AWR2243: TDA ARM FAILED
Part Number: AWR2243
We have a cascade radar AWR2243P, the scripts run fine until now. Suddenly, I get error with the file capture_cascade.lua : "TDA ARM Failed". I don't know what I might have changed to the scripts that introduce this error.
Alice
GM: Constructor
GM: Mon Apr 03 15:53:11 2023
RSTD.Transmit("/Settings")
[15:53:11]
[15:53:11] ### Running Startup script: "C:\ti\test\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
[15:53:11] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[15:53:11] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[15:53:11] Scripter ignored: Attempt to UnBuild() again or before Build.
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\test\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[15:53:11] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\test\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
[15:53:11] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[15:53:11] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[15:53:11] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[15:53:11] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[15:53:11] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[15:53:11] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[15:53:11] RSTD.Transmit("/")
[15:53:11] RSTD.SaveSettings(): Settings saved to "C:\Users\ar432\AppData\Roaming\RSTD\config.xml"
[15:53:11] RSTD.Build()
[15:53:11] RSTD.AL_Build()
[15:53:11] RSTD.AL_LoadXml()
[15:53:11] RSTD.AL_Init()
[15:53:11] RSTD.Clients_Build()
[15:53:11] GM: Init
[15:53:11] GM: Loaded 'C:\ti\test\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
[15:53:11] GM: 1 Guest (s) init
[15:53:11] GM: 1 Module(s) init
[15:53:11] GM: 2 Tab (s) init
[15:53:11] RSTD.Client_LoadXml()
[15:53:11] [RadarAPI]: ar1.selectRadarMode(0)
[15:53:11] [RadarAPI]: Status: Passed
[15:53:11] Matlab Runtime Engine is installed
[15:53:11] [RadarAPI]: Starting Matlab Engine..
[15:53:15] [RadarAPI]: Matlab Engine Started!
[15:53:15] [RadarAPI]: ar1.selectCascadeMode(0)
[15:53:15] [RadarAPI]: Status: Passed
[15:53:15] [RadarAPI]: ar1.LoadSettings('C:\Users\ar432\AppData\Roaming\RSTD\ar1gui.ini')
[15:53:16] TESTING = false
[15:53:16] RstdNet: Port 2777: Listening..
[15:53:16]
[15:53:16] ***Script completed successfully.***
[15:53:20] [RadarAPI]: ar1.selectRadarMode(1)
[15:53:20] [RadarAPI]: ar1.selectCascadeMode(1)
[15:53:20] [RadarAPI]: Status: Passed
[15:53:21] [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
[15:53:21] [RadarAPI]: Status: Passed
[15:53:22] [RadarAPI]: TDAStatusCallback Event Registered
[15:53:22] [RadarAPI]: registerTDAStatusCallback Status: Passed
[15:53:22] [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
[15:53:22] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:22] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug 5 2019 15:04:45[15:53:22] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:24] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:24] [RadarAPI]: ConnectTDACaptureCard Status: Passed
[15:53:24] TDA Capture Card Status : CONNECTED!
[15:53:30] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Configuration_MIMO.lua")
[15:53:32] Setting up Studio for Cascade started..
[15:53:32] [RadarAPI]: Connection to the TDA is already established!
[15:53:32] ConnectTDA Successful
[15:53:32] selectCascadeMode Successful
[15:53:32] Setting up Studio for Cascade ended..
[15:53:32] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:33] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:33] [RadarAPI]: ar1.FullReset(1)
[15:53:33] [RadarAPI]: Status: Passed
[15:53:33] [RadarAPI]: ar1.SOPControl_mult(1,4)
[15:53:33] Master : SOP Reset Successful
[15:53:33] [DeviceId-0] MSS power up done async event received!
[15:53:33] [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
[15:53:33] Master : SPI Connection Successful
[15:53:33] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin)
[15:53:36] Master : FW Download Successful
[15:53:37] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[15:53:37] [RadarAPI]: Status: Passed
[15:53:37] [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
[15:53:37] [RadarAPI]: ar1.frequencyBandSelection("77G")
[15:53:37] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[15:53:37] Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[15:53:37] [RadarAPI]: ar1.RfEnable_mult(1)
[15:53:37] [DeviceId-0] BSS power up done async event received!
