Hi Support Team.
I could not confirm the timing diagram of SCL and SDA with DS of TMP1075DGKR.
Could you please check the SCL and SDA timing diagrams for the TMP1075DGKR?
Yutaro,
Hi Support Team.
Yutaro,
Hi Hayashi-san,
Thank you for posting to the Sensing forum.
The TMP1075 timing diagrams can be found starting in Section 9.3.4 of the datasheet. For specific timing requirements, please refer to Section 8.7.
Nicole
Hi Nicole
Thank you for contacting us.
In the data sheet I obtained before, there was a description of the Timing Diagram below.
Since the new datasheet does not include the Timing Diagram above,
could you please confirm the diagram corresponding to the above Timing Diagram?
Yutaro,
Yes, that is the correct diagram. I am not sure why this figure is missing in the new revision. Thank you for bringing this to our attention, and I will work with our document team to get this corrected.
Nicole
