I found that the following data is output for each frame via uart.
MMWDEMO_OUTPUT_MSG_DETECTED_POINTS
MMWDEMO_OUTPUT_MSG_RANGE_PROFILE
MMWDEMO_OUTPUT_MSG_NOISE_PROFILE
MMWDEMO_OUTPUT_MSG_AZIMUT_STATIC_HEAT_MAP
MMWDEMO_OUTPUT_MSG_RANGE_DOPPLER_HEAT_MAP
MMWDEMO_OUTPUT_MSG_STATS
MMWDEMO_OUTPUT_MSG_DETECTED_POINTS_SIDE_INFO
MMWDEMO_OUTPUT_MSG_AZIMUT_ELEVATION_STATIC_HEAT_MAP
MMWDEMO_OUTPUT_MSG_TEMPERATURE_STATS
MMWDEMO_OUTPUT_MSG_MAX
I have a question.
What data should I use to make it?
What kind of content does the data contain?
