Other Parts Discussed in Thread: AWR1843BOOST, AWR1843
Hey i am not able to take raw data from DCA1000 and i using AWR1843BOOST radar for this and here i am attaching all my screenshots, and firewall settings etc.. and i have also disconnected wifi
Output::
[01:21:12]
[01:21:12] ### Running Startup script: "C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Scripts\Startup.lua" ###
[01:21:12] RSTD.SetAndTransmit ("/Settings/Scripter/Display DateTime" , "1")
[01:21:12] RSTD.SetAndTransmit ("/Settings/Scripter/DateTime Format" , "HH:mm:ss")
[01:21:12] Scripter ignored: Attempt to UnBuild() again or before Build.
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 0/Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\Clients\\\\LabClient.dll")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 0/Use" , "TRUE")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 1/Use" , "FALSE")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 2/Use" , "FALSE")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 3/Use" , "FALSE")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 4/Use" , "FALSE")
[01:21:12] RSTD.SetVar ("/Settings/AL Client/AL Dll" , "C:\\ti\\mmwave_studio_02_01_01_00\\mmWaveStudio\\RunTime\\SAL.dll")
[01:21:12] RSTD.SetVar ("/Settings/Clients/Client 0/GuiDll" , "")
[01:21:12] RSTD.SetVar ("/Settings/AutoUpdate/Enabled" , "TRUE")
[01:21:12] RSTD.SetVar ("/Settings/AutoUpdate/Interval" , "1")
[01:21:12] RSTD.SetVar ("/Settings/Monitors/UpdateDisplay" , "TRUE")
[01:21:12] RSTD.SetVar ("/Settings/Monitors/OneClickStart" , "TRUE")
[01:21:12] RSTD.SetVar ("/Settings/Automation/Automation Mode" , "false")
[01:21:12] RSTD.Transmit("/")
[01:21:12] RSTD.SaveSettings(): Settings saved to "C:\Users\roman\AppData\Roaming\RSTD\config.xml"
[01:21:12] RSTD.Build()
[01:21:13] RSTD.SaveSettings(): Settings saved to "C:\Users\roman\AppData\Roaming\RSTD\config.xml"
[01:21:13] RSTD.Transmit("/")
[01:21:13] RSTD.AL_Build()
[01:21:13] RSTD.AL_LoadXml()
[01:21:13] RSTD.AL_Init()
[01:21:13] RSTD.Clients_Build()
[01:21:13] GM: Init
[01:21:13] GM: Loaded 'C:\ti\mmwave_studio_02_01_01_00\mmWaveStudio\Clients\\LabClient.dll'
[01:21:13] GM: 1 Guest (s) init
[01:21:13] GM: 1 Module(s) init
[01:21:13] GM: 2 Tab (s) init
[01:21:13] RSTD.Client_LoadXml()
[01:21:13] [RadarAPI]: ar1.selectRadarMode(0)
[01:21:13] [RadarAPI]: Status: Passed
[01:21:13] Matlab Runtime Engine is installed
[01:21:13] [RadarAPI]: Starting Matlab Engine..
[01:21:27] [RadarAPI]: Matlab Engine Started!
[01:21:32] [RadarAPI]: ar1.selectCascadeMode(0)
[01:21:32] [RadarAPI]: Status: Passed
[01:21:32] [RadarAPI]: ar1.LoadSettings('C:\Users\roman\AppData\Roaming\RSTD\ar1gui.ini')
[01:21:32] TESTING = false
[01:21:32] RstdNet: Port 2777: Listening..
[01:21:32]
[01:21:32] ***Script completed successfully.***
[01:27:08] [RadarAPI]: Opening Gpio Control Port()
[01:27:08] [RadarAPI]: Status: Passed
[01:27:09] [RadarAPI]: Opening Board Control Port()
[01:27:09] [RadarAPI]: Status: Passed
[01:27:10] [RadarAPI]: ar1.FullReset()
[01:27:10] [RadarAPI]: Status: Passed
[01:27:10] [RadarAPI]: Closing Board Control Port()
[01:27:11] [RadarAPI]: Status: Passed
[01:27:11] [RadarAPI]: Closing Gpio Control Port()
[01:27:11] [RadarAPI]: ar1.SOPControl(2)
[01:27:11] [RadarAPI]: ar1.Connect(3,921600,1000)
[01:27:14] [RadarAPI]: Warning: Connected with baudrate 115200
[01:27:15] [RadarAPI]: Warning: Disconnected existing BaudRate
[01:27:15] [RadarAPI]: Warning: Trying to connect with baudrate 921600
[01:27:17] [RadarAPI]: ar1.Calling_IsConnected()
[01:27:18] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[01:27:18] [RadarAPI]: Status: Passed
[01:27:18] [RadarAPI]: ar1.deviceVariantSelection("XWR1843")
[01:27:18] [RadarAPI]: ar1.frequencyBandSelection("77G")
[01:27:18] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[01:27:18] Device Status : XWR1843/ASIL-B/SOP:2/ES:2
[01:27:19] [RadarAPI]: ar1.SaveSettings('C:\Users\roman\AppData\Roaming\RSTD\ar1gui.ini')
[01:27:20] [RadarAPI]: ar1.DownloadBSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\radarss\\xwr18xx_radarss.bin")
[01:27:21] [RadarAPI]: Downloading BSS Patch RPRC Binary..
