AWR2243: DFE ADC ouput is nearly zero
Part Number: AWR2243
Hi TI experts,
     We are developing a board with AWR2243 chip with CSI2 HSI. We found ADC data in all nearly zero from remote CSI2 receiver.
  1. Use test pattern with AWR_DEV_TESTPATTERN_GEN_SET_SB, we can see desired ADC data, which proves the data path from ADC Buffer → eDMA → CBUFF → CSI2 is correct.
  2. We can see TX wave with instrument.
  3. Use mmwave_dfp_02_02_04_00\ti\example\mmWaveLink_SingleChip_Monitoring example code, we got clibrationReport and MonitoringReport.txt, from MonitoringReport, we found each RX mixer input voltage swing value (RX_MIXER_IN_VOLTAGE) is very small (most are 0~7mV) wheras it is around 56mV on AWR2243Boost board.
     Below are the monitoring reports and would you please help me out what might be wrong? Thanks in advanced!
  • CalibrationReport.txt
[2022-10-27 02:35:14] DeviceId [0] RFInitCalibStatus: 0x80001ffe, 0x1ffc, 42, 129
[2022-10-27 02:35:14] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x612, 43, 338
[2022-10-27 02:35:15] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 1378
[2022-10-27 02:35:17] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 2582
[2022-10-27 02:35:18] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 3776
[2022-10-27 02:35:19] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 4981
[2022-10-27 02:35:20] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 6175
[2022-10-27 02:35:21] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 7381
[2022-10-27 02:35:23] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 8580
[2022-10-27 02:35:24] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 9774
[2022-10-27 02:35:25] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 10978
[2022-10-27 02:35:26] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 12182
[2022-10-27 02:35:27] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 13377
[2022-10-27 02:35:29] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 14576
[2022-10-27 02:35:30] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 15781
[2022-10-27 02:35:31] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 16980
[2022-10-27 02:35:32] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 18175
[2022-10-27 02:35:33] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 19379
[2022-10-27 02:35:35] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 20573
[2022-10-27 02:35:36] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 21777
[2022-10-27 02:35:37] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 22982
[2022-10-27 02:35:38] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 24181
[2022-10-27 02:35:39] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 25381
[2022-10-27 02:35:41] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 26581
[2022-10-27 02:35:42] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 27778
[2022-10-27 02:35:43] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 28978
[2022-10-27 02:35:44] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 30179
[2022-10-27 02:35:15] DeviceId [0] MonitoringReportHeader: 0, 44
[2022-10-27 02:35:15] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 44, 44, 45, 44, 43, 44, 42, 0, 695
[2022-10-27 02:35:15] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 293, 288, 286, 293, 292, 288, 286, 289, 302, 295, 298, 298, 6886, 6906, 7276, 6514, 16336, 16320, 16580, 15974, 25204, 25408, 25846, 24776, 900524890, 865920858, 698
[2022-10-27 02:35:15] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 164, 165, 166, 157, 160, 168, 169, 144, 154, 154, 155, 699
[2022-10-27 02:35:15] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 20, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 700
[2022-10-27 02:35:15] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 718
[2022-10-27 02:35:15] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 718
[2022-10-27 02:35:15] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 719
[2022-10-27 02:35:15] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 719
[2022-10-27 02:35:15] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 719
[2022-10-27 02:35:15] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 719
[2022-10-27 02:35:15] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -90, -96, -196, -85, -90, -193, 46909, 46394, 44881, 34042, 33617, 32415, 21342, 21758, 21339, 740
[2022-10-27 02:35:15] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33814, 33806, 0, 0, -90, -90, 0, 0, 46, 46, 0, 0, 741
[2022-10-27 02:35:15] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33403, 33393, 0, 0, -96, -96, 0, 0, 47, 47, 0, 0, 741
[2022-10-27 02:35:15] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32634, 32614, 0, 0, -196, -196, 0, 0, 51, 50, 0, 0, 742
[2022-10-27 02:35:15] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 722
[2022-10-27 02:35:15] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 724
[2022-10-27 02:35:15] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 726
[2022-10-27 02:35:15] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 702
[2022-10-27 02:35:15] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 702
[2022-10-27 02:35:15] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 702
[2022-10-27 02:35:15] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 604, 1126, 223, 2214, 1262, 232, 4854, 0, 702
[2022-10-27 02:35:15] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 102, 0, 0, 0, 703
[2022-10-27 02:35:15] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 256, 742
[2022-10-27 02:35:15] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -671, 0, 2909, 0, 0, 0, 0, 700
[2022-10-27 02:35:16] DeviceId [0] MonitoringReportHeader: 1, 44
[2022-10-27 02:35:16] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 44, 43, 45, 42, 0, 1295
[2022-10-27 02:35:16] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 293, 289, 286, 289, 303, 295, 298, 298, 6382, 6426, 6768, 5996, 15900, 15860, 16154, 15556, 25818, 26010, 26482, 25408, 900557658, 865920858, 1298
[2022-10-27 02:35:16] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 159, 166, 167, 167, 154, 161, 167, 166, 144, 155, 153, 159, 1299
[2022-10-27 02:35:16] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 22, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 10, 9, 9, 9, 9, 9, 1300
[2022-10-27 02:35:16] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 1353
[2022-10-27 02:35:16] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 1353
[2022-10-27 02:35:16] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 1354
[2022-10-27 02:35:16] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 1354
[2022-10-27 02:35:16] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 1354
[2022-10-27 02:35:16] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 1354
[2022-10-27 02:35:16] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -96, -196, -86, -90, -193, 46776, 46829, 44608, 33465, 33771, 32485, 21809, 21491, 21684, 1375
[2022-10-27 02:35:16] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33667, 34692, 0, 0, -90, -91, 0, 0, 46, 47, 0, 0, 1376
[2022-10-27 02:35:16] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33747, 34712, 0, 0, -96, -96, 0, 0, 47, 46, 0, 0, 1376
[2022-10-27 02:35:16] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32796, 33808, 0, 0, -196, -196, 0, 0, 49, 48, 0, 0, 1377
[2022-10-27 02:35:16] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 1357
[2022-10-27 02:35:16] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 1359
[2022-10-27 02:35:16] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 1361
[2022-10-27 02:35:16] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 1302
[2022-10-27 02:35:16] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 1302
[2022-10-27 02:35:16] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 1302
[2022-10-27 02:35:16] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 604, 1126, 223, 2214, 1262, 232, 4854, 0, 1302
[2022-10-27 02:35:16] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 1303
[2022-10-27 02:35:16] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65537, 1377
[2022-10-27 02:35:16] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 570, 0, 254, 0, 0, 0, 0, 1300
[2022-10-27 02:35:17] DeviceId [0] MonitoringReportHeader: 2, 44
[2022-10-27 02:35:17] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 44, 44, 45, 45, 43, 45, 42, 0, 1895
[2022-10-27 02:35:17] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6310, 6356, 6700, 5922, 15834, 15792, 16088, 15494, 25908, 26106, 26580, 25504, 865921882, 865920826, 1898
[2022-10-27 02:35:17] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 154, 163, 163, 165, 159, 162, 166, 170, 145, 153, 153, 158, 1899
[2022-10-27 02:35:17] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 1900
[2022-10-27 02:35:17] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 1953
[2022-10-27 02:35:17] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 1953
[2022-10-27 02:35:17] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 1954
[2022-10-27 02:35:17] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 1954
[2022-10-27 02:35:17] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 1954
[2022-10-27 02:35:17] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 1954
[2022-10-27 02:35:17] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -93, -192, -90, -96, -196, -85, -90, -193, 46824, 46852, 44631, 33907, 33983, 33007, 20959, 21584, 21252, 1976
[2022-10-27 02:35:17] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33855, 35838, 0, 0, -90, -90, 0, 0, 47, 46, 0, 0, 1976
[2022-10-27 02:35:17] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33836, 35804, 0, 0, -96, -96, 0, 0, 46, 45, 0, 0, 1976
[2022-10-27 02:35:17] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32823, 34869, 0, 0, -196, -196, 0, 0, 48, 48, 0, 0, 1977
[2022-10-27 02:35:17] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 1957
[2022-10-27 02:35:17] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 1959
[2022-10-27 02:35:17] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 1961
[2022-10-27 02:35:17] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 1902
[2022-10-27 02:35:17] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 1902
[2022-10-27 02:35:17] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 1902
[2022-10-27 02:35:17] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 1902
[2022-10-27 02:35:17] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 1000, 100, 101, 0, 0, 0, 1903
[2022-10-27 02:35:17] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 1977
[2022-10-27 02:35:17] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -585, 0, 1645, 0, 0, 0, 0, 1900
[2022-10-27 02:35:17] DeviceId [0] MonitoringReportHeader: 3, 44
[2022-10-27 02:35:17] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 2495
[2022-10-27 02:35:17] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6302, 6350, 6690, 5918, 15824, 15782, 16078, 15484, 25924, 26126, 26598, 25520, 900524889, 865920858, 2498
[2022-10-27 02:35:17] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 164, 170, 164, 157, 162, 169, 169, 146, 156, 153, 159, 2499
[2022-10-27 02:35:17] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 20, 21, 22, 20, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 2500
[2022-10-27 02:35:17] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 2557
[2022-10-27 02:35:17] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 2558
[2022-10-27 02:35:17] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 2558
[2022-10-27 02:35:17] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 2558
[2022-10-27 02:35:17] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 2559
[2022-10-27 02:35:17] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 2559
[2022-10-27 02:35:17] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -90, -193, 47332, 46595, 44510, 33854, 33950, 32986, 20966, 21588, 21721, 2580
[2022-10-27 02:35:17] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33632, 36554, 0, 0, -91, -91, 0, 0, 46, 47, 0, 0, 2580
[2022-10-27 02:35:17] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33302, 36266, 0, 0, -96, -97, 0, 0, 45, 46, 0, 0, 2581
[2022-10-27 02:35:17] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32580, 35552, 0, 0, -196, -196, 0, 0, 51, 51, 0, 0, 2581
[2022-10-27 02:35:17] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 2561
[2022-10-27 02:35:17] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 2563
[2022-10-27 02:35:17] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 2566
[2022-10-27 02:35:17] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 2502
[2022-10-27 02:35:17] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 2502
[2022-10-27 02:35:17] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 2502
[2022-10-27 02:35:17] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 2502
[2022-10-27 02:35:17] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5998, 1999, 1000, 100, 101, 0, 0, 0, 2503
[2022-10-27 02:35:17] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 2582
[2022-10-27 02:35:17] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -531, 0, 2908, 0, 0, 0, 0, 2500
[2022-10-27 02:35:18] DeviceId [0] MonitoringReportHeader: 4, 44
[2022-10-27 02:35:18] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 3095
[2022-10-27 02:35:18] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6756, 6798, 7154, 6382, 16226, 16206, 16470, 15870, 25372, 25574, 26020, 24950, 900524890, 865920858, 3098
[2022-10-27 02:35:18] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 159, 166, 168, 164, 154, 168, 166, 170, 143, 153, 156, 157, 3099
[2022-10-27 02:35:18] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 10, 9, 9, 9, 9, 3100
[2022-10-27 02:35:18] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 3157
[2022-10-27 02:35:18] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 3158
[2022-10-27 02:35:18] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 3158
[2022-10-27 02:35:18] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 3159
[2022-10-27 02:35:18] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -103, 3159
[2022-10-27 02:35:18] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 3159
[2022-10-27 02:35:18] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -96, -196, -85, -90, -194, 46500, 46193, 44788, 33545, 33365, 32709, 21662, 21924, 21883, 3180
[2022-10-27 02:35:18] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33110, 37017, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 3181
[2022-10-27 02:35:18] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33057, 37017, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 3181
[2022-10-27 02:35:18] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32023, 35991, 0, 0, -196, -196, 0, 0, 50, 50, 0, 0, 3182
[2022-10-27 02:35:18] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 3161
[2022-10-27 02:35:18] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 3164
[2022-10-27 02:35:18] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 3166
[2022-10-27 02:35:18] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 3102
[2022-10-27 02:35:18] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 3102
[2022-10-27 02:35:18] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 3102
[2022-10-27 02:35:18] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 233, 4854, 0, 3102
[2022-10-27 02:35:18] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 3103
[2022-10-27 02:35:18] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 3182
[2022-10-27 02:35:18] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -601, 0, 2865, 0, 0, 0, 0, 3100
[2022-10-27 02:35:18] DeviceId [0] MonitoringReportHeader: 5, 44
[2022-10-27 02:35:18] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 44, 43, 45, 42, 0, 3695
[2022-10-27 02:35:18] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6628, 6672, 7024, 6252, 16114, 16088, 16364, 15766, 25532, 25730, 26188, 25112, 900524890, 865920858, 3698
[2022-10-27 02:35:18] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 167, 168, 164, 158, 161, 165, 167, 143, 158, 150, 155, 3699
[2022-10-27 02:35:18] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 20, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 5, 250, 9, 9, 9, 9, 9, 9, 3700
[2022-10-27 02:35:18] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 133, 134, 3752
[2022-10-27 02:35:18] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 3753
[2022-10-27 02:35:18] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 133, 3753
[2022-10-27 02:35:18] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 3753
