Hello, I hve question about URAT communication interval for PGA460 integrated circuit.
uart speed is 115200 bps.
Now we are doing:
1. Initial parameter setting.
2. Then, make burst-listen, measurement, diag-check and diag-clear.
So, acutal command is
cmd 17 08 (burst and listen)
cmd 5 (measurement results)
cmd 9 4D (check 4Dh diag register)
cmd 10 4D00 (reset 4Dh diag to zero)
Then, loop those command.
The interval between command to comand is 1ms.
Here is logs example for one loop
[2022-07-07 17:46:50.901] => cmd 0 17 08
[2022-07-07 17:46:50.995] RET: OK
[2022-07-07 17:46:50.995] => cmd 0 5
[2022-07-07 17:46:51.089] RET: 40 0901AC81FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF 87
[2022-07-07 17:46:51.104] => cmd 0 9 4D
[2022-07-07 17:46:51.198] RET: 40 00 BF
[2022-07-07 17:46:51.198] => cmd 0 10 4D00
[2022-07-07 17:46:51.307] RET: OK
In case I makes some loop on this command, then response would stop. It looks like IC does not response timely
[2022-07-07 17:46:54.432] RET: 40 0870E5A4FFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFFF BC
[2022-07-07 17:46:54.447] => cmd 0 9 4D
[2022-07-07 17:46:54.588] RET: 40 00 BF
[2022-07-07 17:46:54.588] => cmdcmd 0 5
[2022-07-07 17:46:54.588] ERR: Unknown command
[2022-07-07 17:46:54.588] => cmd 0 04D00
[2022-07-07 17:46:54.588] ERR: Parameters contain non-numeric characters
[2022-07-07 17:46:54.588] => cmd 0 cmd 0 9 cmd 0 5
[2022-07-07 17:46:54.588] => cmdcmd 0 17 08
[2022-07-07 17:46:54.588] => cmcmd 0 9 4D
I know, if we added more longer internval time e.g. 200ms, then communication would be okay. But, we pursue the higest speed comnication.
my question is is any requirement (spec) of internal time between sending command. PLease advise .
Also, please advise where we need to check iniside the PGA460 spec about this interval time.
Rgs
Yoshifumi Yamaoka
