Subject : Enable Cache
1. In ARM Cortex-R Series Programmer Guide - version 1.0 , Link - "">developer.arm.com/.../System-Control-Register--SCTLR-"
a) In System Control Register (SCTLR) -
"I" bit - enables/disables Instruction cache
"C" bit - enables/disable data and unified caches
b) In MPU configuration - MPU shall be enabled and the memory regions flags (for L1, MSS_L2 and DSS_L3 regions) can be defined as per the project needs.
2. This conflicts with another document -Cortex-R5 Technical reference Manual r1p2, Link - "">developer.arm.com/.../c1--System-Control-Register
a) In System Control Register (SCTLR ) -
"I" bit - Enables/disables L1 Instruction Cache
"C" bit - enables/disable L1 data and unified caches
Here L1 memory is TCM memories and this around 128K.
If these instructions only enables the TCM memory , then how to enable Cache for MSS_L2, DSS_L3 memories?
b) What is the impact of MPU configuration and defining the Memory region flags (for L1, MSS_L2 and DSS_L3 regions) in this case?
3. Can you please provide us the latest versions of the technical reference manuals and Programmers Guide for ArM cortex R5 to have consistent documents within our teams?
Sheela