[2022-10-27 02:35:18] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -98, 3754
[2022-10-27 02:35:18] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 3754
[2022-10-27 02:35:18] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -96, -196, -85, -90, -193, 46597, 46238, 44343, 33780, 33917, 32976, 21499, 21334, 21601, 3774
[2022-10-27 02:35:18] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33686, 38610, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 3774
[2022-10-27 02:35:18] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33322, 38268, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 3775
[2022-10-27 02:35:18] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32589, 37535, 0, 0, -196, -196, 0, 0, 51, 50, 0, 0, 3775
[2022-10-27 02:35:18] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 3756
[2022-10-27 02:35:18] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 3758
[2022-10-27 02:35:18] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 3761
[2022-10-27 02:35:18] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 3702
[2022-10-27 02:35:18] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 3702
[2022-10-27 02:35:18] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 3702
[2022-10-27 02:35:18] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 223, 2214, 1263, 232, 4849, 0, 3702
[2022-10-27 02:35:18] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 3703
[2022-10-27 02:35:18] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 3776
[2022-10-27 02:35:18] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -632, 0, 2909, 0, 0, 0, 0, 3700
[2022-10-27 02:35:19] DeviceId [0] MonitoringReportHeader: 6, 44
[2022-10-27 02:35:19] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 4295
[2022-10-27 02:35:19] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 293, 292, 288, 286, 289, 302, 295, 298, 298, 6748, 6788, 7144, 6372, 16220, 16198, 16466, 15862, 25384, 25586, 26036, 24958, 900557658, 865920858, 4298
[2022-10-27 02:35:19] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 154, 165, 167, 166, 151, 165, 168, 166, 148, 156, 151, 156, 4299
[2022-10-27 02:35:19] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 22, 20, 20, 8, 8, 9, 13, 11, 9, 7, 5, 250, 9, 9, 9, 9, 9, 9, 4300
[2022-10-27 02:35:19] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 4352
[2022-10-27 02:35:19] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 4352
[2022-10-27 02:35:19] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 4353
[2022-10-27 02:35:19] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 4353
[2022-10-27 02:35:19] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 4353
[2022-10-27 02:35:19] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 4353
[2022-10-27 02:35:19] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -90, -96, -196, -85, -90, -193, 46502, 46187, 44778, 33988, 34019, 32603, 21201, 21694, 21303, 4375
[2022-10-27 02:35:19] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33824, 39738, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 4375
[2022-10-27 02:35:19] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33820, 39721, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 4375
[2022-10-27 02:35:19] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32408, 38339, 0, 0, -196, -196, 0, 0, 52, 52, 0, 0, 4376
[2022-10-27 02:35:19] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 4356
[2022-10-27 02:35:19] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 4358
[2022-10-27 02:35:19] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 4360
[2022-10-27 02:35:19] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 4302
[2022-10-27 02:35:19] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 4302
[2022-10-27 02:35:19] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 4302
[2022-10-27 02:35:19] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 232, 4854, 0, 4302
[2022-10-27 02:35:19] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 101, 0, 0, 0, 4303
[2022-10-27 02:35:19] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 16777217, 4376
[2022-10-27 02:35:19] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -640, 0, 1575, 0, 0, 0, 0, 4300
[2022-10-27 02:35:20] DeviceId [0] MonitoringReportHeader: 7, 44
[2022-10-27 02:35:20] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 44, 43, 45, 42, 0, 4895
[2022-10-27 02:35:20] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6478, 6520, 6860, 6096, 15988, 15952, 16238, 15640, 25718, 25916, 26380, 25308, 900524889, 866969434, 4898
[2022-10-27 02:35:20] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 164, 168, 165, 158, 161, 168, 171, 145, 158, 153, 156, 4899
[2022-10-27 02:35:20] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 20, 20, 20, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 10, 9, 9, 9, 9, 4900
[2022-10-27 02:35:20] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 4956
[2022-10-27 02:35:20] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 4956
[2022-10-27 02:35:20] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 4957
[2022-10-27 02:35:20] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 4957
[2022-10-27 02:35:20] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 4957
[2022-10-27 02:35:20] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 4958
[2022-10-27 02:35:20] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -91, -193, 46706, 46783, 45063, 34115, 33653, 32831, 21576, 21885, 21394, 4979
[2022-10-27 02:35:20] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33334, 40212, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 4979
[2022-10-27 02:35:20] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33153, 40076, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 4980
[2022-10-27 02:35:20] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32511, 39444, 0, 0, -196, -196, 0, 0, 52, 51, 0, 0, 4980
[2022-10-27 02:35:20] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 4960
[2022-10-27 02:35:20] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 4962
[2022-10-27 02:35:20] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 4964
[2022-10-27 02:35:20] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 4902
[2022-10-27 02:35:20] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 4902
[2022-10-27 02:35:20] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 4902
[2022-10-27 02:35:20] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 4902
[2022-10-27 02:35:20] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 1000, 100, 101, 0, 0, 0, 4903
[2022-10-27 02:35:20] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 4981
[2022-10-27 02:35:20] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -703, 0, 1635, 0, 0, 0, 0, 4900
[2022-10-27 02:35:20] DeviceId [0] MonitoringReportHeader: 8, 44
[2022-10-27 02:35:20] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 44, 43, 45, 42, 0, 5495
[2022-10-27 02:35:20] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6782, 6820, 7176, 6414, 16250, 16226, 16496, 15890, 25346, 25546, 25998, 24924, 900557658, 865920826, 5498
[2022-10-27 02:35:20] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 165, 173, 166, 153, 159, 167, 167, 146, 156, 153, 156, 5499
[2022-10-27 02:35:20] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 9, 9, 9, 9, 9, 5500
[2022-10-27 02:35:20] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 5556
[2022-10-27 02:35:20] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 5556
[2022-10-27 02:35:20] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 5557
[2022-10-27 02:35:20] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 5557
[2022-10-27 02:35:20] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 5557
[2022-10-27 02:35:20] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 5558
[2022-10-27 02:35:20] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -96, -196, -85, -90, -193, 46487, 46668, 44544, 33427, 33742, 32884, 21537, 21357, 21160, 5579
[2022-10-27 02:35:20] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33902, 41790, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 5579
[2022-10-27 02:35:20] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33860, 41777, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 5580
[2022-10-27 02:35:20] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32830, 40770, 0, 0, -196, -196, 0, 0, 47, 47, 0, 0, 5580
[2022-10-27 02:35:20] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 5560
[2022-10-27 02:35:20] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 5562
[2022-10-27 02:35:20] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 5564
[2022-10-27 02:35:20] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 5502
[2022-10-27 02:35:20] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 5502
[2022-10-27 02:35:20] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 5502
[2022-10-27 02:35:20] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 5502
[2022-10-27 02:35:20] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 101, 0, 0, 0, 5503
[2022-10-27 02:35:20] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 5581
[2022-10-27 02:35:20] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -804, 0, 1636, 0, 0, 0, 0, 5500
[2022-10-27 02:35:21] DeviceId [0] MonitoringReportHeader: 9, 44
[2022-10-27 02:35:21] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 6095
[2022-10-27 02:35:21] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6298, 6354, 6690, 5912, 15822, 15780, 16076, 15484, 25940, 26138, 26612, 25540, 900557658, 865920858, 6098
[2022-10-27 02:35:21] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 165, 170, 164, 156, 161, 166, 167, 146, 153, 153, 154, 6099
[2022-10-27 02:35:21] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 9, 9, 9, 9, 9, 6100
[2022-10-27 02:35:21] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 6150
[2022-10-27 02:35:21] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 6151
[2022-10-27 02:35:21] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 6151
[2022-10-27 02:35:21] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 6152
[2022-10-27 02:35:21] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 6152
[2022-10-27 02:35:21] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 6152
[2022-10-27 02:35:21] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 47322, 47087, 45194, 33728, 33889, 32541, 21249, 21724, 21315, 6173
[2022-10-27 02:35:21] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33376, 42245, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 6174
[2022-10-27 02:35:21] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33606, 42504, 0, 0, -96, -97, 0, 0, 47, 47, 0, 0, 6174
[2022-10-27 02:35:21] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32705, 41643, 0, 0, -196, -196, 0, 0, 50, 49, 0, 0, 6175
[2022-10-27 02:35:21] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 6154
[2022-10-27 02:35:21] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 6157
[2022-10-27 02:35:21] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 6159
[2022-10-27 02:35:21] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 6102
[2022-10-27 02:35:21] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 6102
[2022-10-27 02:35:21] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 256, 685, 6102
[2022-10-27 02:35:21] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 232, 4854, 0, 6102
[2022-10-27 02:35:21] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 6103
[2022-10-27 02:35:21] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 50397184, 6175
[2022-10-27 02:35:21] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -718, 0, 4314, 0, 0, 0, 0, 6100
[2022-10-27 02:35:21] DeviceId [0] MonitoringReportHeader: 10, 44
[2022-10-27 02:35:21] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 6695
[2022-10-27 02:35:21] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6348, 6396, 6734, 5960, 15870, 15834, 16122, 15528, 25876, 26070, 26538, 25468, 900524890, 865920858, 6698
[2022-10-27 02:35:21] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 166, 169, 165, 153, 164, 171, 169, 147, 155, 151, 157, 6699
[2022-10-27 02:35:21] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 20, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 10, 9, 9, 9, 10, 9, 6700
[2022-10-27 02:35:21] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 6750
[2022-10-27 02:35:21] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 6751
[2022-10-27 02:35:21] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 6752
[2022-10-27 02:35:21] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 6752
[2022-10-27 02:35:21] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 6752
[2022-10-27 02:35:21] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 6752
[2022-10-27 02:35:21] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -90, -96, -196, -85, -90, -193, 47289, 46567, 44964, 34067, 33620, 32816, 21061, 21111, 21055, 6773
[2022-10-27 02:35:21] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33498, 43378, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 6774
[2022-10-27 02:35:21] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33662, 43596, 0, 0, -96, -97, 0, 0, 47, 48, 0, 0, 6774
[2022-10-27 02:35:21] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32737, 42679, 0, 0, -196, -196, 0, 0, 48, 48, 0, 0, 6775
[2022-10-27 02:35:21] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 6754
[2022-10-27 02:35:21] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 6757
[2022-10-27 02:35:21] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 6759
[2022-10-27 02:35:21] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 6702
[2022-10-27 02:35:21] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 6702
[2022-10-27 02:35:21] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 6702
[2022-10-27 02:35:21] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 232, 4854, 0, 6702
[2022-10-27 02:35:21] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 6703
[2022-10-27 02:35:21] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 6775
[2022-10-27 02:35:21] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 617, 0, 1675, 0, 0, 0, 0, 6700
[2022-10-27 02:35:22] DeviceId [0] MonitoringReportHeader: 11, 44
[2022-10-27 02:35:22] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 45, 45, 45, 43, 45, 42, 0, 7295
[2022-10-27 02:35:22] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6344, 6386, 6728, 5956, 15858, 15820, 16110, 15520, 25886, 26080, 26556, 25480, 900557658, 867002170, 7298
[2022-10-27 02:35:22] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 167, 168, 163, 159, 161, 165, 170, 143, 153, 154, 157, 7299
[2022-10-27 02:35:22] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 20, 21, 20, 21, 22, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 7300
[2022-10-27 02:35:22] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 135, 7356
[2022-10-27 02:35:22] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 7356
[2022-10-27 02:35:22] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 7357
[2022-10-27 02:35:22] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 7357
[2022-10-27 02:35:22] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 7357
[2022-10-27 02:35:22] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 7357
[2022-10-27 02:35:22] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -90, -96, -196, -85, -90, -193, 47289, 46568, 44965, 34067, 34051, 32612, 21193, 21176, 21082, 7379
[2022-10-27 02:35:22] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33484, 44393, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 7379
[2022-10-27 02:35:22] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33213, 44174, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 7380
[2022-10-27 02:35:22] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32543, 43501, 0, 0, -196, -197, 0, 0, 51, 52, 0, 0, 7380
[2022-10-27 02:35:22] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 7360
[2022-10-27 02:35:22] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 7362
[2022-10-27 02:35:22] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 7364
[2022-10-27 02:35:22] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 7302
[2022-10-27 02:35:22] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 7302
[2022-10-27 02:35:22] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 7302
[2022-10-27 02:35:22] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 7302
[2022-10-27 02:35:22] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 7303
[2022-10-27 02:35:22] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 7381
