132.036505]  r7:f5077edc r6:00106001 r5:f5076000 r4:08430000
[  132.042233] [<c0041fe8>] (get_signal) from [<c0012928>] (do_signal+0xd0/0x3b4)
[  132.049485]  r10:00000000 r9:f5076000 r8:00000000 r7:00000000 r6:f5077ec8 r5:00000000
[  132.057400]  r4:f5077fb0
[  132.059959] [<c0012858>] (do_signal) from [<c0012dd4>] (do_work_pending+0xa8/0xc0)
[  132.067561]  r10:00000000 r9:f5076000 r8:00000000 r7:30c5387d r6:f5077fb0 r5:00000000
[  132.075475]  r4:f5076000
[  132.078034] [<c0012d2c>] (do_work_pending) from [<c000fb2c>] (slow_work_pending+0xc/0x20)
[  132.086246]  r7:30c5387d r6:ffffffff r5:200f0030 r4:b6fa7bfc
[  132.456852] ---[ end trace e4b171fa69554503 ]---
[  132.610991] Process 906(false) has RLIMIT_CORE set to 1
[  132.616309] Aborting core
[  132.642915] Process 909(false) has RLIMIT_CORE set to 1
[  132.648454] Aborting core
[  133.028135] Alignment trap: not handling instruction e8141e0f at [<b6fba616>]
[  133.035311] Unhandled fault: alignment exception (0x221) at 0xfffffffb
[  133.041908] pgd = f45be140
[  133.044626] [fffffffb] *pgd=80000080007003, *pmd=b77a6003, *pte=00000000
[  133.052098] Alignment trap: not handling instruction e8141e0f at [<b6f97616>]
[  133.059300] Unhandled fault: alignment exception (0x221) at 0xfffffffb
[  133.065859] pgd = f45be040
[  133.068865] [fffffffb] *pgd=80000080007003, *pmd=b77a6003, *pte=00000000
[  133.075633] Process 918(false) has RLIMIT_CORE set to 1
[  133.080907] Aborting core
Renan
  • Hi
    This thread has been filed under wrong Part Number.We will need the new part number to assign the thread to a different group.
    Unfortunately our team can't update it.
    Can you please start a new thread with following Part Number
    MMWCAS-DSP-EVM
    Thank you
    Cesar
