Other Parts Discussed in Thread: AWR6843AOP
What is the weight of the AWR6843AOPEVM Rev G for:
- The entire sensor
- The mission board
- The radar block (antenna and receivers only)
- The heatsink
- The entire sensor
- The mission board
- The heatsink
Please allow us until after the weekend to respond to your query.
-Shareef
We dont really measure the weight of the EVMs, but I will try and get these for you. Please note that there is always slight variance between units. Just a few follow up questions:
1. When you say sensor, you are requesting for the weight of the AWR6843AOP device?
2. When asking for radar block, are you requesting the weight of the antenna patches in the AWR6843AOP device?
3. Are you requesting the weight of the external heatsink that usually goes on the device here?
-Shareef
1. Yes, the weight of the device as a whole (mission board + breakaway board), as well as just the mission board
2. Yes, everything contained in the black square on the front of the device
3. Yes, the weight of the heatsink normally found on the back of device
Approximate measurements are ok
We will check and let you know. However, the weight of heat sink(being the heaviest) is very variable and would be governed by the actual material you use.