[15:53:39] Master : RF Power Up Successful
[15:53:39] [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 1)
[15:53:39] [RadarAPI]: Status: Passed
[15:53:39] Master : Channel & ADC Configuration Successful
[15:53:39] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:40] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:40] [RadarAPI]: ar1.FullReset(2)
[15:53:40] [RadarAPI]: Status: Passed
[15:53:40] [RadarAPI]: ar1.SOPControl_mult(2,4)
[15:53:40] Device 2 : SOP Reset Successful
[15:53:40] [DeviceId-1] MSS power up done async event received!
[15:53:40] [RadarAPI]: ar1.AddDevice(2)
[15:53:40] Device 2 : SPI Connection Successful
[15:53:40] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:41] [RadarAPI]: ar1.FullReset(4)
[15:53:41] [RadarAPI]: Status: Passed
[15:53:41] [RadarAPI]: ar1.SOPControl_mult(4,4)
[15:53:41] Device 3 : SOP Reset Successful
[15:53:41] [DeviceId-2] MSS power up done async event received!
[15:53:41] [RadarAPI]: ar1.AddDevice(4)
[15:53:41] Device 3 : SPI Connection Successful
[15:53:41] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:53:42] [RadarAPI]: ar1.FullReset(8)
[15:53:42] [RadarAPI]: Status: Passed
[15:53:42] [RadarAPI]: ar1.SOPControl_mult(8,4)
[15:53:42] Device 4 : SOP Reset Successful
[15:53:42] [DeviceId-3] MSS power up done async event received!
[15:53:42] [RadarAPI]: ar1.AddDevice(8)
[15:53:42] Device 4 : SPI Connection Successful
[15:53:42] [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin)
[15:53:45] Slaves : FW Download Successful
[15:53:46] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[15:53:46] [RadarAPI]: Status: Passed
[15:53:46] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[15:53:46] Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[15:53:47] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[15:53:47] [RadarAPI]: Status: Passed
[15:53:47] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[15:53:47] Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[15:53:48] [RadarAPI]: ar1.SelectChipVersion("AR1243")
[15:53:48] [RadarAPI]: Status: Passed
[15:53:48] [RadarAPI]: ar1.SelectChipVersion("XWR2243")
[15:53:48] Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
[15:53:48] [RadarAPI]: ar1.RfEnable_mult(14)
[15:53:48] [DeviceId-2] BSS power up done async event received!
[15:53:48] [DeviceId-1] BSS power up done async event received!
[15:53:48] [DeviceId-3] BSS power up done async event received!
[15:53:53] Slaves : RF Power Up Successful
[15:53:53] [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 1, 1, 1, 1, 1, 2, 1, 0, 2)
[15:53:53] [RadarAPI]: Status: Passed
[15:53:53] Slaves : Channel & ADC Configuration Successful
[15:53:53] [RadarAPI]: ar1.RfLdoBypassConfig_mult(15, 0xF)
[15:53:54] LDO Bypass Successful
[15:53:54] [RadarAPI]: ar1.LPModConfig_mult(15, 0,0)
[15:53:54] [RadarAPI]: Status: Passed
[15:53:54] Low Power Mode Configuration Successful
[15:53:54] [RadarAPI]: ar1.SetMiscConfig_mult(15, 1, 0, 0, 0)
[15:53:54] Misc Control Configuration Successful
[15:53:54] [RadarAPI]: ar1.RfInitCalibConfig_mult(15, 1, 1, 1, 1, 1, 1, 1, 65537)
[15:53:54] RF Init Calibration Successful
[15:53:54] [RadarAPI]: ar1.RfInit_mult(15)
[15:53:54] [DeviceId-1] RF Init async event received!
[15:53:54] [DeviceId-2] RF Init async event received!
[15:53:54] [DeviceId-0] RF Init async event received!
[15:53:54] [DeviceId-3] RF Init async event received!
