AWR6843AOP: rebuild SOC driver error
Part Number: AWR6843AOP
Hi Expert,
https://e2e.ti.com/support/sensors-group/sensors/f/sensors-forum/832728/compiler-awr1642-awr1642-changing-tcmb-size/3130697
When MMWAVE_SDK_SHMEM_ALLOC set to 0x00010005, the rebuild SOC driver will have the following error
Could you give me some suggestions?
Daniel
  • Hello Daniel,
    Can you tell me why you are changing MMWAVE_SDK_SHMEM_ALLOC in the first place and what your goal is so I can provide better suggestions? Are you trying to increase the size of your memory zones such as PROG_RAM or DATA_RAM?
    Pedrhom Nafisi
  • Hi Expert,
    Because customer want to fix this issue:
    #10099-D: program will not fit into available memory.  run placement with alignment fails for section ".stack" size 0x800 .
    Available memory ranges:
       DATA_RAM     size: 0x30000      unused: 0x532        max hole: 0x530
    Daniel
    You can take some space away from PROG_RAM and add it to DATA_RAM in order. Below is an example of doing just that via the r4f_linker.cmd file. You can confirm memory space afterwards by looking at the Memory Allocation view post compilation.
    Pedrhom
