A few things to get started. There is the DCA1000 user guide on our Industrial Toolbox for mmWave Sensors which has more information (https://dev.ti.com/tirex/explore/node?a=VLyFKFf__4.12.0&node=A__AGTrhNYW8jE6cMxbovlfaA__com.ti.mmwave_industrial_toolbox__VLyFKFf__4.12.0). Do you have all the correct software drivers downloaded? This is mostly the FTDI and XDS drivers. Also, is your 5V power supply being used rated for 3A?
Pedrhom Nafisi
The drivers for FTDI and XDS have been downloaded and installed.The power supply is also 5V 3A. When connected to PC, port AR is not displayed and Ethernet port is not illuminated.
And the USB is plugged into the FTDI port of the DCA1000? With your setup I would try having the power supply connected to the DCA1000.
Pedrhom Nafisi
Last thing, so when you plug the DCA1000 in the computer, lights turn on correct? And in Device Manager, do you possibly see it show up as an “Unknown Device” or does Device Manager show no change after the DCA1000 is connected
Pedrhom Nafisi
Unknown devices are not displayed in the device manager.Only the 5V power light is on, and the rest are not. Can you send out a new product?
Contact customer support and point them to this thread or my name to vouch for you.
Pedrhom Nafisi
