I want to use gstreamer plugins (gst-plugins-good-1.22.7) to split video in tda4vm EVM as a node, call video_encode.but I find not cannot finish split video every 5 minutes.The problem is the split video is less 5 minutes,and the split video has some duplicate frames and is random.
void construct_gst_strings(NMVideoEncodeConfig *config) {
ENTRY_LOG
int32_t i = 0;
for (uint8_t ch = 0; ch < gst_wrapper_params.in_num_channels; ch++) {
snprintf(gst_wrapper_params.m_AppSrcNameArr[ch], 32u, "myAppSrc%d", ch);
i += snprintf(&gst_wrapper_params.m_cmdString[i], CODEC_MAX_LEN_CMD_STR - i,
"appsrc format=GST_FORMAT_TIME is-live=true "
"do-timestamp=true block=false name=%s ! queue \n",
gst_wrapper_params.m_AppSrcNameArr[ch]);
i += snprintf(
"! video/x-raw, width=(int)%d, height=(int)%d, "
"framerate=(fraction)30/1, format=(string)%s, "
"interlace-mode=(string)progressive, colorimetry=(string)bt601 \n",
gst_wrapper_params.in_width, gst_wrapper_params.in_height,
gst_wrapper_params.in_format);
"! v4l2h264enc bitrate=%d \n", config->bitrate);
"! h264parse \n");
if (config->enable_split) {
"! splitmuxsink location=%s/output_video_%d_%%d.264 "
"max-size-time=300000000000\n",
config->storage_path, ch);
} else {
"! filesink location=%s/output_video_%d.264 \n",
EXIT_LOG
