AWR2944EVM: mmWave Demo visualizer tool H/W not detected
Hello Adrian,
Thanks for your prompt reply. I had followed your instruction and was able to flash the board successfully. After flashing the board, when i tried to run the board in mmWave Demo visulaizer tool, still was facing the same issue of H/W not detected.
Need your guidance in this aspect that how to run the demo visulaizer and visulaize the plots
    To avoid confusion I will close the other thread since you have created a new thread.
    Can you confirm you switched to SOP4 mode (only SOP0 is shorted) and power cycled the board? Also, please confirm which baud rates you have set and for which ports you have set the baud rates.
    Adrian
