AWR2243: When we use delta dither in adv chirp configuration to change Tx phase shifter, will the accumulated phase dither value module 360 degree to itself?
Part Number: AWR2243
Hi champion,
   My customer is using adv chirp configuration, and they want to use delta dither to change Tx phase shifter setting across chirps. In other words, they configure the Tx phase shifter steps across chirps as the SF0_CHIRP_PARAM_DELTA in AWR_ADVANCE_CHIRP_CONF_SB.
   The question is whether the accumulated phase in a chirp (profile phase + LUT phase + delta phase * chirpIdx)  module 360 degree to itself (if the accumulated value exceed 360 degree, it can round itself).
   Could you help to check?
Adam
