AWR2944: MSS_UARTB_RX failed
Part Number: AWR2944
Hi Team,
Have you tried using UARTB? In the uart_echo_callback routine, I changed the serial port setting to uartb through example.syscfg as shown in the picture below. It can be exported normally, but the imported data cannot be received.
Similar problems occurred before when I was using 1642 or 1843, the specifications indicate that UARTB RX is available, but in fact it is not workable. I would like to know if the same problem occurs with 2944.
Kind regards,
Katherine
