TMP451: THERM pin setting to trigger under 0degC
Part Number: TMP451
Hi TI Team,
I would like to use the THERM pin available on your sensor to trigger when local temperature goes above the -5deg celsius.
Providing that the sensor is working on "extended temperature range configuration" mode, would be possible, in general, to set the THERM pin to trigger also for temperatures below 0degC?
Thanks in Advance,
A.M.
