Other Parts Discussed in Thread: IWR1443
Hi , datasheet says IWRL1432 has transmitter binary phase shifter
Are there any demo or example has a CLI to set this?
or How to set phase shifler?
Hi
Thanks for your query. Please allow us a couple of days to respond
You can set it to either TDM or BPM mode, but nothing custom. This is done in the CFG file, within the chirpComnCfg parameter under the ChirpTxMimoPatSel field.
More information on these two can be found in our MIMO guide
https://www.ti.com/lit/swra554
Pedrhom
Hello Abhishek,
BPM stands for binary phase modulation. Modulation and shifting are synonymous, please look at the BPM section of the document listed above.
Pedrhom
Hi Pedrhom.
I have used iwr1443 before, in its mmwave sdk,
There is a cli command ‘profileCfg’as follows
There is para txPhaseShifter to set tx phhase. (but for iwr1443 it is not work)
For IWRL1432 , Is there a parameter for this, or is there an example containing a similar cli command
We do not have this for 1432/6432 because it would not make sense to do this with only two TX antennas as it would not have much coherent gain.
Pedrhom
