IWR6843AOP: Antenna Positions (Placement and Relative Spacing)
Part Number: IWR6843AOP
The IWR6843AOP sensor datasheet and EVMs data sheet has different labelling for TX and RX antenna - TX1 & TX2 are swapped, All RX are swapped
60GHz mmWave Sensor EVMs (SWRU546D – OCTOBER 2018 – REVISED DECEMBER 2020) on Page 51
IWR6843AOP Datasheet (SWRS237A – APRIL 2020 – REVISED APRIL 2021) on Page 35
Which one is correct labelling for TX and RX antenna? i.e. TX and RX antenna numbering
  • Hi Vithy,
    Thankyou for reaching out to us.
    Please give me some time to investigate on this and I shall get back to you with my insights on Monday.
    Ishita
  • Hello Vithy,
    The Antenna placement is correct in both figures, just the perspective is different.
    In the datasheet (SWRS237A – APRIL 2020 – REVISED APRIL 2021), Pin A1 is in the bottom right, whereas in the EVM user guide (SWRU546D – OCTOBER 2018 – REVISED DECEMBER 2020), it is the bottom left as pointed by the dot highlighted below :
    Hope this makes sense and brings more clarity.
    Ishita
