Hi TI Teams,
Can u help to check the schematic of OPT3007 and give some suggestion for the design?
We also have some question about the input voltage ripple, the input voltage is 1.8V and the voltage ripple is 100mV.
Kind Regards
Hi TI Teams,
Kind Regards
Hi Lumina,
You will need pull up resistors on the SDA and SCL lines unless the controllers have internal pullups. The device should operate fine under this ripple.
Thank you,
Brent Elliott
Hi Brent,
Thanks a lot for your reply. We have designed the pull-up resistor on the complete terminal. Does the optical sensing module end also need such a design (pull up resistors on the SDA and SCL lines)?
Kind Regards
Hi Lumina,
There shouldn't be an issue as long as the SDA and SCL lines both have pull-up resistors on the complete circuit.
Thank you,
Brent Elliott
