Other Parts Discussed in Thread: MATHLIB
Hi TI Support,
I don't get any compilation errors, but I can't generate the .out file. Could you please provide a possible source of the problem?
makefile:
# All Target
all: $(OBJS) $(CMD_SRCS) $(GEN_CMDS)
@$(MAKE) --no-print-directory -Onone "platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.out"
# Tool invocations
platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.out: $(OBJS) $(CMD_SRCS) $(GEN_CMDS)
@echo 'Building target: "$@"'
@echo 'Invoking: Arm Linker'
@echo 'Flags: -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='"'"'<'"'"'ti/demo/awr294x/mmw/mmw_resDDM.h'"'"'>'"'"' -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -Wl,-m"platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.Debug.map" -Wl,-i"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -Wl,-i"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/drivers/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/board/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01/ti/control/mmwavelink/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/alg/gtrack/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/control/mmwave/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/control/dpm/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/cli/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/mathutils/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/testlogger/lib" -Wl,-i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/hsiheader/lib" -Wl,-i"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -Wl,-i"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -Wl,--reread_libs -Wl,--diag_suppress=10063 -Wl,--diag_wrap=off -Wl,--display_error_number -Wl,--warn_sections -Wl,--xml_link_info="platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang_linkInfo.xml" -Wl,--ram_model -Wl,--zero_init=on -Wl,--use_memcpy=fast -Wl,--use_memset=fast'
$(shell echo -m"platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.Debug.map" -i"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -i"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/drivers/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/board/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01/ti/control/mmwavelink/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/alg/gtrack/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/control/mmwave/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/control/dpm/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/cli/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/mathutils/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/testlogger/lib" -i"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02/ti/utils/hsiheader/lib" -i"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -i"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" --reread_libs --diag_suppress=10063 --diag_wrap=off --display_error_number --warn_sections --xml_link_info="platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang_linkInfo.xml" --ram_model --zero_init=on --use_memcpy=fast --use_memset=fast > "ccsLinker.opt")
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -Wl,"ccsLinker.opt" -Wl,ccsObjs.opt -o "platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.out"
@echo 'Finished building target: "$@"'
@echo ' '
@$(MAKE) --no-print-directory post-build
makefie product:
#define RB_NUM_BORDER_ELEMENTS (100u)
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c:25:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated\Rte_RbSwc.h:8:10: warning: 'RB_VAR_SINGLEBORDER' macro redefined [-Wmacro-redefined]
#define RB_VAR_SINGLEBORDER
<command line>:12:9: note: previous definition is here
#define RB_VAR_SINGLEBORDER 1
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c:59:15: warning: variable 'egoPathBuffer' set but not used [-Wunused-but-set-variable]
egoPath_t* egoPathBuffer;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c:173:10: warning: unused variable 'numPrevGapLines' [-Wunused-variable]
uint8 numPrevGapLines = 1u;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c:472:4: warning: call to undeclared function 'Sims_AddValue'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
Sims_AddValue("RBEgoPath_CycleArr", SIMS_GetCycleNum());
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c:472:40: warning: call to undeclared function 'SIMS_GetCycleNum'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
6 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoid.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c"
Invoking: Arm Compiler
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.d_raw" -MT"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.o" -o"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c"
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c:23:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.h:36:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/../rb_Border.h:39:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Variants_cfg.h:25:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder_cfg.h:32:9: warning: 'RB_NUM_BORDER_ELEMENTS' macro redefined [-Wmacro-redefined]
#define RB_NUM_BORDER_ELEMENTS (50u)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture_cfg.h:31:9: note: previous definition is here
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c:25:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c:90:12: warning: variable 'isFront' set but not used [-Wunused-but-set-variable]
boolean isFront;
3 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoClothoidMixture.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.d_raw" -MT"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.o" -o"External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c"
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:23:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.h:34:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src\rb_Border.h:39:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder_cfg.h:29:9: warning: 'RB_NUM_BORDERS' macro redefined [-Wmacro-redefined]
#define RB_NUM_BORDERS (1u)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9_cfg.h:30:9: note: previous definition is here
#define RB_NUM_BORDERS (2u)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9_cfg.h:32:9: note: previous definition is here
#define RB_NUM_BORDER_ELEMENTS (50)