[2022-10-27 02:35:22] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -718, 0, 1551, 0, 0, 0, 0, 7300
[2022-10-27 02:35:23] DeviceId [0] MonitoringReportHeader: 12, 44
[2022-10-27 02:35:23] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 44, 43, 45, 42, 0, 7895
[2022-10-27 02:35:23] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6434, 6478, 6816, 6048, 15944, 15906, 16196, 15600, 25782, 25982, 26450, 25378, 899476314, 865920826, 7898
[2022-10-27 02:35:23] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 156, 163, 172, 164, 156, 163, 168, 168, 147, 155, 155, 155, 7899
[2022-10-27 02:35:23] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 10, 9, 7900
[2022-10-27 02:35:23] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 135, 7950
[2022-10-27 02:35:23] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 7950
[2022-10-27 02:35:23] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 7951
[2022-10-27 02:35:23] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 7951
[2022-10-27 02:35:23] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -102, 7951
[2022-10-27 02:35:23] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 7951
[2022-10-27 02:35:23] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -97, -196, -86, -91, -193, 47226, 46537, 44457, 33387, 33285, 32241, 21936, 22051, 21456, 7972
[2022-10-27 02:35:23] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33292, 45216, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 7973
[2022-10-27 02:35:23] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33572, 45556, 0, 0, -96, -97, 0, 0, 46, 47, 0, 0, 7973
[2022-10-27 02:35:23] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32286, 44302, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 7974
[2022-10-27 02:35:23] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 7954
[2022-10-27 02:35:23] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 7956
[2022-10-27 02:35:23] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 7958
[2022-10-27 02:35:23] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 7902
[2022-10-27 02:35:23] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 7902
[2022-10-27 02:35:23] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 7902
[2022-10-27 02:35:23] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 7902
[2022-10-27 02:35:23] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 7903
[2022-10-27 02:35:23] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 7974
[2022-10-27 02:35:23] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -664, 0, 240, 0, 0, 0, 0, 7900
[2022-10-27 02:35:23] DeviceId [0] MonitoringReportHeader: 13, 44
[2022-10-27 02:35:23] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 45, 43, 45, 42, 0, 8495
[2022-10-27 02:35:23] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6526, 6566, 6910, 6146, 16026, 15998, 16282, 15684, 25664, 25858, 26330, 25254, 900557658, 865920858, 8498
[2022-10-27 02:35:23] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 166, 170, 165, 159, 166, 169, 170, 143, 154, 154, 158, 8499
[2022-10-27 02:35:23] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 6, 250, 10, 10, 9, 9, 9, 9, 8500
[2022-10-27 02:35:23] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 133, 8555
[2022-10-27 02:35:23] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 134, 136, 8555
[2022-10-27 02:35:23] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 8556
[2022-10-27 02:35:23] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 8556
[2022-10-27 02:35:23] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 8556
[2022-10-27 02:35:23] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 8557
[2022-10-27 02:35:23] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 47173, 47011, 44710, 33495, 33775, 32891, 21534, 21346, 21154, 8578
[2022-10-27 02:35:23] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33456, 46418, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 8578
[2022-10-27 02:35:23] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33644, 46638, 0, 0, -96, -97, 0, 0, 47, 47, 0, 0, 8579
[2022-10-27 02:35:23] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32320, 45348, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 8579
[2022-10-27 02:35:23] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 8559
[2022-10-27 02:35:23] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 8561
[2022-10-27 02:35:23] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 8563
[2022-10-27 02:35:23] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 8502
[2022-10-27 02:35:23] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 8502
[2022-10-27 02:35:23] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 8502
[2022-10-27 02:35:23] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 8502
[2022-10-27 02:35:23] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 999, 100, 101, 0, 0, 0, 8503
[2022-10-27 02:35:23] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 8580
[2022-10-27 02:35:23] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 593, 0, 4310, 0, 0, 0, 0, 8500
[2022-10-27 02:35:24] DeviceId [0] MonitoringReportHeader: 14, 44
[2022-10-27 02:35:24] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 9095
[2022-10-27 02:35:24] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6518, 6558, 6898, 6134, 16018, 15986, 16270, 15672, 25680, 25876, 26344, 25266, 900524890, 867002202, 9098
[2022-10-27 02:35:24] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 163, 168, 165, 157, 164, 169, 168, 145, 155, 153, 159, 9099
[2022-10-27 02:35:24] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 21, 22, 21, 21, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 9, 9, 9, 9, 9, 9100
[2022-10-27 02:35:24] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 9154
[2022-10-27 02:35:24] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 138, 135, 136, 9155
[2022-10-27 02:35:24] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 9155
[2022-10-27 02:35:24] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 9155
[2022-10-27 02:35:24] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 9156
[2022-10-27 02:35:24] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 9156
[2022-10-27 02:35:24] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -93, -192, -91, -96, -196, -85, -90, -193, 46672, 46758, 44594, 33877, 33963, 32560, 21208, 21191, 21087, 9177
[2022-10-27 02:35:24] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33485, 47477, 0, 0, -91, -92, 0, 0, 47, 47, 0, 0, 9177
[2022-10-27 02:35:24] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33213, 47270, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 9178
[2022-10-27 02:35:24] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32549, 46631, 0, 0, -196, -197, 0, 0, 51, 50, 0, 0, 9178
[2022-10-27 02:35:24] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 9158
[2022-10-27 02:35:24] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 9160
[2022-10-27 02:35:24] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 9163
[2022-10-27 02:35:24] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 9102
[2022-10-27 02:35:24] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 9102
[2022-10-27 02:35:24] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 9102
[2022-10-27 02:35:24] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 9102
[2022-10-27 02:35:24] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 1000, 100, 101, 0, 0, 0, 9103
[2022-10-27 02:35:24] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 256, 9179
[2022-10-27 02:35:24] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -507, 0, 5248, 0, 0, 0, 0, 9100
[2022-10-27 02:35:24] DeviceId [0] MonitoringReportHeader: 15, 44
[2022-10-27 02:35:24] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 46, 45, 43, 45, 42, 0, 9695
[2022-10-27 02:35:24] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6428, 6472, 6814, 6048, 15944, 15910, 16198, 15600, 25784, 25984, 26452, 25378, 900524889, 865920858, 9698
[2022-10-27 02:35:24] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 165, 169, 167, 152, 166, 166, 167, 143, 157, 155, 156, 9699
[2022-10-27 02:35:24] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 21, 20, 8, 8, 9, 12, 11, 9, 7, 5, 250, 9, 9, 9, 9, 9, 9, 9700
[2022-10-27 02:35:24] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 9749
[2022-10-27 02:35:24] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 9749
[2022-10-27 02:35:24] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 9750
[2022-10-27 02:35:24] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 9750
[2022-10-27 02:35:24] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 9750
[2022-10-27 02:35:24] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 9751
[2022-10-27 02:35:24] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -91, -193, 47223, 47040, 44725, 33506, 33777, 32874, 21534, 21852, 21369, 9772
[2022-10-27 02:35:24] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33342, 48402, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 9772
[2022-10-27 02:35:24] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33583, 48668, 0, 0, -96, -98, 0, 0, 47, 46, 0, 0, 9773
[2022-10-27 02:35:24] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32286, 47375, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 9773
[2022-10-27 02:35:24] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 9753
[2022-10-27 02:35:24] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 9755
[2022-10-27 02:35:24] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 9757
[2022-10-27 02:35:24] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 9702
[2022-10-27 02:35:24] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 9702
[2022-10-27 02:35:24] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 9702
[2022-10-27 02:35:24] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 233, 4854, 0, 9702
[2022-10-27 02:35:24] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 9703
[2022-10-27 02:35:24] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 9774
[2022-10-27 02:35:24] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -414, 0, 4216, 0, 0, 0, 0, 9700
[2022-10-27 02:35:25] DeviceId [0] MonitoringReportHeader: 16, 44
[2022-10-27 02:35:25] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 10295
[2022-10-27 02:35:25] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 298, 298, 6874, 6894, 7260, 6496, 16326, 16310, 16572, 15966, 25246, 25448, 25888, 24816, 900524857, 865953626, 10298
[2022-10-27 02:35:25] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 164, 169, 165, 160, 166, 166, 165, 144, 157, 153, 160, 10299
[2022-10-27 02:35:25] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 20, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 10, 9, 9, 9, 9, 9, 10300
[2022-10-27 02:35:25] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 10349
[2022-10-27 02:35:25] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 138, 135, 136, 10349
[2022-10-27 02:35:25] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 10350
[2022-10-27 02:35:25] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 10350
[2022-10-27 02:35:25] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 10350
[2022-10-27 02:35:25] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 10350
[2022-10-27 02:35:25] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -97, -196, -85, -90, -193, 46912, 46373, 44411, 33792, 33919, 32960, 20955, 21573, 21689, 10371
[2022-10-27 02:35:25] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33169, 49191, 0, 0, -91, -92, 0, 0, 46, 47, 0, 0, 10372
[2022-10-27 02:35:25] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33062, 49257, 0, 0, -97, -98, 0, 0, 46, 46, 0, 0, 10372
[2022-10-27 02:35:25] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32028, 48231, 0, 0, -196, -197, 0, 0, 50, 50, 0, 0, 10373
[2022-10-27 02:35:25] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 10353
[2022-10-27 02:35:25] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 10355
[2022-10-27 02:35:25] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 10357
[2022-10-27 02:35:25] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 10302
[2022-10-27 02:35:25] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 10302
[2022-10-27 02:35:25] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 10302
[2022-10-27 02:35:25] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 10302
[2022-10-27 02:35:25] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 10303
[2022-10-27 02:35:25] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 10373
[2022-10-27 02:35:25] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -578, 0, 240, 0, 0, 0, 0, 10300
[2022-10-27 02:35:26] DeviceId [0] MonitoringReportHeader: 17, 44
[2022-10-27 02:35:26] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 44, 43, 45, 42, 0, 10895
[2022-10-27 02:35:26] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6636, 6680, 7034, 6256, 16124, 16100, 16372, 15774, 25534, 25732, 26190, 25114, 865954650, 865920826, 10898
[2022-10-27 02:35:26] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 166, 166, 164, 158, 163, 166, 166, 145, 157, 155, 158, 10899
[2022-10-27 02:35:26] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 7, 5, 250, 9, 10, 9, 9, 9, 9, 10900
[2022-10-27 02:35:26] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 10953
[2022-10-27 02:35:26] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 10954
[2022-10-27 02:35:26] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 133, 10954
[2022-10-27 02:35:26] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 10955
[2022-10-27 02:35:26] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 10955
[2022-10-27 02:35:26] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 10955
[2022-10-27 02:35:26] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -90, -193, 47086, 46972, 44681, 33489, 33338, 32675, 21658, 21410, 21627, 10976
[2022-10-27 02:35:26] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33207, 50313, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 10977
[2022-10-27 02:35:26] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33092, 50327, 0, 0, -97, -98, 0, 0, 46, 46, 0, 0, 10977
[2022-10-27 02:35:26] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32043, 49292, 0, 0, -196, -197, 0, 0, 50, 50, 0, 0, 10977
[2022-10-27 02:35:26] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 10957
[2022-10-27 02:35:26] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 10960
[2022-10-27 02:35:26] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 10962
[2022-10-27 02:35:26] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 10902
[2022-10-27 02:35:26] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 10902
[2022-10-27 02:35:26] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 10902
[2022-10-27 02:35:26] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 223, 2214, 1263, 233, 4854, 0, 10902
[2022-10-27 02:35:26] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 101, 0, 0, 0, 10903
[2022-10-27 02:35:26] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 10978
[2022-10-27 02:35:26] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -765, 0, 1636, 0, 0, 0, 0, 10900
[2022-10-27 02:35:26] DeviceId [0] MonitoringReportHeader: 18, 44
[2022-10-27 02:35:26] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 11495
[2022-10-27 02:35:26] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6628, 6670, 7018, 6246, 16116, 16088, 16360, 15766, 25550, 25746, 26204, 25132, 900557658, 865920858, 11498
[2022-10-27 02:35:26] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 167, 164, 167, 158, 164, 169, 169, 145, 155, 153, 155, 11499
[2022-10-27 02:35:26] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 11500
[2022-10-27 02:35:26] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 11553
[2022-10-27 02:35:26] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 138, 135, 136, 11554
[2022-10-27 02:35:26] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 11554
[2022-10-27 02:35:26] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 11554
[2022-10-27 02:35:26] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 11555
[2022-10-27 02:35:26] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 11555
[2022-10-27 02:35:26] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -91, -193, 47089, 46972, 45147, 34162, 33671, 32842, 21563, 21874, 21395, 11576
[2022-10-27 02:35:26] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33773, 51966, 0, 0, -91, -92, 0, 0, 46, 47, 0, 0, 11576
[2022-10-27 02:35:26] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33802, 52096, 0, 0, -96, -98, 0, 0, 46, 46, 0, 0, 11577
