Hello Team,
I would like to know the maximum frame rate and the bit rate for the AWRL6432BOOST? I tried to check documents and SDK examples it seems that this information is not available.
Renan
Hello Team,
Renan
Hi Renan,
The frame rate depends on the other parameters included in the chirp configuration. You should ensure that the total chirp time and required processing time can fit into a single frame period.
Please refer to the tuning guide for further details. It can be found here:
MMWAVE_L_SDK_05_02_00_02/docs/MotionPresenceDetectionDemo_TuningGuide.pdf
You can also test configurations through the sensing estimator which has automatic checks for the frame rate
It is linked here:
Raymond Zhao
