Other Parts Discussed in Thread: AWR1843BOOST
Hi, I am using AWR1843BOOST and DCA1000. Is it possible to find out the response curve of the antenna?
You will be able to measure the Rx Tx gain of the antenna as provided in the AWR1843BOOST EVM User Guide.
https://www.ti.com/lit/ug/spruim4b/spruim4b.pdf
Please see Section 2.7 Antenna
In order to measure at different angle you would need to be able to position the antenna at an accurate angle.
Thank you
Cesar