[2022-10-27 02:35:26] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32393, 50690, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 11577
[2022-10-27 02:35:26] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 11557
[2022-10-27 02:35:26] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 11559
[2022-10-27 02:35:26] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 11562
[2022-10-27 02:35:26] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 11502
[2022-10-27 02:35:26] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 11502
[2022-10-27 02:35:26] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 11502
[2022-10-27 02:35:26] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 233, 4854, 0, 11502
[2022-10-27 02:35:26] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 102, 0, 0, 0, 11503
[2022-10-27 02:35:26] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 11578
[2022-10-27 02:35:26] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -648, 0, 213, 0, 0, 0, 0, 11500
[2022-10-27 02:35:27] DeviceId [0] MonitoringReportHeader: 19, 44
[2022-10-27 02:35:27] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 46, 45, 45, 45, 45, 43, 45, 42, 0, 12095
[2022-10-27 02:35:27] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6492, 6528, 6868, 6104, 15996, 15956, 16242, 15648, 25722, 25918, 26386, 25312, 900557658, 865920858, 12098
[2022-10-27 02:35:27] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 165, 168, 163, 158, 163, 174, 170, 147, 154, 153, 158, 12099
[2022-10-27 02:35:27] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 21, 22, 21, 20, 8, 8, 9, 12, 11, 9, 7, 6, 250, 9, 9, 9, 9, 9, 10, 12100
[2022-10-27 02:35:27] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 135, 12157
[2022-10-27 02:35:27] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 12158
[2022-10-27 02:35:27] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 12158
[2022-10-27 02:35:27] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 12158
[2022-10-27 02:35:27] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -103, 12159
[2022-10-27 02:35:27] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 12159
[2022-10-27 02:35:27] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -91, -193, 46699, 46271, 44333, 33770, 33907, 32981, 21484, 21824, 21817, 12180
[2022-10-27 02:35:27] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33561, 52788, 0, 0, -91, -92, 0, 0, 47, 47, 0, 0, 12180
[2022-10-27 02:35:27] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33251, 52604, 0, 0, -97, -98, 0, 0, 46, 46, 0, 0, 12181
[2022-10-27 02:35:27] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32548, 51872, 0, 0, -196, -197, 0, 0, 51, 50, 0, 0, 12181
[2022-10-27 02:35:27] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 12161
[2022-10-27 02:35:27] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 12163
[2022-10-27 02:35:27] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 12166
[2022-10-27 02:35:27] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 12102
[2022-10-27 02:35:27] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 12102
[2022-10-27 02:35:27] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 12102
[2022-10-27 02:35:27] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 232, 4854, 0, 12102
[2022-10-27 02:35:27] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5998, 1999, 999, 100, 101, 0, 0, 0, 12103
[2022-10-27 02:35:27] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 12182
[2022-10-27 02:35:27] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -679, 0, 2980, 0, 0, 0, 0, 12100
[2022-10-27 02:35:27] DeviceId [0] MonitoringReportHeader: 20, 44
[2022-10-27 02:35:27] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 44, 43, 45, 42, 0, 12695
[2022-10-27 02:35:27] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6420, 6462, 6800, 6036, 15934, 15894, 16188, 15592, 25804, 26000, 26468, 25398, 900524889, 865920858, 12698
[2022-10-27 02:35:27] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 164, 169, 163, 154, 164, 171, 168, 146, 155, 151, 158, 12699
[2022-10-27 02:35:27] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 12, 11, 9, 8, 5, 250, 9, 9, 9, 9, 10, 9, 12700
[2022-10-27 02:35:27] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 12757
[2022-10-27 02:35:27] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 12757
[2022-10-27 02:35:27] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 133, 12758
[2022-10-27 02:35:27] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 12758
[2022-10-27 02:35:27] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 12758
[2022-10-27 02:35:27] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 12759
[2022-10-27 02:35:27] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -89, -193, 47240, 46549, 44936, 34064, 34043, 33019, 20921, 21041, 21471, 12780
[2022-10-27 02:35:27] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33722, 53989, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 12780
[2022-10-27 02:35:27] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33765, 54172, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 12781
[2022-10-27 02:35:27] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32776, 53164, 0, 0, -196, -197, 0, 0, 48, 48, 0, 0, 12781
[2022-10-27 02:35:27] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 12761
[2022-10-27 02:35:27] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 12763
[2022-10-27 02:35:27] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 12766
[2022-10-27 02:35:27] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 12702
[2022-10-27 02:35:27] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 12702
[2022-10-27 02:35:27] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 256, 685, 12702
[2022-10-27 02:35:27] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 12702
[2022-10-27 02:35:27] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 999, 100, 101, 0, 0, 0, 12703
[2022-10-27 02:35:27] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 12782
[2022-10-27 02:35:27] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 695, 0, 1675, 0, 0, 0, 0, 12700
[2022-10-27 02:35:28] DeviceId [0] MonitoringReportHeader: 21, 44
[2022-10-27 02:35:28] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 13295
[2022-10-27 02:35:28] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6668, 6712, 7058, 6288, 16150, 16126, 16394, 15796, 25494, 25698, 26152, 25074, 900524889, 865920858, 13298
[2022-10-27 02:35:28] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 159, 165, 166, 170, 156, 166, 168, 168, 144, 156, 152, 158, 13299
[2022-10-27 02:35:28] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 22, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 13300
[2022-10-27 02:35:28] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 13352
[2022-10-27 02:35:28] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 13352
[2022-10-27 02:35:28] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 13353
[2022-10-27 02:35:28] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 13353
[2022-10-27 02:35:28] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 13353
[2022-10-27 02:35:28] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 13353
[2022-10-27 02:35:28] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -97, -196, -86, -90, -193, 46546, 46208, 44302, 33751, 33464, 32747, 21612, 21380, 21609, 13375
[2022-10-27 02:35:28] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33208, 54508, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 13375
[2022-10-27 02:35:28] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33086, 54520, 0, 0, -97, -98, 0, 0, 46, 47, 0, 0, 13375
[2022-10-27 02:35:28] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32466, 53918, 0, 0, -196, -197, 0, 0, 51, 51, 0, 0, 13376
[2022-10-27 02:35:28] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 13356
[2022-10-27 02:35:28] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 13358
[2022-10-27 02:35:28] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 13360
[2022-10-27 02:35:28] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 13302
[2022-10-27 02:35:28] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 13302
[2022-10-27 02:35:28] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 13302
[2022-10-27 02:35:28] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 13302
[2022-10-27 02:35:28] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 13303
[2022-10-27 02:35:28] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65536, 13376
[2022-10-27 02:35:28] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -515, 0, 2683, 0, 0, 0, 0, 13300
[2022-10-27 02:35:29] DeviceId [0] MonitoringReportHeader: 22, 44
[2022-10-27 02:35:29] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 45, 45, 45, 43, 45, 42, 0, 13895
[2022-10-27 02:35:29] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6458, 6502, 6840, 6070, 15962, 15932, 16212, 15620, 25760, 25960, 26424, 25352, 900557658, 865920858, 13898
[2022-10-27 02:35:29] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 168, 165, 165, 157, 163, 165, 167, 144, 155, 156, 158, 13899
[2022-10-27 02:35:29] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 21, 21, 21, 20, 20, 8, 8, 9, 12, 11, 9, 7, 5, 250, 10, 9, 9, 9, 9, 9, 13900
[2022-10-27 02:35:29] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 13956
[2022-10-27 02:35:29] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 13957
[2022-10-27 02:35:29] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 13957
[2022-10-27 02:35:29] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 13957
[2022-10-27 02:35:29] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 13958
[2022-10-27 02:35:29] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 13958
[2022-10-27 02:35:29] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -90, -193, 46711, 46790, 45066, 34117, 33642, 32807, 21042, 21619, 21271, 13979
[2022-10-27 02:35:29] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33392, 55727, 0, 0, -91, -92, 0, 0, 47, 47, 0, 0, 13979
[2022-10-27 02:35:29] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33614, 56100, 0, 0, -96, -98, 0, 0, 47, 46, 0, 0, 13980
[2022-10-27 02:35:29] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32299, 54829, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 13980
[2022-10-27 02:35:29] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 13960
[2022-10-27 02:35:29] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 13963
[2022-10-27 02:35:29] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 13965
[2022-10-27 02:35:29] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 13902
[2022-10-27 02:35:29] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 13902
[2022-10-27 02:35:29] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 13902
[2022-10-27 02:35:29] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 13902
[2022-10-27 02:35:29] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 13903
[2022-10-27 02:35:29] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 13981
[2022-10-27 02:35:29] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -898, 0, 4315, 0, 0, 0, 0, 13900
[2022-10-27 02:35:29] DeviceId [0] MonitoringReportHeader: 23, 44
[2022-10-27 02:35:29] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 14495
[2022-10-27 02:35:29] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6878, 6896, 7268, 6504, 16324, 16310, 16572, 15970, 25250, 25452, 25890, 24820, 865921850, 865920826, 14498
[2022-10-27 02:35:29] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 165, 169, 167, 155, 162, 165, 170, 144, 157, 156, 158, 14499
[2022-10-27 02:35:29] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 7, 6, 250, 9, 9, 9, 9, 9, 9, 14500
[2022-10-27 02:35:29] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 14551
[2022-10-27 02:35:29] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 14552
[2022-10-27 02:35:29] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 14552
[2022-10-27 02:35:29] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 14553
[2022-10-27 02:35:29] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 14553
[2022-10-27 02:35:29] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 14553
[2022-10-27 02:35:29] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -90, -193, 46907, 46376, 44402, 33350, 33269, 32664, 21155, 21665, 21734, 14574
[2022-10-27 02:35:29] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33606, 57017, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 14574
[2022-10-27 02:35:29] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33297, 56832, 0, 0, -96, -97, 0, 0, 46, 46, 0, 0, 14575
[2022-10-27 02:35:29] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32139, 55724, 0, 0, -196, -197, 0, 0, 50, 50, 0, 0, 14575
[2022-10-27 02:35:29] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 14555
[2022-10-27 02:35:29] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 14558
[2022-10-27 02:35:29] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 14560
[2022-10-27 02:35:29] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 14502
[2022-10-27 02:35:29] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 14502
[2022-10-27 02:35:29] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 14502
[2022-10-27 02:35:29] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 14502
[2022-10-27 02:35:29] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 14503
[2022-10-27 02:35:29] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 1, 14576
[2022-10-27 02:35:29] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -765, 0, 1636, 0, 0, 0, 0, 14500
[2022-10-27 02:35:30] DeviceId [0] MonitoringReportHeader: 24, 44
[2022-10-27 02:35:30] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 44, 45, 45, 43, 45, 42, 0, 15095
[2022-10-27 02:35:30] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6598, 6636, 6984, 6218, 16086, 16056, 16336, 15740, 25590, 25782, 26244, 25168, 899476281, 865920826, 15098
[2022-10-27 02:35:30] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 156, 163, 168, 167, 156, 160, 170, 166, 148, 153, 152, 158, 15099
[2022-10-27 02:35:30] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 15100
[2022-10-27 02:35:30] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 15151
[2022-10-27 02:35:30] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 15152
[2022-10-27 02:35:30] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 15152
[2022-10-27 02:35:30] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 15152
[2022-10-27 02:35:30] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 15153
[2022-10-27 02:35:30] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 15153
[2022-10-27 02:35:30] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -90, -193, 47128, 46487, 44913, 34048, 33615, 32392, 21326, 21239, 21557, 15174
[2022-10-27 02:35:30] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33687, 58127, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 15174
[2022-10-27 02:35:30] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33762, 58383, 0, 0, -96, -98, 0, 0, 46, 46, 0, 0, 15175
[2022-10-27 02:35:30] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32378, 57021, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 15175
[2022-10-27 02:35:30] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 15155
[2022-10-27 02:35:30] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 15157
[2022-10-27 02:35:30] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 15160
[2022-10-27 02:35:30] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 15102
[2022-10-27 02:35:30] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 15102
[2022-10-27 02:35:30] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 15102
[2022-10-27 02:35:30] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 15102
[2022-10-27 02:35:30] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 999, 100, 101, 0, 0, 0, 15103
[2022-10-27 02:35:30] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65536, 15176
[2022-10-27 02:35:30] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -687, 0, 4256, 0, 0, 0, 0, 15100
[2022-10-27 02:35:30] DeviceId [0] MonitoringReportHeader: 25, 44
[2022-10-27 02:35:30] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 15695
[2022-10-27 02:35:30] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 298, 298, 6492, 6532, 6872, 6108, 16000, 15966, 16250, 15656, 25700, 25898, 26364, 25290, 900524890, 865920858, 15698
[2022-10-27 02:35:30] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 153, 164, 166, 164, 159, 161, 168, 166, 144, 155, 156, 154, 15699