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:26:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:394:64: warning: equality comparison with extraneous parentheses [-Wparentheses-equality]
if ((isCurrentLinePointOccluded[RB_VARPROTOREL9_STARTPOINT] == TRUE))
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:394:64: note: remove extraneous parentheses around the comparison to silence this warning
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:394:64: note: use '=' to turn this equality comparison into an assignment
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:583:46: warning: array index 1 is past the end of the array (which contains 1 element) [-Warray-bounds]
buffer->borders[1].elements, buffer->borders[1].nValidElements);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.h:61:4: note: array 'borders' declared here
rb_Border_t borders[RB_NUM_BORDERS];
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c:583:75: warning: array index 1 is past the end of the array (which contains 1 element) [-Warray-bounds]
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarProtoRel9.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.d_raw" -MT"External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.o" -o"External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype/rb_VarPrototype.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_BinLines.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_BinLines.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_BinLines.o" -o"External/gen40_trk_stef/rb/src/rb_BinLines.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_BinLines.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_BinLines.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Border.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Border.o" -o"External/gen40_trk_stef/rb/src/rb_Border.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:63:7: warning: call to undeclared function 'MATLAB_STORE_UINT32'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_UINT32("RB_CycleArr", SIMS_GetCycleNum());
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:63:42: warning: call to undeclared function 'SIMS_GetCycleNum'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:64:7: warning: call to undeclared function 'MATLAB_STORE_FLOAT'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_FLOAT("RB_PosX_m", self->elements[iElement].position.x);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:66:7: warning: call to undeclared function 'MATLAB_STORE_UINT8'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_UINT8("RB_IsConnectedToNext",(uint8)rb_Element_GetIsConnectedStatus(&(self->elements[iElement])));
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:84:7: warning: call to undeclared function 'MATLAB_STORE_UINT32'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_UINT32("RBLatPoint_CycleArr", SIMS_GetCycleNum());
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:84:50: warning: call to undeclared function 'SIMS_GetCycleNum'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:85:7: warning: call to undeclared function 'MATLAB_STORE_FLOAT'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_FLOAT("RBLatPoint_PosX_m", xPosition);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c:87:7: warning: call to undeclared function 'MATLAB_STORE_UINT8'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
MATLAB_STORE_UINT8("RBLatPoint_Quality", quality);
8 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_EgoDynamics.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_EgoDynamics.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_EgoDynamics.o" -o"External/gen40_trk_stef/rb/src/rb_EgoDynamics.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_EgoDynamics.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_EgoDynamics.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Element.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Element.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Element.o" -o"External/gen40_trk_stef/rb/src/rb_Element.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Element.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Element.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Extrapolator.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Extrapolator.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Extrapolator.o" -o"External/gen40_trk_stef/rb/src/rb_Extrapolator.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Extrapolator.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Extrapolator.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistCluster.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_HistCluster.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_HistCluster.o" -o"External/gen40_trk_stef/rb/src/rb_HistCluster.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistCluster.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistCluster.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistManager.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_HistManager.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_HistManager.o" -o"External/gen40_trk_stef/rb/src/rb_HistManager.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistManager.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_HistManager.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Histogram.c"
Invoking: Arm Compiler
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Histogram.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Histogram.o" -o"External/gen40_trk_stef/rb/src/rb_Histogram.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Histogram.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Histogram.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinReg.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_LinReg.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_LinReg.o" -o"External/gen40_trk_stef/rb/src/rb_LinReg.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinReg.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinReg.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LineSelector.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_LineSelector.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_LineSelector.o" -o"External/gen40_trk_stef/rb/src/rb_LineSelector.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LineSelector.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LineSelector.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinkedList.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_LinkedList.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_LinkedList.o" -o"External/gen40_trk_stef/rb/src/rb_LinkedList.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinkedList.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_LinkedList.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_MixtureBin.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_MixtureBin.o" -o"External/gen40_trk_stef/rb/src/rb_MixtureBin.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c"
