IWR1642BOOST: IWR1642BOOST
Part Number: IWR1642BOOST
Other Parts Discussed in Thread: MATHLIB,
**** Build of configuration Debug for project vitalSigns_16xx_mss ****
"C:\\ti\\ccs1210\\ccs\\utils\\bin\\gmake" -k -j 8 all -O
rm -f C:/Users/ozgur/workspace_v12/vitalSigns_16xx_mss/xwr16xx_vitalSignsDemo_mss.bin
makefile:186: recipe for target 'pre-build' failed
process_begin: CreateProcess(NULL, rm -f C:/Users/ozgur/workspace_v12/vitalSigns_16xx_mss/xwr16xx_vitalSignsDemo_mss.bin, ...) failed.
gmake[1]: [pre-build] Error 2 (ignored)
Building file: "../mss_mmw.cfg"
Invoking: XDCtools
"C:/ti/ccs1210/xdctools_3_62_01_16_core/xs" --xdcpath="C:/ti/bios_6_73_01_01/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/dsplib_c64Px_3_4_0_0/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.R4F_big_endian -p ti.platforms.cortexR:IWR16XX:false:200 -r release -c "C:/ti/ccs1210/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS" "../mss_mmw.cfg"
making package.mak (because of package.bld) ...
subdir_rules.mk:19: recipe for target 'build-730684609-inproc' failed
js: "./config.bld", line 10: Error: Can't find the target named 'ti.targets.arm.elf.R4F_big_endian' along the path 'C:/ti/bios_6_73_01_01/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/dsplib_c64Px_3_4_0_0/packages;C:/ti/ccs1210/xdctools_3_62_01_16_core/packages;..;': please check the spelling of the target's name and that it exists along this path.
gmake.exe: *** No rule to make target '.configuro'. Stop.
js: "C:/ti/ccs1210/xdctools_3_62_01_16_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
gmake[2]: *** [build-730684609-inproc] Error 1
gmake[1]: *** [build-730684609] Error 2
gmake[1]: Target 'main-build' not remade because of errors.
gmake: *** [all] Error 2
subdir_rules.mk:16: recipe for target 'build-730684609' failed
makefile:152: recipe for target 'all' failed
**** Build Finished ****
    Thank you for reaching out on the e2e forums. Please provide some context as to what lab this is, what device you are using and what you are trying to do.
    Thanks again,
    Angie
  • It is driver vital lab.
    I am using IWR1642BOOST evaluation board.
    I want to build a imported project which its name is   vitalSigns_16xx_mss
  • I am getting these errors when I build vitalSigns_16xx_mss  project.
    Invoking: XDCtools
    "C:/ti/xdctools_3_51_02_21_core/xs" --xdcpath="C:/ti/bios_6_73_01_01/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/dsplib_c64Px_3_4_0_0/packages;" xdc.tools.configuro -o configPkg -t ti.targets.arm.elf.R4F_big_endian -p ti.platforms.cortexR:IWR16XX:false:200 -r release -c "C:/ti/ccs1210/ccs/tools/compiler/ti-cgt-arm_20.2.7.LTS" "../mss_mmw.cfg"
    js: "./config.bld", line 10: Error: Can't find the target named 'ti.targets.arm.elf.R4F_big_endian' along the path 'C:/ti/bios_6_73_01_01/packages;C:/ti/dsplib_c674x_3_4_0_0/packages;C:/ti/mathlib_c674x_3_1_2_1/packages;C:/ti/dsplib_c64Px_3_4_0_0/packages;C:/ti/xdctools_3_51_02_21_core/packages;..;': please check the spelling of the target's name and that it exists along this path.
    xdctools_3_51_02_21_core\gmake.exe: *** No rule to make target '.configuro'. Stop.
    js: "C:/ti/xdctools_3_51_02_21_core/packages/xdc/tools/Cmdr.xs", line 52: Error: xdc.tools.configuro: configuration failed due to earlier errors (status = 2); 'linker.cmd' deleted.
    Can you please confirm if the pre -requisites in terms of the SDK version and compilers mentioned in the developers guide are taken into account?
    Sudharshan K N
  • Also this needs an older SDK which is not supported anymore. Can you please let us know which application you are trying to develop with this lab?
    Sudharshan K N
    I want to build a imported project which its name is   vitalSigns_16xx_mss.
    I am using older mmw SDK version 2
    Thanks for confirming. Please go ahead and mark the issue as closed.
    Sudharshan K N
