I have a similar problem to debug sbl. The ccs debug cannot load the source file and keep run when load program.
Understood. This question is a bit different than the one you linked to, which is regarding debugging the image loaded via SBL. Debugging the SBL should work the same as debugging other images. Can you confirm that you have followed the steps listed in the "Using CCS Debug" guide that is contained in the mmWave Industrial Toolbox? I will include a link below.
https://dev.ti.com/tirex/explore/node?a=VLyFKFf__4.10.1&node=AI6eWEtGLrdQkdspmXsHYA__VLyFKFf__4.10.1
Alec