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c:27:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin_priv.h:60:90: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier]
LOCAL uint8 rb_MixtureBins_GetModeUpdateIndex(rb_MixtureBin_t* const self, const float32 const updateValue);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin_priv.h:92:87: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier]
LOCAL void rb_MixtureBins_UpdateValidModes(rb_MixtureBin_t* const self, const float32 const updateValue);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c:96:87: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier]
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c:134:90: warning: duplicate 'const' declaration specifier [-Wduplicate-decl-specifier]
4 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBin.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBinArray.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_MixtureBinArray.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_MixtureBinArray.o" -o"External/gen40_trk_stef/rb/src/rb_MixtureBinArray.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBinArray.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureBinArray.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureMode.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_MixtureMode.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_MixtureMode.o" -o"External/gen40_trk_stef/rb/src/rb_MixtureMode.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureMode.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_MixtureMode.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Occlusion.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Occlusion.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Occlusion.o" -o"External/gen40_trk_stef/rb/src/rb_Occlusion.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Occlusion.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Occlusion.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_SeedPoints.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_SeedPoints.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_SeedPoints.o" -o"External/gen40_trk_stef/rb/src/rb_SeedPoints.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_SeedPoints.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_SeedPoints.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Segment.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Segment.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Segment.o" -o"External/gen40_trk_stef/rb/src/rb_Segment.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Segment.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Segment.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.o" -o"External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.c"
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.c:23:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.h:79:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Border.h:39:
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Variants_cfg.h:25:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder_cfg.h:29:9: warning: 'RB_NUM_BORDERS' macro redefined [-Wmacro-redefined]
#define RB_NUM_BORDERS (1u)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder_cfg.h:30:9: note: previous definition is here
#define RB_NUM_BORDERS (2u)
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.c:26:
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated\Rte_RbSwc.h:8:10: warning: 'RB_VAR_SINGLEBORDER' macro redefined [-Wmacro-redefined]
#define RB_VAR_SINGLEBORDER
<command line>:12:9: note: previous definition is here
#define RB_VAR_SINGLEBORDER 1
2 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarLeftRightBorder.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Variants.c"
Invoking: Arm Compiler
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_Variants.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_Variants.o" -o"External/gen40_trk_stef/rb/src/rb_Variants.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Variants.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_Variants.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/rb/src/rb_VarSingleBorder.d_raw" -MT"External/gen40_trk_stef/rb/src/rb_VarSingleBorder.o" -o"External/gen40_trk_stef/rb/src/rb_VarSingleBorder.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder.c"
In file included from C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder.c:28:
1 warning generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/rb_VarSingleBorder.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ClutterFilter.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_ClutterFilter.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_ClutterFilter.o" -o"External/gen40_trk_stef/smf/src/smf_ClutterFilter.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ClutterFilter.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ClutterFilter.c:77:12: warning: unused variable 'linearSNR' [-Wunused-variable]
float32 linearSNR = 0.0f;
