AWR1843AOPEVM: AWR1843AOPEVM + MMWICBOOST
Part Number: AWR1843AOPEVM
Other Parts Discussed in Thread: AWR1843BOOST, , MMWAVEICBOOST
I have purchased AWR184aopevm with MMWICBOOST. I have not find any document for  fast run and test of the modules together.
Is it true that all documents available for AWR1843BOOST can be used for AWR1843AOPEVM + MMWICBOOST?
for example can i use the MMwave out-of-box demo instructions for AWR1843BOOST  to start with  AWR1843AOPEVM + MMWICBOOST modules?
  • Hi Ali,
    There are a lot of documents that can be used as a common resource for AWR1843BOOST and AWR1843AOPEVM. However, the AWR1843AOPEVM comes with its own user guide and datasheet that you can find on its product page.
    You should be able to use the xwr18xx_mmw_aop_demo.bin from the latest SDK for a quick test run. The instructions regarding how to flash and run the demo will be same but the procedure and switch settings to use along with MMWAVEICBOOST can be found in their respective user guides.
    Kaushik
