AWR1843AOPEVM: Forum capteurs
Part Number: AWR1843AOPEVM
I'm actually working on a new project. I use the AWR1843AOPEVM card. I am setting up the radar on LRR, with a range of 150m and a speed of 150klm/h.
In fact my question regarding the extended max velocity command how can I use it to reach a speed of 2*Vmax?
how i can visualize extended max velocity in mmwave visualizer demo?
thank you
    You can install the sensor in an area where there is traffic with velocity V>Vmax.
    You will need to check the velocity detected by sensor (with GUI)
    First disable the velocity extension. You should not be able to detect velocity > Vmax.
    Second enable velocity extension. You should be able to see velocity detected > Vmax
    Thank you
    Cesar