[2022-10-27 02:35:30] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 15700
[2022-10-27 02:35:30] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 15756
[2022-10-27 02:35:30] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 15757
[2022-10-27 02:35:30] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 15757
[2022-10-27 02:35:30] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 15757
[2022-10-27 02:35:30] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 15758
[2022-10-27 02:35:30] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 15758
[2022-10-27 02:35:30] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 46683, 46768, 45048, 33656, 33851, 32930, 20978, 21584, 21249, 15779
[2022-10-27 02:35:30] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33838, 59324, 0, 0, -91, -91, 0, 0, 46, 47, 0, 0, 15779
[2022-10-27 02:35:30] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33827, 59512, 0, 0, -96, -97, 0, 0, 46, 45, 0, 0, 15780
[2022-10-27 02:35:30] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32408, 58094, 0, 0, -196, -197, 0, 0, 52, 51, 0, 0, 15780
[2022-10-27 02:35:30] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 15760
[2022-10-27 02:35:30] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 15762
[2022-10-27 02:35:30] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 15765
[2022-10-27 02:35:30] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 15702
[2022-10-27 02:35:30] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 15702
[2022-10-27 02:35:30] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 15702
[2022-10-27 02:35:30] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 233, 4859, 0, 15702
[2022-10-27 02:35:30] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 15703
[2022-10-27 02:35:30] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 1, 15781
[2022-10-27 02:35:30] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -750, 0, 2909, 0, 0, 0, 0, 15700
[2022-10-27 02:35:31] DeviceId [0] MonitoringReportHeader: 26, 44
[2022-10-27 02:35:31] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 16295
[2022-10-27 02:35:31] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6832, 6856, 7226, 6454, 16288, 16270, 16532, 15932, 25300, 25502, 25942, 24874, 900524890, 867002202, 16298
[2022-10-27 02:35:31] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 169, 167, 166, 156, 164, 166, 171, 146, 156, 156, 156, 16299
[2022-10-27 02:35:31] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 5, 250, 9, 9, 9, 9, 10, 9, 16300
[2022-10-27 02:35:31] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 16351
[2022-10-27 02:35:31] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 16351
[2022-10-27 02:35:31] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 16352
[2022-10-27 02:35:31] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 16352
[2022-10-27 02:35:31] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 16352
[2022-10-27 02:35:31] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 16352
[2022-10-27 02:35:31] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -97, -196, -86, -91, -194, 46446, 46142, 44763, 33965, 33580, 32383, 21842, 21999, 21909, 16374
[2022-10-27 02:35:31] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33073, 59614, 0, 0, -91, -92, 0, 0, 46, 47, 0, 0, 16375
[2022-10-27 02:35:31] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33468, 60214, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 16375
[2022-10-27 02:35:31] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32650, 59407, 0, 0, -196, -197, 0, 0, 49, 49, 0, 0, 16376
[2022-10-27 02:35:31] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 16355
[2022-10-27 02:35:31] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 16357
[2022-10-27 02:35:31] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 16359
[2022-10-27 02:35:31] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 16302
[2022-10-27 02:35:31] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 16302
[2022-10-27 02:35:31] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 684, 16302
[2022-10-27 02:35:31] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 16302
[2022-10-27 02:35:31] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 16303
[2022-10-27 02:35:31] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 16376
[2022-10-27 02:35:31] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -804, 0, 1646, 0, 0, 0, 0, 16300
[2022-10-27 02:35:32] DeviceId [0] MonitoringReportHeader: 27, 44
[2022-10-27 02:35:32] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 16895
[2022-10-27 02:35:32] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6722, 6762, 7116, 6352, 16198, 16178, 16440, 15844, 25428, 25630, 26086, 25012, 899476314, 865920826, 16898
[2022-10-27 02:35:32] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 164, 169, 162, 155, 161, 169, 170, 143, 155, 153, 157, 16899
[2022-10-27 02:35:32] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 22, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 10, 10, 9, 9, 9, 9, 16900
[2022-10-27 02:35:32] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 16955
[2022-10-27 02:35:32] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 16956
[2022-10-27 02:35:32] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 16956
[2022-10-27 02:35:32] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 16957
[2022-10-27 02:35:32] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 16957
[2022-10-27 02:35:32] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 16957
[2022-10-27 02:35:32] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -86, -90, -193, 47022, 46437, 44428, 33806, 33490, 32338, 21866, 21509, 21671, 16978
[2022-10-27 02:35:32] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33181, 60754, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 16978
[2022-10-27 02:35:32] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33079, 60877, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 16979
[2022-10-27 02:35:32] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32043, 59832, 0, 0, -196, -197, 0, 0, 49, 49, 0, 0, 16979
[2022-10-27 02:35:32] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 16959
[2022-10-27 02:35:32] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 16962
[2022-10-27 02:35:32] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 16964
[2022-10-27 02:35:32] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 16902
[2022-10-27 02:35:32] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 16902
[2022-10-27 02:35:32] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 16902
[2022-10-27 02:35:32] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 16902
[2022-10-27 02:35:32] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 16903
[2022-10-27 02:35:32] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 16980
[2022-10-27 02:35:32] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -757, 0, 4316, 0, 0, 0, 0, 16900
[2022-10-27 02:35:32] DeviceId [0] MonitoringReportHeader: 28, 44
[2022-10-27 02:35:32] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 17495
[2022-10-27 02:35:32] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 293, 292, 288, 286, 288, 302, 295, 297, 298, 6978, 7002, 7366, 6608, 16418, 16406, 16660, 16056, 25126, 25334, 25764, 24698, 900524890, 865920858, 17498
[2022-10-27 02:35:32] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 170, 171, 163, 155, 164, 170, 169, 146, 154, 153, 157, 17499
[2022-10-27 02:35:32] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 10, 9, 17500
[2022-10-27 02:35:32] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 134, 134, 17555
[2022-10-27 02:35:32] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 17556
[2022-10-27 02:35:32] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 17556
[2022-10-27 02:35:32] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 17556
[2022-10-27 02:35:32] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 17557
[2022-10-27 02:35:32] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 17557
[2022-10-27 02:35:32] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -86, -91, -194, 46838, 46353, 44850, 34023, 33603, 32392, 21834, 21994, 21908, 17577
[2022-10-27 02:35:32] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33517, 62122, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 17577
[2022-10-27 02:35:32] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33240, 62072, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 17578
[2022-10-27 02:35:32] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32116, 60954, 0, 0, -196, -197, 0, 0, 49, 50, 0, 0, 17578
[2022-10-27 02:35:32] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 17559
[2022-10-27 02:35:32] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 17561
[2022-10-27 02:35:32] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 17564
[2022-10-27 02:35:32] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 17502
[2022-10-27 02:35:32] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 17502
[2022-10-27 02:35:32] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 17502
[2022-10-27 02:35:32] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 232, 4854, 0, 17502
[2022-10-27 02:35:32] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 17503
[2022-10-27 02:35:32] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 1, 17579
[2022-10-27 02:35:32] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -914, 0, 4316, 0, 0, 0, 0, 17500
[2022-10-27 02:35:33] DeviceId [0] MonitoringReportHeader: 29, 44
[2022-10-27 02:35:33] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 18095
[2022-10-27 02:35:33] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6596, 6634, 6990, 6218, 16086, 16058, 16340, 15742, 25590, 25784, 26250, 25172, 900557658, 866969402, 18098
[2022-10-27 02:35:33] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 156, 167, 171, 167, 158, 163, 167, 168, 145, 152, 154, 154, 18099
[2022-10-27 02:35:33] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 21, 21, 22, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 10, 9, 9, 9, 9, 9, 18100
[2022-10-27 02:35:33] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 133, 134, 18150
[2022-10-27 02:35:33] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 18150
[2022-10-27 02:35:33] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 18151
[2022-10-27 02:35:33] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 18151
[2022-10-27 02:35:33] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 18151
[2022-10-27 02:35:33] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 18151
[2022-10-27 02:35:33] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -91, -193, 47116, 46990, 44683, 33489, 33335, 32259, 21914, 22044, 21451, 18172
[2022-10-27 02:35:33] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33289, 62921, 0, 0, -91, -91, 0, 0, 46, 47, 0, 0, 18173
[2022-10-27 02:35:33] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33564, 63433, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 18173
[2022-10-27 02:35:33] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32284, 62158, 0, 0, -196, -197, 0, 0, 51, 52, 0, 0, 18174
[2022-10-27 02:35:33] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 18154
[2022-10-27 02:35:33] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 18156
[2022-10-27 02:35:33] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 18158
[2022-10-27 02:35:33] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 18102
[2022-10-27 02:35:33] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 18102
[2022-10-27 02:35:33] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 18102
[2022-10-27 02:35:33] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 18102
[2022-10-27 02:35:33] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 18103
[2022-10-27 02:35:33] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 18174
[2022-10-27 02:35:33] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -593, 0, 4316, 0, 0, 0, 0, 18100
[2022-10-27 02:35:33] DeviceId [0] MonitoringReportHeader: 30, 44
[2022-10-27 02:35:33] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 18695
[2022-10-27 02:35:33] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6876, 6896, 7266, 6504, 16326, 16310, 16572, 15968, 25250, 25454, 25892, 24824, 899476281, 865920858, 18698
[2022-10-27 02:35:33] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 167, 167, 166, 156, 161, 166, 169, 145, 157, 156, 159, 18699
[2022-10-27 02:35:33] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 20, 19, 21, 21, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 5, 250, 9, 9, 9, 9, 9, 9, 18700
[2022-10-27 02:35:33] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 18749
[2022-10-27 02:35:33] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 18750
[2022-10-27 02:35:33] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 18751
[2022-10-27 02:35:33] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 18751
[2022-10-27 02:35:33] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -102, 18751
[2022-10-27 02:35:33] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 18751
[2022-10-27 02:35:33] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -86, -90, -193, 46910, 46873, 45112, 33682, 33430, 32743, 21621, 21396, 21174, 18772
[2022-10-27 02:35:33] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33436, 64088, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 18773
[2022-10-27 02:35:33] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33202, 64074, 0, 0, -97, -97, 0, 0, 46, 47, 0, 0, 18773
[2022-10-27 02:35:33] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32084, 62969, 0, 0, -196, -197, 0, 0, 50, 49, 0, 0, 18774
[2022-10-27 02:35:33] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 18753
[2022-10-27 02:35:33] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 18756
[2022-10-27 02:35:33] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 18758
[2022-10-27 02:35:33] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 18702
[2022-10-27 02:35:33] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 18702
[2022-10-27 02:35:33] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 256, 685, 18702
[2022-10-27 02:35:33] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 223, 2214, 1263, 233, 4854, 0, 18702
[2022-10-27 02:35:33] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 999, 100, 101, 0, 0, 0, 18703
[2022-10-27 02:35:33] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 18774
[2022-10-27 02:35:33] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -617, 0, 2882, 0, 0, 0, 0, 18700
[2022-10-27 02:35:34] DeviceId [0] MonitoringReportHeader: 31, 44
[2022-10-27 02:35:34] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 19295
[2022-10-27 02:35:34] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 293, 292, 288, 286, 288, 302, 295, 297, 298, 6960, 6984, 7350, 6588, 16396, 16384, 16642, 16036, 25154, 25358, 25792, 24722, 900524890, 866969434, 19298
[2022-10-27 02:35:34] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 156, 163, 172, 167, 158, 164, 169, 173, 146, 153, 154, 159, 19299
[2022-10-27 02:35:34] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 20, 21, 21, 20, 22, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 5, 250, 10, 9, 9, 9, 9, 9, 19300
[2022-10-27 02:35:34] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 19354
[2022-10-27 02:35:34] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 19354
[2022-10-27 02:35:34] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 19355
[2022-10-27 02:35:34] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 19355
[2022-10-27 02:35:34] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 19355
[2022-10-27 02:35:34] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 19355
[2022-10-27 02:35:34] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -93, -192, -91, -97, -196, -85, -91, -193, 46341, 46594, 44965, 33631, 33407, 32300, 21371, 21779, 21799, 19376
[2022-10-27 02:35:34] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33117, 64772, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 19377
[2022-10-27 02:35:34] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33052, 64920, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 19377
[2022-10-27 02:35:34] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32016, 63878, 0, 0, -196, -197, 0, 0, 50, 50, 0, 0, 19378
[2022-10-27 02:35:34] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 19358
[2022-10-27 02:35:34] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 19360
[2022-10-27 02:35:34] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 19362
