Hello Sir,
First of all, because I am an overseas user, this text uses a translation site.
Therefore, there may be mistranslations.
I appreciate your understanding in advance.
The other day, I recorded data with mmWave Demo Visualizer for the first time.
When playing back the recorded data, I have the following questions, so I would like you to answer them.
First, for data playback, after pressing the Plots tab on the mmWave Demo Visualizer, Press the PLAYBACK START button.
First of all, you will be prompted to select a (.cfg) file.
After specifying the CFG file, you will be prompted to select a (.dat) file.
As a playback operation procedure, select the CFG used for recording on the first screen.
Is the procedure for selecting the recorded DAT file correct on the next screen?
The purpose of this question is the other day, I was able to play it by selecting the recorded DAT file on the first screen and selecting the recorded DAT file on the next screen, so I would like to ask you about the original official playback method. It's up to you.
Also, I would like to ask separately, is there a function that can output the data (x, y, z, velocity, etc.) saved on the mmWave Demo Visualizer to a file (other than a DAT file, such as .csv)?
One last thing, is the mmWave Demo Visualizer equipped with functions such as forwarding and rewinding one frame during playback of recorded data?
Thanks for your support.