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ClutterFilter.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_DataExportMgr.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_DataExportMgr.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_DataExportMgr.o" -o"External/gen40_trk_stef/smf/src/smf_DataExportMgr.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_DataExportMgr.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_DataExportMgr.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Element.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_Element.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_Element.o" -o"External/gen40_trk_stef/smf/src/smf_Element.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Element.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Element.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ElementSrc.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_ElementSrc.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_ElementSrc.o" -o"External/gen40_trk_stef/smf/src/smf_ElementSrc.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ElementSrc.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_ElementSrc.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_IncLineExtract.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_IncLineExtract.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_IncLineExtract.o" -o"External/gen40_trk_stef/smf/src/smf_IncLineExtract.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_IncLineExtract.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_IncLineExtract.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LineExtractIF.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_LineExtractIF.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_LineExtractIF.o" -o"External/gen40_trk_stef/smf/src/smf_LineExtractIF.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LineExtractIF.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LineExtractIF.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LinkedList.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_LinkedList.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_LinkedList.o" -o"External/gen40_trk_stef/smf/src/smf_LinkedList.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LinkedList.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_LinkedList.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBuffer.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_VarBuffer.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_VarBuffer.o" -o"External/gen40_trk_stef/smf/src/smf_VarBuffer.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBuffer.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBuffer.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBypassDet.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_VarBypassDet.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_VarBypassDet.o" -o"External/gen40_trk_stef/smf/src/smf_VarBypassDet.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBypassDet.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBypassDet.c:109:74: warning: call to undeclared function 'MATHLIB_SIN_Q15'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
float32 DetPosZ_m = senPosZ_m + ((curDetection->basicDetn->range_m) * MATHLIB_SIN_Q15(curDetection->basicDetn->elevation_q15));
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarBypassDet.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarLineExtract.c"
Invoking: Arm Compiler
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_VarLineExtract.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_VarLineExtract.o" -o"External/gen40_trk_stef/smf/src/smf_VarLineExtract.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarLineExtract.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_VarLineExtract.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Variants.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"External/gen40_trk_stef/smf/src/smf_Variants.d_raw" -MT"External/gen40_trk_stef/smf/src/smf_Variants.o" -o"External/gen40_trk_stef/smf/src/smf_Variants.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Variants.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/smf_Variants.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c:167:21: warning: unused variable 'trackListSafe' [-Wunused-variable]
Rte_TrackList_t* trackListSafe = NULL;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c:217:17: warning: call to undeclared function 'smf_VarBuffer_GetReadAccess'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
isAccessOK = smf_VarBuffer_GetReadAccess(accessObj);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c:233:25: warning: call to undeclared function 'smf_VarBuffer_ReleaseReadAccess'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
isBufPtrReleased = smf_VarBuffer_ReleaseReadAccess(accessObj);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c:257:28: warning: call to undeclared function 'DetnH_AccessAugmDetnList'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
Std_ReturnType result = DetnH_AccessAugmDetnList(cycleNumber, DetnListdata);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c:275:29: warning: call to undeclared function 'Detn_ReleaseAugmDetnList'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
Std_ReturnType result = Detn_ReleaseAugmDetnList(cycleNumber);
5 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c:51:8: warning: variable 'validRbInfo' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
if (NULL != ptToRbInfo )
C:\ti\ccs1250\ccs\tools\compiler\ti-cgt-armllvm_3.2.0.LTS\lib\clang\15.0.7\include\stddef.h:89:16: note: expanded from macro 'NULL'
# define NULL ((void*)0)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c:58:11: note: uninitialized use occurs here
return validRbInfo;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c:51:4: note: remove the 'if' if its condition is always true
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c:49:30: note: initialize the variable 'validRbInfo' to silence this warning
Std_ReturnType validRbInfo;
= '\0'
1 warning generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Ctrk_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Rb_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.c:74:41: warning: incompatible function pointer types assigning to 'Std_ReturnType (*)(uint8, FeatLib_AugmDetnList_t **)' (aka 'unsigned char (*)(unsigned char, FeatLib_AugmDetnList_t **)') from 'Std_ReturnType (uint8, const FeatLib_AugmDetnList_t **)' (aka 'unsigned char (unsigned char, const FeatLib_AugmDetnList_t **)') [-Wincompatible-function-pointer-types]
inputInterfaces->getDetnHListOfCycle = CommIF_AugmDetn_AccessAugmDetnList;
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Smf_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/Tracker.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/Tracker.o" -o"Integration/Tracker/Gen40_Ctrk_interface/Tracker.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:24:4: warning: call to undeclared function 'ObjCSwc_Init'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
ObjCSwc_Init();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:26:4: warning: call to undeclared function 'DetnHFunc_Init'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
