Other Parts Discussed in Thread: IWRL6432
Hello TI
I am going to test the example of Doorbell using AWRL6432BOOST.
What cfg files and examples are used in the picture below?
I want to know an example where the target area is detected.
Thanks.
Hello TI
Thanks.
This demo uses the code in the Video Doorbell example in TiRex. See link here.
Nate
The configuration files used in the video are outdated. They have been updated with the configuration files given below. If you want an example of a single boundary box, you can add it in the configuration file. Simply remove the BoundaryBox and BoundaryArc lines in the configuration file and use
BoundaryBox 1 -2 2 0 7 0 2
Nate
The visualizer code is written using the open source pyQT framework. You are free to modify it how you please, however, we will not be able to support this request on the forum as it does not relate to the IWRL6432 device.
Nate
