We want to develop a frequency strength detector using awrl1432 to detect a 77Ghz signal coming from another cars.
When I checked exmaples here, I think there doesn't seems to have an example of this kind of stuff. Could you recommend an best example code for our target system?
And I have some questions on SW for AWRL1432.
I'd like to check the approximate amount of the scope that can be modified by SW.
Could you check our questions below?
- Is it possible to adjust the Chirp frequency range?
If yes, could you advise how to change it?
- Is it possible to adjust the Chirp period or cycle?
- Is it possible to adjust the number of ADC buffers and sample frequency of each Chirp?
- When I look at your examples, most of them seem to use saw-tooth wave chirp. Right?
Any other chirp could be implemeted?
- Do you support Both realFFT or ComplexFFT, so can I slect one of them?
- What kind of window-functions are provided? Chebishev or Keiser is provided?
- Does your sw support SlidingDFT?
Thanks in advance for your reply.
KS
