Other Parts Discussed in Thread: PGA305
Hi IT-Team,
We have a differential pressure sensor with a sensitivity of ~ +-20mV/V.
The sensor signal must be linearized and temperature compensated and the output should be read out both analogue and digitally.
When searching I found PGA305, PG900.
Now my question: is it possible to configure the output signal of these ICs with a zero offset, e.g. 2V, and the signal would then
be e.g. 2V +- 1V so that we can represent the differential pressure in the output voltage? Unfortunately I couldn't find anything in the data sheet or the application notes.
Thank you for your help.
Kind regards,
Michael