[15:53:54] [RadarAPI]: Time stamp, Temperture: 5547,33; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 0, 0;
[15:53:54] [RadarAPI]: Time stamp, Temperture: 16427,33; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 0, 0;
[15:53:54] [RadarAPI]: Time stamp, Temperture: 5547,33; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[15:53:54] RF Init Successful
[15:53:54] [RadarAPI]: ar1.DataPathConfig_mult(15, 0, 1, 0)
[15:53:54] Data Path Configuration Successful
[15:53:54] [RadarAPI]: ar1.LvdsClkConfig_mult(15, 1,1)
[15:53:54] Clock Configuration Successful
[15:53:54] [RadarAPI]: ar1.CSI2LaneConfig_mult(15, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
[15:53:54] CSI2 Configuration Successful
[15:53:54] [RadarAPI]: ar1.ProfileConfig_mult(15, 0, 77, 5, 6, 40, 0, 0, 0, 0, 0, 0, 78.986, 0, 256, 8000, 0, 0, 48)
[15:53:54] Profile Configuration successful
[15:53:54] [RadarAPI]: ar1.ChirpConfig_mult(1, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] [RadarAPI]: Status: Passed
[15:53:55] Device 1 : Chirp 0 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 1 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 2 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 3 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 4 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 5 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 6 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 7 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 1 : Chirp 8 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 9, 9, 0, 0, 0, 0, 0, 0, 0,1)
[15:53:55] Device 1 : Chirp 9 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 10, 10, 0, 0, 0, 0, 0, 0, 1,0)
[15:53:55] Device 1 : Chirp 10 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(1, 11, 11, 0, 0, 0, 0, 0, 1, 0,0)
[15:53:55] Device 1 : Chirp 11 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(2, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:55] Device 2 : Chirp 0 Configuration successful
[15:53:55] [RadarAPI]: ar1.ChirpConfig_mult(2, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] [RadarAPI]: Status: Passed
[15:53:56] Device 2 : Chirp 1 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 2 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 3 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 4 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 5 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 6, 6, 0, 0, 0, 0, 0, 0, 0,1)
[15:53:56] Device 2 : Chirp 6 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 7, 7, 0, 0, 0, 0, 0, 0, 1,0)
[15:53:56] Device 2 : Chirp 7 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 8, 8, 0, 0, 0, 0, 0, 1, 0,0)
[15:53:56] Device 2 : Chirp 8 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 9 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 10 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(2, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 2 : Chirp 11 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(4, 0, 0, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:56] Device 3 : Chirp 0 Configuration successful
[15:53:56] [RadarAPI]: ar1.ChirpConfig_mult(4, 1, 1, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] [RadarAPI]: Status: Passed
[15:53:57] Device 3 : Chirp 1 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 2, 2, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 2 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 3, 3, 0, 0, 0, 0, 0, 0, 0,1)
[15:53:57] Device 3 : Chirp 3 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 4, 4, 0, 0, 0, 0, 0, 0, 1,0)
[15:53:57] Device 3 : Chirp 4 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 5, 5, 0, 0, 0, 0, 0, 1, 0,0)
[15:53:57] Device 3 : Chirp 5 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 6 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 7 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 8 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 9 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 10 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(4, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:57] Device 3 : Chirp 11 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(8, 0, 0, 0, 0, 0, 0, 0, 0, 0,1)
[15:53:57] Device 4 : Chirp 0 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(8, 1, 1, 0, 0, 0, 0, 0, 0, 1,0)
[15:53:57] Device 4 : Chirp 1 Configuration successful
[15:53:57] [RadarAPI]: ar1.ChirpConfig_mult(8, 2, 2, 0, 0, 0, 0, 0, 1, 0,0)
[15:53:58] [RadarAPI]: Status: Passed
[15:53:58] Device 4 : Chirp 2 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 3, 3, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 3 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 4, 4, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 4 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 5, 5, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 5 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 6, 6, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 6 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 7, 7, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 7 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 8, 8, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 8 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 9, 9, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 9 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 10, 10, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 10 Configuration successful
[15:53:58] [RadarAPI]: ar1.ChirpConfig_mult(8, 11, 11, 0, 0, 0, 0, 0, 0, 0,0)
[15:53:58] Device 4 : Chirp 11 Configuration successful
[15:53:58] Test Source Already Disabled...!!!
