Can you provide me with CLI commands for sdk v02.01.01.00 , IWR6843ISK.
cause I have this matlab script which is for sdk v03.03.00.01 and I got error Invalid command (alk\bin\config_default.json).error -4048.
function [cfg] = defineCLICommands(sdkVersion, demoType)
%Supports CLIs as defined in SDK 3.3.x
%TODO: Add support for different SDK versions
cfg = struct('command', [], 'parameters', [], 'units', []);
switch sdkVersion(1:5)
case '03.03'
i=1;
cfg(i).command = 'dfeDataOutputMode';
cfg(i).parameters = struct('modeType', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'channelCfg';
cfg(i).parameters = struct('rxChannelEn', 0, 'txChannelEn', 0, 'cascading', 0);
cfg(i).units = {'', '', ''};
i=i+1;
cfg(i).command = 'adcCfg';
cfg(i).parameters = struct('numADCBits', 0, 'adcOutputFmt', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'adcbufCfg';
cfg(i).parameters = struct('subFrameidx', 0, 'adcOutputFmt', 0, 'sampleSwap', 0, ...
'chanInterleave', 0, 'chirpThreshold', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'profileCfg';
cfg(i).parameters = struct('profileId', 0, 'startFreq', 0, 'idleTime', 0, ...
'adcStartTime', 0, 'rampEndTime', 0, 'txOutPower', 0, 'txPhaseShifter', 0,...
'freqSlopeConst', 0, 'txStartTime', 0, 'numADCSamples', 0,...
'digOutSampleRate', 0, 'hpfCornerFreq1', 0, 'hpfCofnerFreq2', 0,...
'rxGain', 0);
cfg(i).units = {'-', 'GHz', 'usec', 'usec', 'usec', '-', '-', 'MHz/usec'};
i=i+1;
cfg(i).command = 'chirpCfg';
cfg(i).parameters =struct('chirpStartIndex', 0, 'chirpEndIndex', 0, ...
'profileIdentifier', 0, 'startFrequencyVariation', 0, ...
'frequencySlopeVariation', 0, 'idleTimeVariation', 0, ...
'adcStartTimeVariation', 0, 'txEnableMask', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'lowPower';
cfg(i).parameters = struct('DNC', 0, 'adcMode', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'frameCfg';
cfg(i).parameters = struct('chirpStartIndex', 0, 'chirpEndIndex', 0, ...
'numLoops', 0, 'numFrames', 0, 'framePeriodicity', 0, ...
'triggerSelect', 0, 'frameTriggerDelay', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'advFrameCfg';
cfg(i).parameters = struct('numOfSubFrames', 0, 'forceProfile', 0, ...
'numFrames', 0, 'triggerSelect', 0, 'frameTrigDelay', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'subFrameCfg';
cfg(i).parameters = struct('subFrameNum', 0, 'forceProfileIdex', 0, ...
'chirpStartIdx', 0, 'numOfChirps', 0, 'numLoops', 0, ...
'burstPeriodicity', 0, 'chirpStartIdxOffset', 0, 'numOfBurst', 0,...
'numOfBurstLoops', 0, 'subFramePeriodicity', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'guiMonitor';
cfg(i).parameters = struct('subFrameIdx', 0, 'detectedObjects', 0, 'logMagRange', 0,...
'noiseProfile', 0, 'rangeAzimuthHeatMap', 0, 'rangeDopplerHeatMap', 0,...
'statsInfo', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'cfarCfg';
cfg(i).parameters = struct('subFrameIdx', 0, 'procDirection', 0, 'mode', 0,...
'noiseWin', 0, 'guardLen', 0, 'divShift', 0,...
'cyclicWrapMode', 0, 'thresholdScale', 0, 'peakGrouping', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'multiObjBeamForming';
cfg(i).parameters = struct('subFrameIdx', 0, 'featureEnabled', 0, 'threshold', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'calibDcRangeSig';
cfg(i).parameters = struct('subFrameIdx', 0, 'enabled', 0, 'negativeBinIdx', 0,...