[2022-10-27 02:35:34] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 19302
[2022-10-27 02:35:34] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 19302
[2022-10-27 02:35:34] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 19302
[2022-10-27 02:35:34] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 233, 4854, 0, 19302
[2022-10-27 02:35:34] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 19303
[2022-10-27 02:35:34] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 50397184, 19378
[2022-10-27 02:35:34] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -679, 0, 255, 0, 0, 0, 0, 19300
[2022-10-27 02:35:35] DeviceId [0] MonitoringReportHeader: 32, 44
[2022-10-27 02:35:35] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 44, 43, 45, 42, 0, 19895
[2022-10-27 02:35:35] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 293, 292, 288, 286, 288, 302, 295, 297, 298, 6990, 7014, 7374, 6622, 16430, 16416, 16672, 16066, 25120, 25320, 25760, 24688, 900557658, 865920858, 19898
[2022-10-27 02:35:35] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 166, 170, 164, 160, 161, 166, 170, 147, 155, 151, 160, 19899
[2022-10-27 02:35:35] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 20, 20, 8, 8, 9, 13, 11, 9, 7, 6, 250, 10, 9, 9, 9, 9, 9, 19900
[2022-10-27 02:35:35] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 19953
[2022-10-27 02:35:35] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 19954
[2022-10-27 02:35:35] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 133, 19954
[2022-10-27 02:35:35] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 19955
[2022-10-27 02:35:35] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 19955
[2022-10-27 02:35:35] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 19955
[2022-10-27 02:35:35] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -92, -192, -91, -96, -196, -86, -91, -193, 46322, 46087, 44736, 33515, 33787, 32492, 21776, 21966, 21426, 19976
[2022-10-27 02:35:35] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33311, 482, 0, 0, -91, -91, 0, 0, 46, 47, 0, 0, 19977
[2022-10-27 02:35:35] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33568, 978, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 19977
[2022-10-27 02:35:35] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32687, 60, 0, 0, -196, -197, 0, 0, 49, 48, 0, 0, 19978
[2022-10-27 02:35:35] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 19957
[2022-10-27 02:35:35] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 19960
[2022-10-27 02:35:35] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 19962
[2022-10-27 02:35:35] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 19902
[2022-10-27 02:35:35] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 19902
[2022-10-27 02:35:35] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 19902
[2022-10-27 02:35:35] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 233, 4859, 0, 19902
[2022-10-27 02:35:35] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 101, 0, 0, 0, 19903
[2022-10-27 02:35:35] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 19978
[2022-10-27 02:35:35] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -695, 0, 256, 0, 0, 0, 0, 19900
[2022-10-27 02:35:35] DeviceId [0] MonitoringReportHeader: 33, 44
[2022-10-27 02:35:35] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 20495
[2022-10-27 02:35:35] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6360, 6402, 6742, 5974, 15872, 15838, 16128, 15534, 25882, 26076, 26548, 25472, 900524890, 865920826, 20498
[2022-10-27 02:35:35] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 164, 165, 169, 156, 159, 167, 165, 145, 154, 155, 159, 20499
[2022-10-27 02:35:35] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 7, 6, 250, 9, 9, 9, 9, 9, 9, 20500
[2022-10-27 02:35:35] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 134, 134, 20548
[2022-10-27 02:35:35] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 20548
[2022-10-27 02:35:35] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 133, 20549
[2022-10-27 02:35:35] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 20549
[2022-10-27 02:35:35] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 20549
[2022-10-27 02:35:35] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 20549
[2022-10-27 02:35:35] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -91, -193, 46785, 46818, 45069, 33666, 33422, 32725, 21621, 21896, 21411, 20571
[2022-10-27 02:35:35] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33768, 1966, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 20571
[2022-10-27 02:35:35] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33793, 2208, 0, 0, -96, -97, 0, 0, 45, 46, 0, 0, 20571
[2022-10-27 02:35:35] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32390, 758, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 20572
[2022-10-27 02:35:35] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 20552
[2022-10-27 02:35:35] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 20554
[2022-10-27 02:35:35] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 20556
[2022-10-27 02:35:35] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 20502
[2022-10-27 02:35:35] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 20502
[2022-10-27 02:35:35] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 20502
[2022-10-27 02:35:35] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 225, 2219, 1262, 232, 4854, 0, 20502
[2022-10-27 02:35:35] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 999, 100, 101, 0, 0, 0, 20503
[2022-10-27 02:35:35] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 20572
[2022-10-27 02:35:35] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 554, 0, 2980, 0, 0, 0, 0, 20500
[2022-10-27 02:35:36] DeviceId [0] MonitoringReportHeader: 34, 44
[2022-10-27 02:35:36] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 44, 43, 45, 42, 0, 21095
[2022-10-27 02:35:36] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6834, 6862, 7228, 6462, 16288, 16276, 16540, 15934, 25298, 25502, 25946, 24876, 899509082, 865920858, 21098
[2022-10-27 02:35:36] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 169, 170, 163, 161, 164, 163, 165, 145, 151, 152, 155, 21099
[2022-10-27 02:35:36] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 20, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 21100
[2022-10-27 02:35:36] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 21147
[2022-10-27 02:35:36] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 21148
[2022-10-27 02:35:36] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 21149
[2022-10-27 02:35:36] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 21149
[2022-10-27 02:35:36] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 21149
[2022-10-27 02:35:36] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 21149
[2022-10-27 02:35:36] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -93, -192, -91, -97, -196, -85, -90, -194, 46431, 46637, 44515, 33847, 33523, 32761, 21070, 21633, 21726, 21170
[2022-10-27 02:35:36] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33598, 2811, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 21171
[2022-10-27 02:35:36] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33715, 3114, 0, 0, -96, -97, 0, 0, 46, 47, 0, 0, 21171
[2022-10-27 02:35:36] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32780, 2096, 0, 0, -196, -197, 0, 0, 48, 48, 0, 0, 21172
[2022-10-27 02:35:36] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 21152
[2022-10-27 02:35:36] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 21154
[2022-10-27 02:35:36] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 21156
[2022-10-27 02:35:36] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 21102
[2022-10-27 02:35:36] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 21102
[2022-10-27 02:35:36] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 21102
[2022-10-27 02:35:36] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 21102
[2022-10-27 02:35:36] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 1000, 100, 101, 0, 0, 0, 21103
[2022-10-27 02:35:36] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 33554433, 21172
[2022-10-27 02:35:36] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -617, 0, 4317, 0, 0, 0, 0, 21100
[2022-10-27 02:35:36] DeviceId [0] MonitoringReportHeader: 35, 44
[2022-10-27 02:35:36] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 21695
[2022-10-27 02:35:36] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 298, 298, 6340, 6380, 6722, 5948, 15854, 15810, 16108, 15514, 25906, 26100, 26576, 25500, 865954650, 867002170, 21698
[2022-10-27 02:35:36] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 162, 167, 166, 155, 166, 166, 171, 146, 154, 150, 158, 21699
[2022-10-27 02:35:36] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 21700
[2022-10-27 02:35:36] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 134, 134, 21752
[2022-10-27 02:35:36] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 21753
[2022-10-27 02:35:36] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 21753
[2022-10-27 02:35:36] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 21754
[2022-10-27 02:35:36] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 21754
[2022-10-27 02:35:36] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 21754
[2022-10-27 02:35:36] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -90, -193, 46797, 46822, 44613, 33888, 33537, 32354, 21855, 21500, 21205, 21775
[2022-10-27 02:35:36] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33406, 3594, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 21775
[2022-10-27 02:35:36] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33184, 3554, 0, 0, -97, -97, 0, 0, 46, 46, 0, 0, 21776
[2022-10-27 02:35:36] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32506, 2844, 0, 0, -196, -197, 0, 0, 51, 51, 0, 0, 21776
[2022-10-27 02:35:36] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 21756
[2022-10-27 02:35:36] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 21759
[2022-10-27 02:35:36] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 21761
[2022-10-27 02:35:36] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 21702
[2022-10-27 02:35:36] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 21702
[2022-10-27 02:35:36] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 21702
[2022-10-27 02:35:36] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 223, 2214, 1262, 233, 4859, 0, 21702
[2022-10-27 02:35:36] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 21703
[2022-10-27 02:35:36] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 196608, 21777
[2022-10-27 02:35:36] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 656, 0, 1675, 0, 0, 0, 0, 21700
[2022-10-27 02:35:37] DeviceId [0] MonitoringReportHeader: 36, 44
[2022-10-27 02:35:37] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 46, 42, 0, 22295
[2022-10-27 02:35:37] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6434, 6478, 6820, 6050, 15950, 15914, 16200, 15604, 25788, 25986, 26448, 25378, 900524889, 865920858, 22298
[2022-10-27 02:35:37] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 168, 172, 170, 157, 165, 169, 171, 144, 160, 156, 156, 22299
[2022-10-27 02:35:37] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 22, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 7, 6, 250, 10, 9, 9, 9, 9, 9, 22300
[2022-10-27 02:35:37] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 22352
[2022-10-27 02:35:37] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 138, 135, 136, 22352
[2022-10-27 02:35:37] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 133, 22353
[2022-10-27 02:35:37] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 22353
[2022-10-27 02:35:37] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 22353
[2022-10-27 02:35:37] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 22354
[2022-10-27 02:35:37] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 47214, 46523, 44922, 33609, 33814, 32491, 21253, 21710, 21292, 22375
[2022-10-27 02:35:37] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33806, 4948, 0, 0, -91, -91, 0, 0, 46, 47, 0, 0, 22375
[2022-10-27 02:35:37] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33798, 5172, 0, 0, -96, -97, 0, 0, 45, 45, 0, 0, 22376
[2022-10-27 02:35:37] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32398, 3690, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 22376
[2022-10-27 02:35:37] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 22356
[2022-10-27 02:35:37] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 22358
[2022-10-27 02:35:37] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 22360
[2022-10-27 02:35:37] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 22302
[2022-10-27 02:35:37] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 22302
[2022-10-27 02:35:37] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 22302
[2022-10-27 02:35:37] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 225, 2219, 1263, 232, 4849, 0, 22302
[2022-10-27 02:35:37] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 1000, 100, 101, 0, 0, 0, 22303
[2022-10-27 02:35:37] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 22377
[2022-10-27 02:35:37] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 617, 0, 2910, 0, 0, 0, 0, 22300
[2022-10-27 02:35:38] DeviceId [0] MonitoringReportHeader: 37, 44
[2022-10-27 02:35:38] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 22895
[2022-10-27 02:35:38] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6486, 6530, 6870, 6106, 15996, 15960, 16244, 15654, 25722, 25924, 26386, 25314, 900557658, 865920826, 22898
[2022-10-27 02:35:38] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 167, 163, 163, 156, 162, 169, 169, 142, 155, 156, 157, 22899
[2022-10-27 02:35:38] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 20, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 22900
[2022-10-27 02:35:38] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 22957
[2022-10-27 02:35:38] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 22958
[2022-10-27 02:35:38] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 22958
[2022-10-27 02:35:38] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 22958
[2022-10-27 02:35:38] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 22959
[2022-10-27 02:35:38] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 22959
[2022-10-27 02:35:38] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 46692, 46767, 44577, 33872, 33959, 32955, 20933, 21563, 21232, 22980
[2022-10-27 02:35:38] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33398, 5551, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 22980
[2022-10-27 02:35:38] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33168, 5473, 0, 0, -97, -97, 0, 0, 46, 45, 0, 0, 22981
[2022-10-27 02:35:38] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32513, 4815, 0, 0, -196, -197, 0, 0, 51, 51, 0, 0, 22981
[2022-10-27 02:35:38] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 22961
[2022-10-27 02:35:38] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 22963
[2022-10-27 02:35:38] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 22966
[2022-10-27 02:35:38] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 22902
[2022-10-27 02:35:38] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 22902
[2022-10-27 02:35:38] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 22902
[2022-10-27 02:35:38] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 22902
[2022-10-27 02:35:38] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 1000, 100, 101, 0, 0, 0, 22903
[2022-10-27 02:35:38] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65536, 22982
[2022-10-27 02:35:38] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 656, 0, 1675, 0, 0, 0, 0, 22900
[2022-10-27 02:35:38] DeviceId [0] MonitoringReportHeader: 38, 44
[2022-10-27 02:35:38] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 23495
[2022-10-27 02:35:38] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6794, 6832, 7184, 6420, 16258, 16240, 16502, 15906, 25356, 25552, 26006, 24932, 865921881, 865920858, 23498
[2022-10-27 02:35:38] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 163, 169, 163, 156, 165, 163, 169, 146, 151, 153, 155, 23499
[2022-10-27 02:35:38] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 12, 11, 9, 7, 5, 250, 9, 9, 9, 9, 9, 9, 23500
[2022-10-27 02:35:38] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 23552
[2022-10-27 02:35:38] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 23552