[15:53:58] [RadarAPI]: ar1.DisableTestSource_mult(1,0)
[15:53:58] [RadarAPI]: ar1.FrameConfig_mult(1, 0, 11, 10, 64, 100, 0, 1)
[15:53:59] [RadarAPI]: Status: Passed
[15:53:59] Master : Frame Configuration successful
[15:53:59] Test Source Already Disabled...!!!
[15:53:59] [RadarAPI]: ar1.DisableTestSource_mult(14,0)
[15:53:59] [RadarAPI]: ar1.FrameConfig_mult(14, 0, 11, 10, 64, 100, 0, 2)
[15:53:59] Slaves : Frame Configuration successful
[15:53:59]
[15:53:59] ***Script completed successfully.***
[15:54:23] LuaLoad("C:/ti/mmwave_studio_03_00_00_14/mmWaveStudio/Scripts/Cascade/Cascade_Capture.lua")
[15:54:24] Loops Remaining : 1
[15:54:24] Starting TDA ARM...
[15:54:24] [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, 3maway_turned90degreee_bent30degree, 0)
[15:54:24] Device 0 - Configuring TDA with Width : 2048 and Height : 768
[15:54:24] [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
[15:54:24] Device 1 - Configuring TDA with Width : 2048 and Height : 768
[15:54:24] [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:54:24] [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
[15:54:24] Device 2 - Configuring TDA with Width : 2048 and Height : 768
[15:54:24] [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:54:24] [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
[15:54:24] Device 3 - Configuring TDA with Width : 2048 and Height : 768
[15:54:24] [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
[15:54:24] [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:54:24] Sending Frame Periodicity of 100 to TDA..
[15:54:24] [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:54:24] [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
[15:54:24] [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
[15:54:24] Sending Capture Directory with name /mnt/ssd/3maway_turned90degreee_bent30degree to TDA..
[15:54:24] [RadarAPI]: Status: Passed. Capture Directory sent to TDA
[15:54:24] Sending File Allocation of 0 files to TDA..
[15:54:24] [RadarAPI]: Status: Passed. File Allocation sent to TDA
[15:54:24] Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
[15:54:24] [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
[15:54:24] Sending Number of frames to capture with value of 0 to TDA..
[15:54:24] [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
[15:54:24] [RadarAPI]: Status: Passed for notifying TDA about Creating Application
[15:54:34] Create Application Response from Capture Card timed out!!
[15:54:34] TDA ARM Failed
[15:54:34]
[15:54:34] ***Script completed successfully.***
    did you make any progress on that one? I have exactly the same error.
    BR Christian
  • Hi, No we are still stuck
  • Hi, meanwhile I found out that this only occurs when using the MMW Studio. When using the C-Code (mmwavelink_examle.exe) everything works.
  • Hi Alice,
    Can you perform a quick comparison of both and let me know what has been changed?
    Kaushik
  • Hi, we tried to configure the radar with the gui instead of running the lua scripts and we get exactly the same error when we press TDAxxARM in the sensor config tab. I copy paste the output files below.
    GM: Constructor
    GM: Mon Apr 24 14:21:37 2023
    [14:21:38]
    [14:21:38]  ### Running Startup script: "C:\ti\test\mmwave_studio_03_00_00_14\mmWaveStudio\Scripts\Startup.lua" ###
    [14:21:38]  RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
    [14:21:38]  RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
    [14:21:38]  Scripter ignored: Attempt to UnBuild() again or before Build.
