LDC1614 has four measurement channels. In the process of testing, it was found that channel 0 was relatively stable. I would like to ask if there are differences in stability, sensitivity and accuracy among the four channels?
The LDC1614 channels are the same except for the high current drive feature. If you need to use the high current drive setting, it is only for CH0:
Otherwise, you should experience the same performance from the four different channels.
Justin Beigel
