Hi team,
My customer has project about parking spot detecting. Could you help recommend some sensor about 6m detecting range? Really appreciate.
Jasper
Hi team,
Jasper
Hi Alec,
I have guide my customer to TI parking garage demo. Thanks. And I want to ask are there any sensor products with a range of no more than 6 meters? Looking forward to your reply.
Jasper
Hi Jasper,
If a maximum range of 6meters is desired, the mmWave radar could be tuned for that range via the cfg file that is sent over during startup. Would this work for you customer's use case?
Alec
Hi Alec,
Thanks for your reply. Could you share some app note or other design material about tune range for mmWave? With these material, I will check with my customer for that solution.
Jasper
Hi Jasper,
There is quite a few components to radar tuning, so I will provide a few resources.
This doc provides background on the math and logic behind different chirp parameters.
https://www.ti.com/lit/an/swra553a/swra553a.pdf?ts=1646239413240
This guide provides documentation on what all the different parameters in the .cfg file represents, refer to section 3.4 "Configuration file format":
https://software-dl.ti.com/ra-processors/esd/MMWAVE-SDK/03_05_00_04/exports/mmwave_sdk_user_guide.pdf
This tool can be used to provide some assistance with calculating what impact the various parameters will have on different performance characteristics:
https://dev.ti.com/gallery/view/mmwave/mmWaveSensingEstimator/ver/1.4.0/
Alec
Hi Alec,
Really appreciate for your support. I will deliver these information to my customer. Thanks.
Jasper