'positiveBinIdx', 0, 'numAvg', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'clutterRemoval';
cfg(i).parameters = struct('subFrameIdx', 0, 'enabled', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'aoaFovCfg';
cfg(i).parameters = struct('subFrameIdx', 0, 'minAzimuthDeg', 0, 'maxAzimuthDeg', 0, 'minElevationDeg', 0, 'maxElevationDeg', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'cfarFovCfg';
cfg(i).parameters = struct('subFrameIdx', 0, 'procDirection', 0, 'min', 0, 'max', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'compRangeBiasAndRxChanPhase';
cfg(i).parameters = struct('rangeBias', 0, 'Re_VA_1', 0, 'Im_VA_1', 0,...
'Re_VA_2', 0, 'Im_VA_2', 0, 'Re_VA_3', 0, 'Im_VA_3', 0, 'Re_VA_4', 0,...
'Im_VA_4', 0, 'Re_VA_5', 0, 'Im_VA_5', 0, 'Re_VA_6', 0, 'Im_VA_6', 0,...
'Re_VA_7', 0, 'Im_VA_7', 0 ,'Re_VA_8', 0, 'Im_VA_8', 0 ,'Re_VA_9', 0,...
'Im_VA_9', 0, 'Re_VA_10', 0, 'Im_VA_10', 0, 'Re_VA_11', 0, 'Im_VA_11', 0,...
'Re_VA_12', 0, 'Im_VA_12', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'measureRangeBiasAndRxChanPhase';
cfg(i).parameters = struct('enabled', 0, 'targetDistance', 0, 'searchWin', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'extendedMaxVelocity';
cfg(i).units = {};
i=i+1;
cfg(i).command = 'CQRxSatMonitor';
cfg(i).parameters = struct('profile', 0, 'satMonSel', 0, 'priSliceDuration', 0, 'numSlices', 0, 'rxChanMask',0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'CQSigImgMonitor';
cfg(i).parameters = struct('profile', 0, 'numSlices', 0, 'numSamplePerSlice',0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'analogMonitor';
cfg(i).parameters = struct('rxSaturation', 0, 'sigImgBand', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'lvdsStreamCfg';
cfg(i).parameters = struct('subFrameIdx', 0, 'enableHeader', 0, 'dataFmt', 0, 'enableSW', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'bpmCfg';
cfg(i).parameters = struct('subFrameIdx', 0, 'enabled', 0, 'chirp0Idx', 0, 'chirp1Idx', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'calibdata';
cfg(i).parameters = struct('saveEnable', 0, 'restoreEnable', 0, 'FlashOffset', 0);
cfg(i).units = {};
i = i+1;
cfg(i).command = 'configDataPort';
cfg(i).parameters = struct('baudrate', 0, 'ackPing', 0);
cfg(i).units = {};
otherwise
fprintf('Unsupported SDK version');
end
switch demoType
case 'TM'
i=i+1;
cfg(i).command = 'trackingCfg';
cfg(i).parameters = struct('enable', 0, 'reserved', 0, 'maxNumPoints', 0, 'maxNumTracks', 0, 'maxVel', 0, 'velRes', 0, 'framePeriod', 0, 'azimuthTilt', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'staticBoundaryBox';
cfg(i).parameters = struct('minX', 0, 'maxX', 0, 'minY', 0, 'maxY', 0, 'minZ', 0, 'maxZ', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'boundaryBox';
cfg(i).units = {};
i=i+1;
cfg(i).command = 'gatingParam';
cfg(i).parameters = struct('gain', 0, 'widthLimit', 0, 'depthLimit', 0, 'heightLimit', 0, 'velLimit', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'stateParam';
cfg(i).parameters = struct('det2act', 0, 'det2free', 0, 'active2free', 0, 'static2free', 0, 'exit2free', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'allocationParam';
cfg(i).parameters = struct('snrThreshold', 0, 'snrThresholdObscured', 0, 'minVel', 0, 'minPoints', 0, 'maxDistance', 0, 'maxVelocity', 0);
cfg(i).units = {};
i=i+1;
cfg(i).command = 'maxAcceleration';
cfg(i).parameters = struct('maxX', 0, 'maxY', 0, 'maxZ', 0);
cfg(i).units = {};
otherwise
end
end