DetnHFunc_Init();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:27:4: warning: call to undeclared function 'RbFunc_Init'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
RbFunc_Init();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:28:4: warning: call to undeclared function 'SmfFunc_Init'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
SmfFunc_Init();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:46:4: warning: call to undeclared function 'DetnH_StartCycle'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
DetnH_StartCycle();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:47:4: warning: call to undeclared function 'Smf_MainFunction'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
Smf_MainFunction();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:48:4: warning: call to undeclared function 'Rb_MainFunction'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
Rb_MainFunction();
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c:50:4: warning: call to undeclared function 'DetnHSwc_StopCycle'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
DetnHSwc_StopCycle();
8 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Tracker.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.o" -o"Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c:142:7: warning: call to undeclared function 'CommIF_AccessObjListPtr'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
CommIF_AccessObjListPtr(pObjectList);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c:225:16: warning: call to undeclared function 'CommIF_WriteObjListPtr'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
(void)CommIF_WriteObjListPtr(pObjectList);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c:142:31: warning: variable 'pObjectList' is uninitialized when used here [-Wuninitialized]
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c:133:30: note: initialize the variable 'pObjectList' to silence this warning
Rte_ObjList_t* pObjectList;
= NULL
3 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/ctrk_if.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:159:10: warning: unused variable 'sensorIdx' [-Wunused-variable]
uint8 sensorIdx = 0u;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:160:11: warning: unused variable 'arrayIdx' [-Wunused-variable]
uint32 arrayIdx = 0u;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:162:25: warning: unused variable 'vehDynState' [-Wunused-variable]
const Std_ReturnType vehDynState = CommIF_GetVehDynData(&vehDynLocalAry[DETNHSWC_NUM_SENSORS]);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:229:74: warning: incompatible pointer types passing 'uint64 *' (aka 'unsigned long long *') to parameter of type 'uint32 *' (aka 'unsigned int *') [-Wincompatible-pointer-types]
const Std_ReturnType detnListState = CommIF_AccessDetectionListPtr(&srcDetnListAddress);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.h:30:54: note: passing argument to parameter 'detectionListPtr' here
Std_ReturnType CommIF_AccessDetectionListPtr(uint32 *detectionListPtr);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:241:50: warning: incompatible pointer types passing 'uint64 *' (aka 'unsigned long long *') to parameter of type 'uint32 *' (aka 'unsigned int *') [-Wincompatible-pointer-types]
(void)CommIF_ReleaseDetectionListPtr(&srcDetnListAddress);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.h:31:55: note: passing argument to parameter 'detectionListPtr' here
Std_ReturnType CommIF_ReleaseDetectionListPtr(uint32 *detectionListPtr);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:296:4: warning: call to undeclared function 'TrafoLib_TransformPolarToCartesian'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
TrafoLib_TransformPolarToCartesian(&extdDetn->posX_m, &extdDetn->posY_m, projectedRange, basicDetn->azimuth_q15);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:298:4: warning: call to undeclared function 'TrafoLib_TransformSensorToVehicle'; ISO C99 and later do not support implicit function declarations [-Wimplicit-function-declaration]
TrafoLib_TransformSensorToVehicle(&extdDetn->posX_m, &extdDetn->posY_m, senGeoData->posX_m, senGeoData->posY_m);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:517:10: warning: incompatible pointer types passing 'uint64 *' (aka 'unsigned long long *') to parameter of type 'uint32 *' (aka 'unsigned int *') [-Wincompatible-pointer-types]
&DetnHSwc_detnListAddresses[sensorIdx]);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:515:13: warning: unused variable 'slotIdx' [-Wunused-variable]
uint8 slotIdx = DetnHSwc_slotIdxs[sensorIdx];
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:555:10: warning: variable 'cycleIdx' set but not used [-Wunused-but-set-variable]
uint8 cycleIdx;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:571:8: warning: variable 'ret' is used uninitialized whenever 'if' condition is false [-Wsometimes-uninitialized]
if (indices->cycleNumber < DETNHSWC_NUM_CYCLES)
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:582:11: note: uninitialized use occurs here
return ret;
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:571:4: note: remove the 'if' if its condition is always true
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c:569:22: note: initialize the variable 'ret' to silence this warning
Std_ReturnType ret;
= '\0'
11 warnings generated.
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/detnh_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/fs_interface.c"
Invoking: Arm Compiler
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/fs_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/fs_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/fs_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/fs_interface.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/fs_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/objc_interface.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/Gen40_Ctrk_interface/objc_interface.d_raw" -MT"Integration/Tracker/Gen40_Ctrk_interface/objc_interface.o" -o"Integration/Tracker/Gen40_Ctrk_interface/objc_interface.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/objc_interface.c"
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/objc_interface.c:57:83: warning: incompatible pointer types passing 'uint64 *' (aka 'unsigned long long *') to parameter of type 'const FeatLib_AugmDetnList_t **' [-Wincompatible-pointer-types]
Std_ReturnType detnListState = CommIF_AugmDetn_AccessAugmDetnList(cycleNumber, &detnListAddress);
