I am considering mmwave sensor.
Sorry for the rudimentary question, but please tell us about the following question.
Q1. I know that mmwave sensor have higher range accuracy than range resolution.
However, I do not understand why the range accuracy is higher than the drange resolution.
Could you please explain the principle?
Q2. If I want to improve the range resolution, which parameter of the chirp should I change?
And if I change that parameter, what performance will be reduced instead?
Q3. If I want to improve the range accuracy, which parameter of the chirp should I change?