[01:27:22] [RadarAPI]: ar1.GetBSSFwVersion()
[01:27:22] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[01:27:23] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[01:27:23] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[01:27:24] [RadarAPI]: ar1.DownloadMSSFw("C:\\ti\\mmwave_studio_02_01_01_00\\rf_eval_firmware\\masterss\\xwr18xx_masterss.bin")
[01:27:24] [RadarAPI]: Downloading MSS RPRC Binary..
[01:27:27] [RadarAPI]: ar1.GetMSSFwVersion()
[01:27:27] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[01:27:29] [RadarAPI]: ar1.PowerOn(0, 1000, 0, 0)
[01:27:29] [RadarAPI]: Status: Passed
[01:27:29] MSS power up done async event received!
[01:27:31] [RadarAPI]: ar1.SelectChipVersion("AR1642")
[01:27:31] [RadarAPI]: Status: Passed
[01:27:31] [RadarAPI]: ar1.SelectChipVersion("XWR1843")
[01:27:32] Device Status : XWR1843/ASIL-B/SOP:2/ES:2
[01:27:32] [RadarAPI]: ar1.RfEnable()
[01:27:32] BSS power up done async event received!
[01:27:32] [RadarAPI]: Status: Passed
[01:27:32] [RadarAPI]: ar1.GetMSSFwVersion()
[01:27:32] [RadarAPI]: MSSFwVersion:(01.02.05.02 (16/07/19))
[01:27:33] [RadarAPI]: ar1.GetBSSFwVersion()
[01:27:33] [RadarAPI]: BSSFwVersion:(02.00.00.01 (05/10/17))
[01:27:34] [RadarAPI]: ar1.GetBSSPatchFwVersion()
[01:27:34] [RadarAPI]: BSSPatchFwVersion:(01.02.05.02 (30/04/19))
[01:27:47] [RadarAPI]: ar1.ChanNAdcConfig(1, 1, 0, 1, 1, 1, 1, 2, 1, 0)
[01:27:47] [RadarAPI]: Status: Passed
[01:27:53] [RadarAPI]: ar1.LPModConfig(0, 0)
[01:27:53] [RadarAPI]: Status: Passed
[01:27:55] [RadarAPI]: ar1.RfInit()
[01:27:55] RF Init async event received!
[01:27:55] [RadarAPI]: Status: Passed
[01:27:55] [RadarAPI]: Time stamp, Temperture: 23045,45; APLL Status, Update: 1, 0; SynthVCO1 Status, Update: 1, 1; SynthVCO2 Status, Update: 1, 1; LODist Status, Update: 1, 1; RxADCDC Status, Update: 1, 1; HPFcutoff Status, Update: 1, 1; LPFcutoff Status, Update: 1, 1; PeakDetector Status, Update: 1, 1; TxPower Status, Update: 1, 1; RxGain Status, Update: 1, 1; TxPhase Status, Update: 1, 1; RxIQMM Status, Update: 1, 1;
[01:28:00] [RadarAPI]: ar1.DataPathConfig(513, 1216644097, 0)
[01:28:00] [RadarAPI]: Status: Passed
[01:28:03] [RadarAPI]: ar1.LvdsClkConfig(1, 1)
[01:28:03] [RadarAPI]: Status: Passed
[01:28:04] [RadarAPI]: ar1.LVDSLaneConfig(0, 1, 1, 0, 0, 1, 0, 0)
[01:28:04] [RadarAPI]: Status: Passed
[01:28:16] [RadarAPI]: ar1.ProfileConfig(0, 77, 100, 6, 60, 0, 0, 0, 0, 0, 0, 29.982, 0, 256, 10000, 0, 0, 30)
[01:28:16] [RadarAPI]: Status: Passed
[01:28:17] [RadarAPI]: ar1.ChirpConfig(0, 0, 0, 0, 0, 0, 0, 1, 0, 0)
[01:28:17] [RadarAPI]: Status: Passed
[01:28:19] Test Source Already Disabled...!!!
[01:28:19] [RadarAPI]: ar1.DisableTestSource(0)
[01:28:19] [RadarAPI]: Status: Passed
[01:28:19] [RadarAPI]: ar1.FrameConfig(0, 0, 8, 128, 40, 0, 0, 1)
[01:28:24] [RadarAPI]: ar1.GetCaptureCardDllVersion()
[01:28:24] [RadarAPI]: Sending dll_version command to DCA1000
[01:28:24] DLL Version : 1.0
[01:28:24] [RadarAPI]: ar1.SelectCaptureDevice("DCA1000")
[01:28:24] [RadarAPI]: Status: Passed
[01:28:26] [RadarAPI]: ar1.CaptureCardConfig_EthInit("192.168.33.30", "192.168.33.180", "12:34:56:78:90:12", 4096, 4098)
[01:28:26] [RadarAPI]: ar1.CaptureCardConfig_Mode(1, 2, 1, 2, 3, 30)
[01:28:26] [RadarAPI]: ar1.CaptureCardConfig_PacketDelay(25)
