Other Parts Discussed in Thread: AWR1843
What is Range-Profile's Relative Power?
(e.g. received power/transmitted power)
Please also tell me about the transmit antenna gain and receive antenna gain of AWR1843Boost.
(Also power half width)
Hi Hiroyuki-san,
You can find the info related to the RF specifications that you asked in the data sheet of AWR1843.
Thanks and regards,
Kaushik
I would appreciate it if you could let me know specifically which page and which document.
Hi Hiroyuki-san,
Please find the section 8.7 "RF Specifications" in following document
AWR1843 Single-Chip 77- to 79-GHz FMCW Radar Sensor datasheet (Rev. C) (ti.com)
Thanks & regards,
Kaushik
thank you for teaching me
I tried to check, but I'm not sure where it fits.
It would be helpful if you could give me a little more detail.
By the way, I would also like to know which items in the Visualizer correspond to which values in the datasheet.
Hi Hiroyuki-san,
Can you share a screenshot of the items in the visualizer (highlighted) that you have doubts regarding?
Thanks & regards,
Kaushik
OK, This is below.(Surrounded by blue circle)
Also I want to know range-Profile(Blue line in the figure.)
Hi Hiroyuki-san,
The demo visualizer gives the received power in dB scale (y-axis) for each of the frequency bins which can be observed in the range profile plot. The range profile has been obtained from the 1D FFT across the receiver samples for a given chirp. From this range profile (blue line), we can determine the range of the source of reflection.
Kaushik
