Hi team,
Here are some questions need your confirm
Q1.Does HDC2022 require customers to calibrate the temperature and humidity? The official website says that our HDC2022 has been calibrated before leaving the factory. After a long time of use, how should customers calibrate?
Q2. If it needs to be calibrated, when will it be calibrated, and will it be calibrated every time it is turned on? How often should I calibrate if it is a long run device?
Q3. What is the maximum humidity excursion, is there a 60%+ humidity excursion?
YOURS
NAN
