You state the antenna distance as 2.5 and 5mm, but as previously stated, this is NOT the exact lambda and "5" is only one value digit. Do you have the distance in micrometers, preferably with tolerance?
Hello Andreas,
Thankyou for reaching out to us and Welcome to TI E2E Forums.
Please give us some time to investigate this and we shall get back to you.
Ishita
So, how exact is it? What is the tolerance?
And why have you chosen to make the antenna spacing corresponding to 59.958GHz just below the band edge of the specified band?
Hi Andreas,
I do not have have the manufacturing tolerances but it should be centered around the numbers I shared with you.
Sami
Ok, then I know the center, that´s good, but I am sure you can find a number on the accuracy that you can share.
Hi Andreas,
It would be +/- 20 um at max, but should much lower.
Sami