[2022-10-27 02:35:38] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 23553
[2022-10-27 02:35:38] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 23553
[2022-10-27 02:35:38] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 23553
[2022-10-27 02:35:38] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 23554
[2022-10-27 02:35:38] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -89, -193, 46974, 46902, 44649, 33916, 33975, 33000, 20936, 21055, 21021, 23575
[2022-10-27 02:35:38] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33504, 6656, 0, 0, -91, -91, 0, 0, 47, 46, 0, 0, 23575
[2022-10-27 02:35:38] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33665, 6956, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 23576
[2022-10-27 02:35:38] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32322, 5596, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 23576
[2022-10-27 02:35:38] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 23556
[2022-10-27 02:35:38] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 23558
[2022-10-27 02:35:38] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 23561
[2022-10-27 02:35:38] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 23502
[2022-10-27 02:35:38] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 23502
[2022-10-27 02:35:38] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 23502
[2022-10-27 02:35:38] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 23502
[2022-10-27 02:35:38] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 23503
[2022-10-27 02:35:38] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65536, 23577
[2022-10-27 02:35:38] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -906, 0, 1637, 0, 0, 0, 0, 23500
[2022-10-27 02:35:39] DeviceId [0] MonitoringReportHeader: 39, 44
[2022-10-27 02:35:39] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 24095
[2022-10-27 02:35:39] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6520, 6560, 6906, 6140, 16024, 15992, 16274, 15682, 25682, 25878, 26342, 25274, 865954650, 865920858, 24098
[2022-10-27 02:35:39] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 155, 167, 165, 166, 154, 164, 169, 169, 147, 152, 155, 154, 24099
[2022-10-27 02:35:39] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 21, 21, 8, 8, 9, 12, 11, 9, 8, 5, 250, 9, 10, 9, 9, 10, 9, 24100
[2022-10-27 02:35:39] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 24156
[2022-10-27 02:35:39] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 24157
[2022-10-27 02:35:39] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 24157
[2022-10-27 02:35:39] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 24157
[2022-10-27 02:35:39] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 24158
[2022-10-27 02:35:39] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 24158
[2022-10-27 02:35:39] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -96, -196, -85, -90, -193, 46657, 46744, 45042, 33654, 33848, 32524, 21237, 21710, 21296, 24179
[2022-10-27 02:35:39] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33810, 7979, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 24179
[2022-10-27 02:35:39] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33380, 7677, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 24180
[2022-10-27 02:35:39] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32586, 6888, 0, 0, -196, -197, 0, 0, 49, 50, 0, 0, 24180
[2022-10-27 02:35:39] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 24160
[2022-10-27 02:35:39] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 24162
[2022-10-27 02:35:39] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 24165
[2022-10-27 02:35:39] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 24102
[2022-10-27 02:35:39] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 24102
[2022-10-27 02:35:39] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 686, 24102
[2022-10-27 02:35:39] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 24102
[2022-10-27 02:35:39] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 999, 100, 101, 0, 0, 0, 24103
[2022-10-27 02:35:39] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 24181
[2022-10-27 02:35:39] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 500, 0, 1586, 0, 0, 0, 0, 24100
[2022-10-27 02:35:39] DeviceId [0] MonitoringReportHeader: 40, 44
[2022-10-27 02:35:39] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 24695
[2022-10-27 02:35:39] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6402, 6444, 6788, 6016, 15914, 15880, 16170, 15576, 25828, 26026, 26496, 25422, 900524889, 865920858, 24698
[2022-10-27 02:35:39] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 156, 167, 165, 160, 157, 160, 167, 170, 146, 154, 156, 157, 24699
[2022-10-27 02:35:39] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 22, 21, 20, 8, 8, 9, 13, 11, 9, 7, 6, 250, 9, 9, 9, 9, 9, 9, 24700
[2022-10-27 02:35:39] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 135, 24749
[2022-10-27 02:35:39] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 24749
[2022-10-27 02:35:39] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 24750
[2022-10-27 02:35:39] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 24750
[2022-10-27 02:35:39] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 24750
[2022-10-27 02:35:39] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 24750
[2022-10-27 02:35:39] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -90, -194, 46751, 46293, 44829, 33555, 33362, 32685, 21109, 21646, 21731, 24771
[2022-10-27 02:35:39] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33602, 8731, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 24772
[2022-10-27 02:35:39] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33711, 9018, 0, 0, -96, -97, 0, 0, 47, 47, 0, 0, 24772
[2022-10-27 02:35:39] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32746, 8056, 0, 0, -196, -197, 0, 0, 48, 47, 0, 0, 24773
[2022-10-27 02:35:39] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 24753
[2022-10-27 02:35:39] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 24755
[2022-10-27 02:35:39] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 24757
[2022-10-27 02:35:39] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 24702
[2022-10-27 02:35:39] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 24702
[2022-10-27 02:35:39] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 24702
[2022-10-27 02:35:39] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 24702
[2022-10-27 02:35:39] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 999, 100, 101, 0, 0, 0, 24703
[2022-10-27 02:35:39] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 24773
[2022-10-27 02:35:39] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -773, 0, 4313, 0, 0, 0, 0, 24700
[2022-10-27 02:35:40] DeviceId [0] MonitoringReportHeader: 41, 44
[2022-10-27 02:35:40] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 46, 45, 43, 45, 42, 0, 25295
[2022-10-27 02:35:40] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6680, 6728, 7078, 6310, 16160, 16142, 16406, 15814, 25486, 25688, 26142, 25070, 900557658, 865920858, 25298
[2022-10-27 02:35:40] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 157, 166, 167, 164, 159, 164, 165, 168, 144, 152, 151, 158, 25299
[2022-10-27 02:35:40] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 25300
[2022-10-27 02:35:40] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 25356
[2022-10-27 02:35:40] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 25357
[2022-10-27 02:35:40] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 25357
[2022-10-27 02:35:40] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 25358
[2022-10-27 02:35:40] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 25358
[2022-10-27 02:35:40] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 25358
[2022-10-27 02:35:40] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -90, -193, 47050, 46446, 44902, 34029, 33594, 32810, 21045, 21103, 21031, 25379
[2022-10-27 02:35:40] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33490, 9674, 0, 0, -91, -91, 0, 0, 47, 47, 0, 0, 25380
[2022-10-27 02:35:40] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33652, 9938, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 25380
[2022-10-27 02:35:40] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32334, 8566, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 25380
[2022-10-27 02:35:40] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 25360
[2022-10-27 02:35:40] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 25363
[2022-10-27 02:35:40] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 25365
[2022-10-27 02:35:40] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 25302
[2022-10-27 02:35:40] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 25302
[2022-10-27 02:35:40] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 25302
[2022-10-27 02:35:40] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1262, 233, 4859, 0, 25302
[2022-10-27 02:35:40] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6001, 1999, 1000, 100, 101, 0, 0, 0, 25303
[2022-10-27 02:35:40] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 1, 25381
[2022-10-27 02:35:40] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -804, 0, 1636, 0, 0, 0, 0, 25300
[2022-10-27 02:35:41] DeviceId [0] MonitoringReportHeader: 42, 44
[2022-10-27 02:35:41] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 44, 43, 45, 42, 0, 25895
[2022-10-27 02:35:41] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 288, 302, 295, 297, 298, 6524, 6564, 6904, 6146, 16028, 15996, 16278, 15686, 25680, 25876, 26340, 25270, 899509082, 865920826, 25898
[2022-10-27 02:35:41] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 160, 162, 167, 161, 157, 165, 167, 168, 146, 153, 154, 158, 25899
[2022-10-27 02:35:41] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 21, 21, 21, 21, 21, 21, 8, 8, 9, 12, 11, 9, 7, 6, 250, 9, 9, 9, 9, 9, 9, 25900
[2022-10-27 02:35:41] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 25949
[2022-10-27 02:35:41] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 25949
[2022-10-27 02:35:41] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 25950
[2022-10-27 02:35:41] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 25950
[2022-10-27 02:35:41] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 25950
[2022-10-27 02:35:41] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 25950
[2022-10-27 02:35:41] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -85, -90, -193, 46652, 46248, 44322, 33759, 33899, 32532, 21218, 21182, 21064, 25972
[2022-10-27 02:35:41] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33919, 11128, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 25972
[2022-10-27 02:35:41] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33432, 10730, 0, 0, -96, -97, 0, 0, 46, 47, 0, 0, 25972
[2022-10-27 02:35:41] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32621, 9907, 0, 0, -196, -197, 0, 0, 49, 50, 0, 0, 25973
[2022-10-27 02:35:41] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 25953
[2022-10-27 02:35:41] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 25955
[2022-10-27 02:35:41] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 25957
[2022-10-27 02:35:41] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 25902
[2022-10-27 02:35:41] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 25902
[2022-10-27 02:35:41] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 25902
[2022-10-27 02:35:41] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 225, 2219, 1263, 233, 4854, 0, 25902
[2022-10-27 02:35:41] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 999, 100, 101, 0, 0, 0, 25903
[2022-10-27 02:35:41] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 25973
[2022-10-27 02:35:41] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -859, 0, 1673, 0, 0, 0, 0, 25900
[2022-10-27 02:35:41] DeviceId [0] MonitoringReportHeader: 43, 44
[2022-10-27 02:35:41] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 46, 45, 43, 45, 42, 0, 26495
[2022-10-27 02:35:41] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 288, 302, 295, 297, 298, 6734, 6780, 7130, 6364, 16208, 16194, 16454, 15860, 25418, 25618, 26070, 24998, 865921882, 866969434, 26498
[2022-10-27 02:35:41] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 168, 170, 166, 157, 164, 167, 171, 146, 157, 154, 158, 26499
[2022-10-27 02:35:41] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 22, 21, 22, 20, 8, 8, 9, 13, 11, 9, 7, 5, 250, 10, 9, 9, 9, 9, 9, 26500
[2022-10-27 02:35:41] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 26556
[2022-10-27 02:35:41] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 134, 136, 26557
[2022-10-27 02:35:41] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 26557
[2022-10-27 02:35:41] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -101, 26557
[2022-10-27 02:35:41] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 26558
[2022-10-27 02:35:41] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -93, 26558
[2022-10-27 02:35:41] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -90, -193, 47001, 46409, 44894, 33583, 33374, 32699, 21638, 21393, 21163, 26579
[2022-10-27 02:35:41] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33880, 12106, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 26579
[2022-10-27 02:35:41] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33846, 12156, 0, 0, -96, -97, 0, 0, 45, 45, 0, 0, 26580
[2022-10-27 02:35:41] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32415, 10706, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 26580
[2022-10-27 02:35:41] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 26560
[2022-10-27 02:35:41] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 26562
[2022-10-27 02:35:41] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 26565
[2022-10-27 02:35:41] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 26502
[2022-10-27 02:35:41] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 26502
[2022-10-27 02:35:41] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 26502
[2022-10-27 02:35:41] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 26502
[2022-10-27 02:35:41] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5999, 1999, 1000, 100, 101, 0, 0, 0, 26503
[2022-10-27 02:35:41] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 26581
[2022-10-27 02:35:41] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 632, 0, 4314, 0, 0, 0, 0, 26500
[2022-10-27 02:35:42] DeviceId [0] MonitoringReportHeader: 44, 44
[2022-10-27 02:35:42] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 46, 45, 43, 45, 42, 0, 27095
[2022-10-27 02:35:42] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6480, 6526, 6864, 6098, 15992, 15958, 16240, 15646, 25738, 25942, 26406, 25334, 900557658, 865920858, 27098
[2022-10-27 02:35:42] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 159, 165, 164, 169, 156, 165, 166, 168, 142, 153, 154, 156, 27099
[2022-10-27 02:35:42] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 21, 8, 8, 9, 12, 11, 9, 7, 5, 250, 9, 9, 9, 9, 9, 9, 27100
[2022-10-27 02:35:42] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 27155
[2022-10-27 02:35:42] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 27155
[2022-10-27 02:35:42] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 27156
[2022-10-27 02:35:42] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 27156
[2022-10-27 02:35:42] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -99, 27156
[2022-10-27 02:35:42] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 27157
[2022-10-27 02:35:42] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -90, -193, 47186, 47013, 44694, 33482, 33757, 32464, 21262, 21213, 21080, 27177
[2022-10-27 02:35:42] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33919, 13167, 0, 0, -91, -91, 0, 0, 45, 45, 0, 0, 27178
[2022-10-27 02:35:42] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33854, 13180, 0, 0, -96, -97, 0, 0, 45, 46, 0, 0, 27178
[2022-10-27 02:35:42] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32430, 11746, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 27179
[2022-10-27 02:35:42] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 27159
[2022-10-27 02:35:42] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 27161
[2022-10-27 02:35:42] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 27164
[2022-10-27 02:35:42] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 27102
[2022-10-27 02:35:42] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 27102
