Other Parts Discussed in Thread: DDC112
I am in the process of designing a sensitive photosensor system, capable of measuring low photocurrents: as a reference, the dark current of the photosensor will be in the order of 10-100 pA. The light output to be measured is a steady, low intensity light source above the dark current.
For this application I was thinking about the following architecture, based on a switched integrator as TIA stage, as shown in the sketch below. Two comparators + timers will provide data conversion.
-Any comments or suggestions about the proposed solution?
-The IVC102 seems a good candidate for the application, or am I missing something? Any leakage issues to foresee?
-Other components or architectures to suggest?
Thank you!
DP
