Other Parts Discussed in Thread: ALP,
I would like to get the specification of Tray and Tape and Reel for IWR1843AOP (180pin FCCSP(ALP)).
Because I can't find them on the web. Please send me these spec.
Please advise.
Thank you,
Shoko
Please advise.
Thank you,
Shoko
Hello Shoko,
If you download the device's datasheet you should find all the information you need near the end of it.
Pedrhom
Hello Pedrhom,
I'm asking because I can't find them on the datasheet!
Have you seen the datasheet of IWR1843AOP? Please let me know what page is it written on?
Please advise. If you don't know, please change the person in charge about this questions?
Shoko
Hello Shoko,
I apologize, it should be there but I see that it is not. This is a problem and we will be going to update the datasheet. In the meantime, this is the information for tape and reel for the 1843AOP chip itself.
Reel - Tape and Reel : 01
Descriptor : REEL 24MM W X 100MM(4INCHES) HUB - 2.8MM THICK
Diameter : 330 MM
Hub Diameter : 95 MM
Width : 24.4 MM
Reel - Tape and Reel : 02
Diameter : 330 MM
Width : 24.4 MM
Tape - Tape and Reel : 01
Descriptor : Carrier
Width : 24 MM
A0 Width : 15.40 MM
B0 Length : 15.40 MM
K0 Thick : 1.50 MM
Pocket Hole Diameter: 1.75 MM
Pocket Pitch : 20 MM
Tape Cover : 01
Descriptor : Heat Activated Adhesive (HAA)
Width : 21.00 MM
Tape Lock : 01
Descriptor : BAND PROTECTIVE
Width : 24 MM
Tape-ESD Adhesive : 01
Descriptor : Yellow end tape
Width : 10 MM
Pedrhom
Hello Pedrhom,
Thank you for the information.
Please send the specification by pdf document, not the information in text only.
And, I said I want to get the specification of "Tray" and "Tape and Reel" for IWR1843AOP.
Please send the pdf document not only tape and reel information, but also Tray information.
Shoko
Hello Shoko,
I am not sure why that specific part number is not showing up in the search tool, but it will be the same as this one
https://www.ti.com/packaging/docs/carriermaterial/carrierlookup?OPN=IWR1843ARBSALPR
Pedrhom
Hello Pedrhom,
Thank you for your response. I've got them.
Please ask PIC to add the tray and tape adn reel information on the datasheet.
Shoko
