Other Parts Discussed in Thread: MSP-EXP430F5529LP, PGA460, TUSS4470
Good Day. Customer is working on Ultrasonic sensor and using your products for that PGA460-Q1 EVM and launch pad Part no: MSP-EXP430F5529LP. They need analog signal for their research and they have tried all the methods they could try.
After doing research on E2E, I found an answer. Please see below for your reference. Please help to check if this is right.
"You can output the signal that is fed to the internal ADC of the PGA460. This signal is output on the TEST pin of the PGA460 by selecting the “Analog Front End output” option for the TEST_MUX bits in the TEST_MUX register."
E2E Forum Post (Reference):
e2e.ti.com/.../pga460-q1-how-pga460-output-analog-waveforms
If this is right, Is it possible to tell us how to select the Analog front end option in the Text mux? Please advise. Thank you very much.
Ray Vincent
