Other Parts Discussed in Thread: PGA450Q1EVM, PGA460, PGA460-Q1
Hi TI,
What is the Materials's(transformance & ultrasonic sensor) vendor PN use for demo board PGA450-Q1?Can you share the detailed bill of materials list for me?
Best regards
JQ
Hi TI,
Best regards
JQ
Hi JQ,
The below link has the BOM of the PGA450Q1EVM:
https://www.ti.com/lit/zip/slar135
In the BOM, you can find info on the transducer and transformer used in the EVM.
Instead of using the PGA450, however, I would recommend using the PGA460. The PGA460 has better performance, lower cost, and smaller size than the PGA450.
Mekre
Hi Mekre.
Both PGA460-Q1 OWI and PGA450-Q1 LIN connect to ECU ,all need add a transceiver .Can you tell me what is the Materials's(transceiver) vendor PN for PGA460-Q1 & PGA450-Q1?
Hi user6544457,
Here are the transducer and transformer used in the PGA450:
The below link has example transducers and transformers that can be used with the PGA460:
https://www.ti.com/lit/zip/slac787
For the PGA460’s OWI options, you will need a one-wire interface transceiver circuit to communicate to the microcontroller. This is the transceiver circuit we use in the BOOSTXL-PGA460 EVM.
Mekre