[2022-10-27 02:35:42] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 27102
[2022-10-27 02:35:42] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 232, 4849, 0, 27102
[2022-10-27 02:35:42] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 27103
[2022-10-27 02:35:42] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 27179
[2022-10-27 02:35:42] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -867, 0, 1637, 0, 0, 0, 0, 27100
[2022-10-27 02:35:42] DeviceId [0] MonitoringReportHeader: 45, 44
[2022-10-27 02:35:42] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 27695
[2022-10-27 02:35:42] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 288, 302, 295, 297, 298, 6832, 6860, 7218, 6456, 16282, 16264, 16530, 15926, 25316, 25520, 25960, 24888, 866970458, 865920826, 27698
[2022-10-27 02:35:42] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 167, 170, 162, 154, 164, 168, 171, 146, 155, 153, 158, 27699
[2022-10-27 02:35:42] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 20, 20, 21, 21, 20, 21, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 10, 9, 9, 9, 9, 27700
[2022-10-27 02:35:42] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 139, 134, 135, 27753
[2022-10-27 02:35:42] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 27753
[2022-10-27 02:35:42] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 27754
[2022-10-27 02:35:42] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -98, 27754
[2022-10-27 02:35:42] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 27754
[2022-10-27 02:35:42] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -91, 27755
[2022-10-27 02:35:42] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -88, -93, -192, -91, -97, -196, -85, -90, -193, 46431, 46633, 44511, 33402, 33290, 32655, 21131, 21150, 21514, 27776
[2022-10-27 02:35:42] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33258, 13536, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 27776
[2022-10-27 02:35:42] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33112, 13468, 0, 0, -97, -98, 0, 0, 46, 46, 0, 0, 27777
[2022-10-27 02:35:42] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32468, 12827, 0, 0, -196, -197, 0, 0, 51, 52, 0, 0, 27777
[2022-10-27 02:35:42] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 27757
[2022-10-27 02:35:42] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 27759
[2022-10-27 02:35:42] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 27761
[2022-10-27 02:35:42] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 27702
[2022-10-27 02:35:42] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 27702
[2022-10-27 02:35:42] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 256, 685, 27702
[2022-10-27 02:35:42] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 27702
[2022-10-27 02:35:42] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 27703
[2022-10-27 02:35:42] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 131072, 27778
[2022-10-27 02:35:42] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 671, 0, 2980, 0, 0, 0, 0, 27700
[2022-10-27 02:35:43] DeviceId [0] MonitoringReportHeader: 46, 44
[2022-10-27 02:35:43] DeviceId [0] TemperatureMonitoring: 31, 0, 44, 45, 45, 45, 45, 44, 43, 45, 42, 0, 28295
[2022-10-27 02:35:43] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6458, 6504, 6840, 6072, 15966, 15932, 16218, 15622, 25762, 25958, 26426, 25356, 900524889, 865920858, 28298
[2022-10-27 02:35:43] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 167, 166, 164, 159, 160, 166, 164, 145, 153, 153, 155, 28299
[2022-10-27 02:35:43] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 28300
[2022-10-27 02:35:43] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 28356
[2022-10-27 02:35:43] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 135, 28356
[2022-10-27 02:35:43] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 28357
[2022-10-27 02:35:43] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 28357
[2022-10-27 02:35:43] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -100, 28357
[2022-10-27 02:35:43] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 28357
[2022-10-27 02:35:43] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -97, -196, -85, -90, -193, 46691, 46281, 44349, 33317, 33681, 32822, 21013, 21084, 21038, 28378
[2022-10-27 02:35:43] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33936, 15280, 0, 0, -91, -91, 0, 0, 46, 46, 0, 0, 28379
[2022-10-27 02:35:43] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33870, 15266, 0, 0, -96, -97, 0, 0, 45, 45, 0, 0, 28379
[2022-10-27 02:35:43] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32426, 13788, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 28380
[2022-10-27 02:35:43] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 28360
[2022-10-27 02:35:43] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 28362
[2022-10-27 02:35:43] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 28364
[2022-10-27 02:35:43] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 28302
[2022-10-27 02:35:43] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 28302
[2022-10-27 02:35:43] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 28302
[2022-10-27 02:35:43] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 223, 2214, 1263, 233, 4854, 0, 28302
[2022-10-27 02:35:43] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 1000, 100, 101, 0, 0, 0, 28303
[2022-10-27 02:35:43] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 1, 28380
[2022-10-27 02:35:43] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 570, 0, 2525, 0, 0, 0, 0, 28300
[2022-10-27 02:35:44] DeviceId [0] MonitoringReportHeader: 47, 44
[2022-10-27 02:35:44] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 45, 43, 45, 42, 0, 28895
[2022-10-27 02:35:44] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 285, 289, 302, 295, 297, 298, 6486, 6524, 6864, 6100, 15986, 15954, 16238, 15648, 25742, 25936, 26402, 25332, 899476281, 865920826, 28898
[2022-10-27 02:35:44] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 154, 164, 169, 166, 158, 162, 166, 164, 145, 155, 153, 157, 28899
[2022-10-27 02:35:44] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 12, 11, 9, 8, 5, 250, 9, 10, 9, 9, 9, 9, 28900
[2022-10-27 02:35:44] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 133, 134, 28953
[2022-10-27 02:35:44] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 134, 135, 28954
[2022-10-27 02:35:44] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 28954
[2022-10-27 02:35:44] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -99, 28955
[2022-10-27 02:35:44] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 28955
[2022-10-27 02:35:44] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 28955
[2022-10-27 02:35:44] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -92, -192, -91, -96, -196, -86, -90, -193, 46686, 46261, 44806, 33530, 33788, 32481, 21764, 21446, 21195, 28976
[2022-10-27 02:35:44] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33412, 15776, 0, 0, -91, -92, 0, 0, 46, 47, 0, 0, 28976
[2022-10-27 02:35:44] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33612, 16094, 0, 0, -97, -97, 0, 0, 47, 48, 0, 0, 28977
[2022-10-27 02:35:44] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32713, 15126, 0, 0, -196, -197, 0, 0, 49, 49, 0, 0, 28977
[2022-10-27 02:35:44] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 28957
[2022-10-27 02:35:44] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 28960
[2022-10-27 02:35:44] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 28962
[2022-10-27 02:35:44] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 28902
[2022-10-27 02:35:44] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 28902
[2022-10-27 02:35:44] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 28902
[2022-10-27 02:35:44] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1263, 232, 4849, 0, 28902
[2022-10-27 02:35:44] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 999, 100, 101, 0, 0, 0, 28903
[2022-10-27 02:35:44] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 28978
[2022-10-27 02:35:44] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, -718, 0, 1674, 0, 0, 0, 0, 28900
[2022-10-27 02:35:44] DeviceId [0] MonitoringReportHeader: 48, 44
[2022-10-27 02:35:44] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 44, 45, 45, 43, 45, 42, 0, 29495
[2022-10-27 02:35:44] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 289, 302, 295, 297, 298, 6352, 6392, 6740, 5964, 15870, 15828, 16124, 15530, 25898, 26092, 26568, 25494, 899509082, 865920858, 29498
[2022-10-27 02:35:44] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 159, 165, 168, 166, 156, 167, 166, 166, 144, 152, 153, 161, 29499
[2022-10-27 02:35:44] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2569, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 20, 21, 21, 20, 20, 8, 8, 9, 13, 11, 9, 8, 6, 250, 9, 9, 9, 9, 9, 9, 29500
[2022-10-27 02:35:44] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 29556
[2022-10-27 02:35:44] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 29557
[2022-10-27 02:35:44] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 137, 133, 134, 29557
[2022-10-27 02:35:44] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 29557
[2022-10-27 02:35:44] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -101, 29558
[2022-10-27 02:35:44] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 29558
[2022-10-27 02:35:44] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -86, -90, -193, 46783, 46809, 44597, 33438, 33300, 32244, 21910, 21530, 21687, 29579
[2022-10-27 02:35:44] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33626, 17075, 0, 0, -91, -92, 0, 0, 47, 47, 0, 0, 29579
[2022-10-27 02:35:44] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33300, 16728, 0, 0, -97, -97, 0, 0, 46, 47, 0, 0, 29580
[2022-10-27 02:35:44] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32138, 15536, 0, 0, -197, -197, 0, 0, 50, 50, 0, 0, 29580
[2022-10-27 02:35:44] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 29560
[2022-10-27 02:35:44] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 29563
[2022-10-27 02:35:44] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 29565
[2022-10-27 02:35:44] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 29502
[2022-10-27 02:35:44] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 29502
[2022-10-27 02:35:44] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 29502
[2022-10-27 02:35:44] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 606, 1126, 225, 2219, 1262, 232, 4854, 0, 29502
[2022-10-27 02:35:44] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 6002, 1999, 1000, 100, 101, 0, 0, 0, 29503
[2022-10-27 02:35:44] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 0, 29581
[2022-10-27 02:35:44] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 593, 0, 263, 0, 0, 0, 0, 29500
[2022-10-27 02:35:45] DeviceId [0] MonitoringReportHeader: 49, 44
[2022-10-27 02:35:45] DeviceId [0] TemperatureMonitoring: 31, 0, 45, 45, 45, 45, 45, 44, 43, 45, 42, 0, 30095
[2022-10-27 02:35:45] DeviceId [0] RXGainPhaseMonitoring: 15, 0, 0, 20, 20, 20, 292, 287, 285, 292, 292, 288, 286, 288, 302, 295, 297, 298, 6942, 6962, 7330, 6570, 16388, 16374, 16630, 16024, 25186, 25390, 25828, 24758, 865954650, 865920826, 30098
[2022-10-27 02:35:45] DeviceId [0] RXNoiseFigureMonitoring: 1, 0, 0, 158, 164, 169, 163, 152, 161, 167, 172, 143, 155, 154, 156, 30099
[2022-10-27 02:35:45] DeviceId [0] RXIFStageMonitoring: 7, 0, 0, 2313, 1, 0, 0, 255, 255, 0, 255, 1, 21, 21, 20, 21, 21, 21, 21, 20, 8, 8, 9, 13, 11, 9, 7, 6, 250, 10, 10, 9, 9, 9, 9, 30100
[2022-10-27 02:35:45] DeviceId [0] TX0PowerMonitoring: 3, 0, 0, 138, 134, 134, 30154
[2022-10-27 02:35:45] DeviceId [0] TX1PowerMonitoring: 3, 0, 0, 139, 135, 136, 30155
[2022-10-27 02:35:45] DeviceId [0] TX2PowerMonitoring: 3, 0, 0, 136, 133, 134, 30155
[2022-10-27 02:35:45] DeviceId [0] TX0BallBreakMonitoring: 1, 0, -100, 30155
[2022-10-27 02:35:45] DeviceId [0] TX1BallBreakMonitoring: 1, 0, -102, 30156
[2022-10-27 02:35:45] DeviceId [0] TX2BallBreakMonitoring: 1, 0, -92, 30156
[2022-10-27 02:35:45] DeviceId [0] TXGainPhaseMismatchMonitoring: 3, 0, 0, -89, -93, -192, -91, -97, -196, -85, -90, -193, 46857, 46849, 45090, 34122, 33640, 32416, 21301, 21224, 21553, 30177
[2022-10-27 02:35:45] DeviceId [0] Tx0PhaseShifterMonitoring: 3, 0, 0, 33223, 17703, 0, 0, -91, -92, 0, 0, 46, 46, 0, 0, 30177
[2022-10-27 02:35:45] DeviceId [0] Tx1PhaseShifterMonitoring: 3, 0, 0, 33538, 18010, 0, 0, -97, -97, 0, 0, 47, 47, 0, 0, 30178
[2022-10-27 02:35:45] DeviceId [0] Tx2PhaseShifterMonitoring: 3, 0, 0, 32264, 16710, 0, 0, -196, -197, 0, 0, 52, 52, 0, 0, 30178
[2022-10-27 02:35:45] DeviceId [0] IntTX0AnalogSignalMonitoring: 7, 0, 0, 30158
[2022-10-27 02:35:45] DeviceId [0] IntTX1AnalogSignalMonitoring: 7, 0, 0, 30160
[2022-10-27 02:35:45] DeviceId [0] IntTX2AnalogSignalMonitoring: 7, 0, 0, 30163
[2022-10-27 02:35:45] DeviceId [0] IntRxAnalogSignalMonitoring: 4095, 0, 0, 30102
[2022-10-27 02:35:45] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 6, 0, 0, 0, 30102
[2022-10-27 02:35:45] DeviceId [0] IntGPADCAnalogSignalMonitoring: 3, 0, 255, 685, 30102
[2022-10-27 02:35:45] DeviceId [0] PLLControlVoltageSignalMonitoring: 55, 0, 608, 1126, 225, 2219, 1262, 233, 4859, 0, 30102
[2022-10-27 02:35:45] DeviceId [0] DualClockComparatorMonitoring: 31, 0, 5996, 1999, 999, 100, 101, 0, 0, 0, 30103
[2022-10-27 02:35:45] DeviceId [0] RxMixerInputPowerMonitoring: 15, 0, 0, 65536, 30179
[2022-10-27 02:35:45] DeviceId [0] SynthFrequencyNonLiveMonitoring: 1, 0, 0, 671, 0, 2980, 0, 0, 0, 0, 30100
    Is it possible to share the report txt file directly so that I can easily open and delimit it in excel?
    Adrian
  • MonitoringReport.txt
    [2022-10-27 02:35:14] DeviceId [0] RFInitCalibStatus: 0x80001ffe, 0x1ffc, 42, 129
    [2022-10-27 02:35:14] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x612, 43, 338
    [2022-10-27 02:35:15] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 1378
    [2022-10-27 02:35:17] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 2582
    [2022-10-27 02:35:18] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 3776
    [2022-10-27 02:35:19] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 4981
    [2022-10-27 02:35:20] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 6175
    [2022-10-27 02:35:21] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 7381
    [2022-10-27 02:35:23] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 8580
    [2022-10-27 02:35:24] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 9774
    [2022-10-27 02:35:25] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 10978
    [2022-10-27 02:35:26] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 12182
    [2022-10-27 02:35:27] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 13377
    [2022-10-27 02:35:29] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 14576
    [2022-10-27 02:35:30] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 15781
    [2022-10-27 02:35:31] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 16980
    [2022-10-27 02:35:32] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 18175
    [2022-10-27 02:35:33] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 19379
    [2022-10-27 02:35:35] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 20573
    [2022-10-27 02:35:36] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 21777
    [2022-10-27 02:35:37] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 22982
    [2022-10-27 02:35:38] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 24181
    [2022-10-27 02:35:39] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 25381
    [2022-10-27 02:35:41] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 26581
    [2022-10-27 02:35:42] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 27778
    [2022-10-27 02:35:43] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 28978
    [2022-10-27 02:35:44] DeviceId [0] RunTimeCalibReport: 0x80001ffe, 0x0, 43, 30179
    [2022-10-27 02:35:14] DeviceId [0] MSSPowerUpDoneAsyncReport: 1673035, 0x40, 0x0, 0x0, 0x0
    [2022-10-27 02:35:14] DeviceId [0] BSSRFPowerUpDoneAsyncReport: 0x73bfefb, 2163569
    Hi Adrian,
         See attachments, thanks.
    Tim
  • Hi Adrian
    The following items seems error, it is in cascade condition, what's the reason cause this issue?
    [2022-10-27 03:57:52] DeviceId [0] IntPMCLKLOAnalogSignalMonitoring: 10, 0, 0, 21, 707
    6330.MonitoringReport.txt
    Thanks and best regards.
