AWR1843BOOST: How to obtain high density data from AWR1843BOOST
Part Number: AWR1843BOOST
Hi, We are currently using AWR1843BOOST and is facing the data sparsity problem. The link mentioned as the solution in the linked question (https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/929353/awr1843boost-is-it-possible-to-get-a-dense-cloud-point-by-using-awr1843boost)  doesn't seem to be available now. Can you kindly provide further leads on this?
    The idea behind increasing the point cloud is configuring the ROS GUI to accumulate and overlay detected points from several frames.
    This is a feature of the ROS GUI. More information can be found on the forums that support ROS.
    Here is where the ROS driver can be downloaded from:
    Please download the mmWave Industrial Toolbox. You will find information about the ros driver here.
    mmwave_industrial_toolbox_4_9_0__all\mmwave_industrial_toolbox_4_9_0\labs\robotics\ros_driver\docs
    Thank you
    Cesar
