Other Parts Discussed in Thread: AWR1843AOPEVM, AWR1642BOOST,
pretty simple question, I have some sensors here and I'd like the know the difference, mostly in application.
It's between the similar AWR6843AOPEVM and AWR1843AOPEVM, aswell as the AWR1642BOOST.
I'm trying to build a robot that autonomously operates in an outdoor envoirnment, using ROS.
For this project I figured that besides LiDAR, mmWave radar sensors would work great.
So now I have these 3 sensors, that all have similar specs, use similar example projects in CCS, and all should work the same in ROS?
so what's the difference and which one should I use?
the robot will perform in both daylight and nighttime, during sunshine and rain. behind a glass/plastic cover that it has to see through.
Thanks in advance for any explanations, tips, or advice given.