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\test\\mmwave_studio_03_00_00_14\\mmWaveStudio\\Clients\\\\LabClient.dll")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
    [14:21:38]  RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\test\\mmwave_studio_03_00_00_14\\mmWaveStudio\\RunTime\\SAL.dll")
    [14:21:38]  RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
    [14:21:38]  RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
    [14:21:38]  RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
    [14:21:38]  RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
    [14:21:38]  RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
    [14:21:38]  RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
    [14:21:38]  RSTD.Transmit("/")
    [14:21:38]  RSTD.SaveSettings(): Settings saved to "C:\Users\ar432\AppData\Roaming\RSTD\config.xml"
    [14:21:38]  RSTD.Build()
    [14:21:38]  RSTD.AL_Build()
    [14:21:38]  RSTD.AL_LoadXml()
    [14:21:38]  RSTD.AL_Init()
    [14:21:38]  RSTD.Clients_Build()
    [14:21:38]  GM: Init
    [14:21:38]  GM: Loaded 'C:\ti\test\mmwave_studio_03_00_00_14\mmWaveStudio\Clients\\LabClient.dll'
    [14:21:38]  GM: 1 Guest (s) init
    [14:21:38]  GM: 1 Module(s) init
    [14:21:38]  GM: 2 Tab   (s) init
    [14:21:38]  RSTD.Client_LoadXml()
    [14:21:38]  [RadarAPI]: ar1.selectRadarMode(0)
    [14:21:38]  [RadarAPI]: Status: Passed
    [14:21:38]  Matlab Runtime Engine is installed
    [14:21:38]  [RadarAPI]: Starting Matlab Engine..
    [14:21:44]  [RadarAPI]: Matlab Engine Started!
    [14:21:45]  [RadarAPI]: ar1.selectCascadeMode(0)
    [14:21:45]  [RadarAPI]: Status: Passed
    [14:21:45]  [RadarAPI]: ar1.LoadSettings('C:\Users\ar432\AppData\Roaming\RSTD\ar1gui.ini')
    [14:21:45]  TESTING = false
    [14:21:45]  RstdNet: Port 2777: Listening..
    [14:21:45]
    [14:21:45]  ***Script completed successfully.***
    [14:21:50]  [RadarAPI]: ar1.selectRadarMode(1)
    [14:21:50]  [RadarAPI]: ar1.selectCascadeMode(1)
    [14:21:50]  [RadarAPI]: Status: Passed
    [14:21:53]  [RadarAPI]: ar1.SelectCaptureDevice("TDA2XX")
    [14:21:53]  [RadarAPI]: Status: Passed
    [14:21:54]  [RadarAPI]: TDAStatusCallback Event Registered
    [14:21:54]  [RadarAPI]: registerTDAStatusCallback Status: Passed
    [14:21:54]  [RadarAPI]: ar1.ConnectTDA("192.168.33.180", 5001, 15)
    [14:21:54]  [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:21:54]  [RadarAPI]: Device 32 : CAPTURE_RESPONSE_VERSION_INFO Async event recieved() with status 0. TDA Version : REL_VISION_SDK_03_07_01_00 Aug  5 2019 15:04:45[14:21:54]  [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:21:56]  [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:21:56]  [RadarAPI]: ConnectTDACaptureCard Status: Passed
    [14:21:56]  TDA Capture Card Status : CONNECTED!
    [14:22:30]  [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:22:30]  [RadarAPI]: ar1.FullReset(1)
    [14:22:30]  [RadarAPI]: Status: Passed
    [14:22:30]  [RadarAPI]: ar1.SOPControl_mult(1,4)
    [14:22:36]  [DeviceId-0] MSS power up done async event received!
    [14:22:36]  [RadarAPI]: ar1.PowerOn_mult(1, 0, 1000, 0,0)
    [14:22:36]  [RadarAPI]: Status: Passed
    [14:22:49]  [RadarAPI]: ar1.DownloadBSSFw_mult(1,"C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin")
    [14:22:49]  [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(1, C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin)
    [14:22:58]  [RadarAPI]: ar1.SelectChipVersion("AR1243")
    [14:22:58]  [RadarAPI]: Status: Passed
    [14:22:58]  [RadarAPI]: ar1.deviceVariantSelection("XWR2243")
    [14:22:58]  [RadarAPI]: ar1.frequencyBandSelection("77G")
    [14:22:58]  [RadarAPI]: ar1.SelectChipVersion("XWR2243")
    [14:22:58]  Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
    [14:22:58]  [RadarAPI]: ar1.RfEnable_mult(1)
    [14:22:58]  [DeviceId-0] BSS power up done async event received!
    [14:23:15]  [RadarAPI]: ar1.ChanNAdcConfig_mult(1, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 1)
    [14:23:15]  [RadarAPI]: Status: Passed
    [14:23:28]  [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:23:28]  [RadarAPI]: ar1.FullReset(2)
    [14:23:28]  [RadarAPI]: Status: Passed
    [14:23:28]  [RadarAPI]: ar1.SOPControl_mult(2,4)
    [14:23:31]  [DeviceId-1] MSS power up done async event received!