C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/Comm_interface.h:49:101: note: passing argument to parameter 'pDetectionListAddress' here
Std_ReturnType CommIF_AugmDetn_AccessAugmDetnList(uint8 cycleNumber, const FeatLib_AugmDetnList_t** pDetectionListAddress);
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface/objc_interface.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/src/MathLib.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/MathLib/src/MathLib.d_raw" -MT"Integration/Tracker/libs/MathLib/src/MathLib.o" -o"Integration/Tracker/libs/MathLib/src/MathLib.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/src/MathLib.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/src/MathLib.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src/TrafoLib.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/TrafoLib/src/TrafoLib.d_raw" -MT"Integration/Tracker/libs/TrafoLib/src/TrafoLib.o" -o"Integration/Tracker/libs/TrafoLib/src/TrafoLib.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src/TrafoLib.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src/TrafoLib.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Edge.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/bgu/src/bgu_Edge.d_raw" -MT"Integration/Tracker/libs/bgu/src/bgu_Edge.o" -o"Integration/Tracker/libs/bgu/src/bgu_Edge.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Edge.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Edge.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Tetragon.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/bgu/src/bgu_Tetragon.d_raw" -MT"Integration/Tracker/libs/bgu/src/bgu_Tetragon.o" -o"Integration/Tracker/libs/bgu/src/bgu_Tetragon.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Tetragon.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Tetragon.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Vector.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/bgu/src/bgu_Vector.d_raw" -MT"Integration/Tracker/libs/bgu/src/bgu_Vector.o" -o"Integration/Tracker/libs/bgu/src/bgu_Vector.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Vector.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src/bgu_Vector.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_dataBuffers.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/utilc/src/utilc_dataBuffers.d_raw" -MT"Integration/Tracker/libs/utilc/src/utilc_dataBuffers.o" -o"Integration/Tracker/libs/utilc/src/utilc_dataBuffers.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_dataBuffers.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_dataBuffers.c"
Building file: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_matrix.c"
"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin/tiarmclang.exe" -c -mcpu=cortex-r5 -mfloat-abi=hard -mfpu=vfpv3-d16 -mlittle-endian -mthumb -Oz -flto -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/bin" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_dfp_02_04_09_01" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15" -I"C:/ti/ccs1250/ccs/tools/compiler/ti-cgt-armllvm_3.2.0.LTS/include/c" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/FreeRTOS-Kernel/include" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/portable/TI_ARM_CLANG/ARM_CR5F" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source/kernel/freertos/config/awr294x/r5f" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mcu_plus_sdk_awr294x_09_00_00_15/source" -I"C:/ti/mmwave_mcuplus_sdk_04_04_01_02/mmwave_mcuplus_sdk_04_04_01_02" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang/mssgenerated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/CCS_Project/platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/common/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Diag" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/Gen40_Ctrk_interface" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/bgu/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/external" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MathLib/public" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/MemLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/StrLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/TrafoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/RSP" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/generated" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/rte/MemMap" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/common" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/ctrkSingle" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/ctrk/src/util" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/fs/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/objc/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/rb/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/FeatLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/PtToRbInfoLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RandLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/RbUtils/RegLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/smf/src/prototype" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/buf/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PiLib/src" -I"C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/External/gen40_trk_stef/StefUtils/PtToFsInfoLib/src" -DDOWNLOAD_FROM_CCS -DDRIVERS_RADAR_HWA_V2 -DAPP_RESOURCE_FILE='<'ti/demo/awr294x/mmw/mmw_resDDM.h'>' -DGTRACK_3D -D_DEBUG_=1 -DSUBSYS_MSS -DSOC_AWR294X -DSOC_AWR2944 -D_LITTLE_ENDIAN -DCTRK_VAR_360 -DWHOAMI_CTRK_MAIN360 -DRB_VAR_SINGLEBORDER -DDO_MATDUMP=STD_OFF -DSMF_VAR_LINEEXTRACT -g -Wall -Wno-gnu-variable-sized-type-not-at-end -Wno-unused-function -MMD -MP -MF"Integration/Tracker/libs/utilc/src/utilc_matrix.d_raw" -MT"Integration/Tracker/libs/utilc/src/utilc_matrix.o" -o"Integration/Tracker/libs/utilc/src/utilc_matrix.o" "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_matrix.c"
Finished building: "C:/NewPF_Cheyrl/code/AWR2944/code/check_master/platform/Integration/Tracker/libs/utilc/src/utilc_matrix.c"
Building target: "platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.xer5f"
Invoking: Arm Linker
makefile:322: recipe for target 'platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.xer5f' failed
The system cannot find the path specified.
gmake[1]: *** [platform_awr294x-evm_r5fss0-0_freertos_ti-arm-clang.xer5f] Error 1
makefile:318: recipe for target 'all' failed
gmake: *** [all] Error 2
**** Build Finished ****
