Other Parts Discussed in Thread: TUSS4470
Hi Team,
Good day! I checked the datasheet, yes, the OUT3 of TUSS4440 marked as input pin while TUSS4470 is output pin. but could you explain the difference? as showed in the datasheet. Isn't it that OUT3 should output signal, same as TUSS4470's, kindly please help to double check if there is a mistake in the datasheet and kindly confirm if our customer use the receive path only, could they replace each other as pin to pin compatible?
Thank you so much for your support.
Jonathan
