Other Parts Discussed in Thread: TMS320F28035, TDC1000
Hello E2E Experts,
Good day.
The board that I am dealing with called TDC1000-C2000 has a lot of pins whose functionalities I do not know. The datasheet and other relative documents do not explain the functionalities as well. Can you please help?
So, I know that I have to use the J5 port to use the transducers but for all other pins, I have no clue. For example J1 port, TP (1-6), JP1, TP22, TP23 and TP15, and TP17.
Also, I am using the board to generate 1Mhz signals from one transducer and receive it through another and thus measuring the time taken by the signal to reach from one transducer to the other. So instead of detailing every pin/port that I mentioned, you can only explain the pins/ports I need to be using.
Thank you in advance.
CSC