    [14:23:31]  [RadarAPI]: ar1.AddDevice(2)
    [14:23:31]  [RadarAPI]: Status: Passed
    [14:23:38]  [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:23:39]  [RadarAPI]: ar1.FullReset(4)
    [14:23:39]  [RadarAPI]: Status: Passed
    [14:23:39]  [RadarAPI]: ar1.SOPControl_mult(4,4)
    [14:23:43]  [DeviceId-2] MSS power up done async event received!
    [14:23:43]  [RadarAPI]: ar1.AddDevice(4)
    [14:23:43]  [RadarAPI]: Status: Passed
    [14:23:49]  [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:23:50]  [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:23:50]  [RadarAPI]: ar1.FullReset(8)
    [14:23:50]  [RadarAPI]: Status: Passed
    [14:23:50]  [RadarAPI]: ar1.SOPControl_mult(8,4)
    [14:23:52]  [DeviceId-3] MSS power up done async event received!
    [14:23:52]  [RadarAPI]: ar1.AddDevice(8)
    [14:23:52]  [RadarAPI]: Status: Passed
    [14:24:28]  [RadarAPI]: ar1.DownloadBSSFw_mult(14,"C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin")
    [14:24:28]  [RadarAPI]: ar1.DownloadBssFwOvSPI_mult(14, C:\\ti\\mmwave_dfp_02_02_03_01\\firmware\\xwr22xx_metaImage.bin)
    [14:24:39]  [RadarAPI]: ar1.SelectChipVersion("AR1243")
    [14:24:39]  [RadarAPI]: Status: Passed
    [14:24:39]  [RadarAPI]: ar1.SelectChipVersion("XWR2243")
    [14:24:39]  Slave1 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
    [14:24:39]  [RadarAPI]: ar1.RfEnable_mult(2)
    [14:24:39]  [DeviceId-1] BSS power up done async event received!
    [14:24:46]  [RadarAPI]: ar1.SelectChipVersion("AR1243")
    [14:24:46]  [RadarAPI]: Status: Passed
    [14:24:46]  [RadarAPI]: ar1.SelectChipVersion("XWR2243")
    [14:24:46]  Slave2 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
    [14:24:46]  [RadarAPI]: ar1.RfEnable_mult(4)
    [14:24:47]  [DeviceId-2] BSS power up done async event received!
    [14:24:47]  [RadarAPI]: Status: Passed
    [14:24:54]  [RadarAPI]: ar1.SelectChipVersion("AR1243")
    [14:24:54]  [RadarAPI]: Status: Passed
    [14:24:54]  [RadarAPI]: ar1.SelectChipVersion("XWR2243")
    [14:24:54]  Slave3 Device Status : XWR2243/ASIL-B/SOP:4/ES:1.1
    [14:24:54]  [RadarAPI]: ar1.RfEnable_mult(8)
    [14:24:54]  [DeviceId-3] BSS power up done async event received!
    [14:25:11]  [RadarAPI]: ar1.ChanNAdcConfig_mult(14, 1, 1, 0, 1, 1, 1, 1, 2, 1, 0, 2)
    [14:25:12]  [RadarAPI]: Status: Passed
    [14:25:38]  [RadarAPI]: ar1.LPModConfig_mult(14, 0,0)
    [14:25:39]  [RadarAPI]: Status: Passed
    [14:25:43]  [RadarAPI]: ar1.SetCalMonFreqLimitConfig_mult(14,77,81)
    [14:25:43]  [RadarAPI]: Status: Passed
    [14:25:46]  [RadarAPI]: ar1.RfInit_mult(14)
    [14:25:46]  [DeviceId-2] RF Init async event received!
    [14:25:46]  [DeviceId-1] RF Init async event received!
    [14:25:46]  [RadarAPI]: Time stamp, Temperture: 59102,33; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
    [14:25:46]  [RadarAPI]: Time stamp, Temperture: 66759,32; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
    [14:25:46]  [DeviceId-3] RF Init async event received!
