We used this module with the 'Traffic Monitor' application and we would like to understand what is the FOV of this application.
Please let us know while assuming a usage of the default parameters within the SDK.
Neta
Neta
The FOV is related to the features of the antenna.
Please review in the AWR1843BOOST EVM User Guide, Figure 11 and Figure 12 the azimuth and elevation antenna patterns
https://www.ti.com/lit/ug/spruim4b/spruim4b.pdf
Thank you
Cesar
Hi Cesar,
Thanks for the answer, but what is the used FOV when using the 'Traffic Monitor' application.
Neta
This application uses the AWR1843BOOST board. The FOV is characterized by the antenna patterns provided in the EVM User Guide.
For example, if you look at the azimuth antenna pattern, you can notice that at 6dB from max gain, the FOV is about +/- 60deg
thank you
Cesar
