Other Parts Discussed in Thread: CC2650STK, HDC3022, HDC2022
Hi
I am using CC2650stk SensorTag. as part of my reaserch I am trying to use the sensor to measure relative humidity and temperature in the soil (for agricultural reaserch)
I desgined and printed a modular and (passivly) ventilated case to allow airflow through the sensor. It's hard to explain exactly what I did, so I attached a picture to make things more clear. the case placed inside the soil so the upper part protruding above the ground, the sensor itself isn't touching the soil (between the parts there is a grid that prevent it)
anyway, the sensor keeps showing 99.99 relative humidity, even when the soil is dry. To the best of my knowledge, there was not condensation on the sensor.
Do you know what may be cause for this issue? Is it necessary for a reliable measurement that there will be air movement around the sensor all the time?
I hope it's clear enough
Thanks in advance
Bnaya
