I'm encountering the following error in my application code, where can I look to find what the error codes correspond to?
Error: mmWave Config failed [Error code: -3108 Subsystem: 38]
Norman
Norman
Hello Norman,
You can refer to the base error number in the file C:\ti\mmwave_sdk_03_06_00_00-LTS\packages\ti\common\mmwave_error.h
As its -3108 code, so base would be -3100:
Then for the offset 8 you can refer to the document: C:\ti\mmwave_sdk_03_06_00_00-LTS\packages\ti\control\mmwave\mmwave.h
So, -3100-8 = -3108
Saswat Kumar
Hi Saswat,
Thanks for the reply. And what about the subsystem number 38 where can I find what that corresponds to?
-Norman
Hello Norman,
To find what this corresponds to you can refer the file: C:\ti\mmwave_sdk_03_06_00_00-LTS\packages\ti\control\mmwavelink\mmwavelink.h
Also, all this is mentioned in the demo information:
C:\ti\mmwave_sdk_03_06_00_00-LTS\packages\ti\demo\xwr16xx\mmw\mss\mss_main.c Line:559
Saswat Kumar