    [14:25:46]  [RadarAPI]: Time stamp, Temperture: 51738,32; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
    [14:25:46]  [RadarAPI]: Status: Passed
    [14:26:00]  [RadarAPI]: ar1.DataPathConfig_mult(14, 512, 1216644097, 0)
    [14:26:00]  [RadarAPI]: Status: Passed
    [14:26:01]  [RadarAPI]: ar1.LvdsClkConfig_mult(14, 1,1)
    [14:26:02]  [RadarAPI]: Status: Passed
    [14:26:04]  [RadarAPI]: ar1.CSI2LaneConfig_mult(14, 1, 0, 2, 0, 4, 0, 5,0,3,0, 0)
    [14:26:04]  [RadarAPI]: Status: Passed
    [14:26:54]  [RadarAPI]: ar1.ProfileConfig_mult(14, 0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 94)
    [14:26:54]  [RadarAPI]: Status: Passed
    [14:26:55]  [RadarAPI]: ar1.ChirpConfig_mult(14, 0, 0, 0, 0, 0, 0, 0, 1, 0,0)
    [14:26:55]  [RadarAPI]: Status: Passed
    [14:27:21]  Test Source Already Disabled...!!!
    [14:27:21]  [RadarAPI]: ar1.DisableTestSource_mult(14,0)
    [14:27:22]  [RadarAPI]: Status: Passed
    [14:27:22]  [RadarAPI]: ar1.FrameConfig_mult(14, 0, 0, 8, 128, 40, 0, 2)
    [14:28:00]  [RadarAPI]: ar1.TDACaptureCard_StartRecord_mult(1, 0, 0, adc_data, 0)
    [14:28:00]  Device 0 - Configuring TDA with Width : 0 and Height : 0
    [14:28:00]  [RadarAPI]: Device 0 - setWidthAndHeight Status: Passed
    [14:28:00]  Device 1 - Configuring TDA with Width : 2048 and Height : 128
    [14:28:00]  [RadarAPI]: Device 1 - setWidthAndHeight Status: Passed
    [14:28:00]  [RadarAPI]: Device 1 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:00]  Device 2 - Configuring TDA with Width : 2048 and Height : 128
    [14:28:00]  [RadarAPI]: Device 2 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:00]  [RadarAPI]: Device 2 - setWidthAndHeight Status: Passed
    [14:28:00]  [RadarAPI]: Device 4 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:00]  Device 3 - Configuring TDA with Width : 2048 and Height : 128
    [14:28:00]  [RadarAPI]: Device 3 - setWidthAndHeight Status: Passed
    [14:28:00]  Sending Frame Periodicity of 0 to TDA..
    [14:28:00]  [RadarAPI]: Status: Passed. Frame Periodicity sent to TDA
    [14:28:00]  [RadarAPI]: Device 8 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:00]  [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:01]  Sending Capture Directory with name /mnt/ssd/adc_data to TDA..
    [14:28:01]  [RadarAPI]: Status: Passed. Capture Directory sent to TDA
    [14:28:01]  [RadarAPI]: Device 32 : CAPTURE_RESPONSE_ACK Async event recieved() with status 0
    [14:28:01]  Sending File Allocation of 0 files to TDA..
    [14:28:01]  [RadarAPI]: Status: Passed. File Allocation sent to TDA
    [14:28:01]  Sending Enable Data Packaging (0 - 16-bit; 1 - 12-bit) with value of 0 to TDA..
    [14:28:01]  [RadarAPI]: Status: Passed. Enable Data Packaging sent to TDA
    [14:28:01]  Sending Number of frames to capture with value of 0 to TDA..
    [14:28:01]  [RadarAPI]: Status: Passed. Number of frames to capture sent to TDA
    [14:28:01]  [RadarAPI]: Status: Passed for notifying TDA about Creating Application
    [14:28:11]  Create Application Response from Capture Card timed out!!
  • Hi Alice,
    As I had previously asked, can you mention if you are using the scripts that came with studio as it is, or have you made any changes to that? Additionally, have you made sure you have all the right user permissions for mmwave studio?
    Kaushik
  • Hi. we solved the issue, turned out the ssd card was full.
