IWR6843AOPEVM: Install ROS driver for Robotics Lab
Part Number: IWR6843AOPEVM
Will the ROS drivers for robotics lab work on Raspberry Pi 3 B?
    If you are able to install ROS Melodic on the Raspberry Pi 3 B, then you should be able to run the mmWave Sensor ROS Driver on it post installation. A quick google search shows that you should be able to do this. Make sure you install specifically ROS Melodic as that is the version needed to work with our driver.
    Pedrhom Nafisi
