Hi Team,
We have received this inquiries from our customer.
Right now I design an instrument with PGA970 (and other parts so, but I'm okay with them)
I've found it's datasheet, everything is fine. I've also found the evaluation board's document, which was also useful
I'm curious about the pin description of the device. On the IC datasheet the example circuit is different than the one on the EV board. I've found details nowhere.
To mention an exact question how should I determine the values of R and C between the PI and PE pins. On the EV pdf they are simply omitted, although they are referred on the IC datasheet. I've quite the same question for lots of pins.
It's said in the EV pdf, that a serial resistance could be used to form a voltage resistive divider with the input impedance. How big is the input impedance?
What is the output impedance of the LVDT driver? How much load can it handle?
What are the power supply limits; how should I handle the GATE pin of the device?
What is the default configuration of the SPI interface with the factory software?
Can I rely on the factory fw, or I should place SWD to the board and upload a latest version in the manufacturing process?
It would be good to know the input requirements of the amplifiers. In some examples they are DC blocked, in some they does not. I cannot understand which is necessary.
How should the unused analog input handled?
Danilo
